Dist/carb tuning question |
Post Reply | Page <1 2345> |
Author | |||
BuffaloBFN
Eric, I'll try to get those #'s today, but I was using the port on the carb that is no longer there.
Think I found(with help) what I need...carb |
how much vacuum? get a reading at the same port and RPM, im curious, you were at 13 to 14 at 700 rpm before
BuffaloBFN
For now it likes 14 degrees.
Just found out I can't return it, so I'll be looking to sell or trade it for a 650. Thanks for the additional input and I'll do what has been suggested when I round up the carb. |
why do all that like a real mechanic would when you all ready have the so called experts doing it for you at performance distributors where it was bought from. why because they are un-educated in the skill of adjusting a dist. correctly. |
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3357 |
I think Chris is still onto something here, when mapping timing on a 425HP model, I was amazed at the final timing the engine liked. I would do a disservice spouting numbers, but it was markedly more than the SBF numbers I was used to (35-36 for a 351). These two distributers having the exact same span is suspicious to me too. It may run fine now, but I suspect there is untapped potential in the engine with enough research, patience and skeptacism in the dist/carb hardware to find it and sort it out. I suggest find the initial the boat likes for a hard launch (usually the most it can take without a labored hot start) find the final the boat likes (have someone drive while twising the dist till no positive affect, then pull a lttle back for a comfort margin, measure this timing. Compare to baseline for similare engines. Subtract the two, and set the span on the advance to this number. this optimizes the min and max. Then play with the curve after you correct some carburation. |
restriction creates vacuum, the writing was on the wall and the restriction is the throat of the carb, good call
BuffaloBFN
I don't think I'll be stuck with it, but I can't get the guy on the phone. He may be out of town. If I do wind up stuck with it, I'll try to trade for a 650 and there may be another place or 2 around here that might want it. The carb I'm using now is mechanical advance and won't accept the factory flame arrestor...so I think I'll put it back the way the Meloons had it.
I think there's a lesson in that last statement somewhere...but with my thick head?!!? LOL |
id be curious to see what your vacuum readings will be now, the smaller throat should increase the readings to where they should be, are you stuck with the carb? can you return? i think the doc hit the nail on the head, stock cam, no increase on intake air and the 600 would seem a touch small but it isnt.
I would think if you went with a hotter cam to where the valves opened taller and stayed open longer the 750 wouldve suited the engine fine.....its a fine line, glad you got her straightened out |
Greg,
Don't jump in on having that cup removed from the prop . It was discovered in the early 60's that the cupping drastically reduced cavitation and is the reason for it. I'd continue tweaking the engine and then if needed have the prop re pitched or try another prop. |
BuffaloBFN
Ya Mon! |
Greg - I bet you sleep good tonight having this figured out!
BuffaloBFN
The verdict is in...a 750 is entirely too large for my application. I put the edelbrock/weber 600 back on it and I have full throttle response, smooth idle at 600(550 in gear), and a smile to prove it!
3 cheers from Amy and I to the Boat Dr.!!! He has patiently walked me through the workings of a carb, and I now have a much better understanding of V/E. Doc, I told you wrong about the prop. I pulled the receipt, and it's a 14x14 with a 200 rpm cup that needs to be removed. That and the flame arrestor sticking up higher again are the only things to work out for the moment. Thanks for everyone's input; oil change first thing in the morning, and I'll make sure to finish seating the rings tomorrow! |
BuffaloBFN
I put in the 71's and a 4.5 PV. It's better but still not right. It stumbles now at 3900-4000 instead of 3700. Maybe I should have put the 2.5 in it?
Should the breather hose be pluged when checking the vacuum...or is there not supposed to be any vacuum there at all? |
BuffaloBFN
There were 2 gaskets on the PV...both of the new ones I bought came with 1. Maybe this was a problem?
BuffaloBFN
Timing light in use sir!
the well qualify friend should have had a quality timing light as that is the most accurate method to determind total advance at a given RPM and that is what is important. And the big mark and big notch are the best marks to keep lined up but then you have to have the tools for the job to do it right at least. |
BuffaloBFN
I did verify TDC and have marked my balancer for 28 and 35 degrees. A well qualified friend told me how! |
sorry if you don't know the difference between total/final advance and built-in distributor advance two completely different things and when talking about dist advance you should be refering to actual advance on the motor and checking it while the motor is running not from some spec sheet joe blow provided.
Again it all goes back to the skill of the hand turning the wrenches you can either do it your self or get someone else 2000 miles away that will get you close, sorry you choose the later sorry you don't have the skill to do it your self, do you really think Doc would have went with the Unilite if he thought the DUI was better? Do you really? I don't. Do you really think you have more experince and first hand knowledge about the HEI distributor's design, functionalty and inner workings or ignitions systems in general than someone that actually worked on them for a living while they where still in production? some one that had to fix all of the little warrenty issue's that had to be fixed to improve the product? doubt it but then again I'm not a EE I don't focus on a small aspect of the big picture I have to look at the whole picture because it's the sum of the parts not some small electrical curcuit that doesn't move. |
BuffaloBFN
I was going to ask him who pissed in his corn flakes?!!?
Greg, just ignore Chris- he'll disagree with me no matter what I say, and since I like my DUI he has to say that its junk.
Set your base timing to 12 degrees, try the smaller jets, and report back. |
Don't have a problem with it it's just that you guys are leaving so much on the table by not doing it your self. Look at this way it sure sounds like Tim's and yours are curved exactly the same way, 24 degrees of advance is built in on both regardless of base setting but the odd thing is you have two completely different cam profiles and two completely different motors and since they are not apples to apples then how in the hell can the advance profiles be the same? How because you bought in to a bunch of BS, said that it's fine would look orginal never said that it would be set up correctly and running the wire the way you did was a big waist and thinking your going to get 14.5v to the coil all of the time is a big joke as well. Just keep a spare module on board and replace the cap often. |
will Tim what he types and what you say are two different things and set for 24 @ 3000 is 24 total advance and you don't add in the base timing to the figure.
It's real easy to figure out the actual advance with a quality timing light and you can actual set the rpm with the right light as well so if you have not reach full advance by 3k then you have it all curved wrong but then again your just guessing because you or he didn't do the work and haven't verifiy the actual timing at all, you are going by what you where told so speak in terms that are relevent not that I get 24 more degrees of advance over base timing at 3k horse ***************, max, total, final advance for a stock cam at 36-38 degress BTDC will ping ping ping like no tomorrow. Again get your head out of the book and spec sheet and live in the real world with real perfomance all around not just out of the hole. |
BuffaloBFN
Thanks Tim, I just picked up some 71's and a 2.5 and 4.5 PV along with the necessary gaskets. I'll get it surrounded soon! Chris, FWIW you didn't have a problem with the DUI when I bought it. |
Chris, he means 24 degrees of advance is built into the dizzy. You have to add the base timing to that 24 degrees to get the total advance. No idea if thats a good set up for a BBC, but 24 degrees of advance works great on my SBF. Greg, your old carb was an edelbrock, correct? It would be interesting to know what the stock jet sizes would have been with a Holley. Its just a WAG, but Id say 76 on the primaries would be quite rich. Maybe try dropping it a few (maybe a 74 or 72), run it briefly to see if performance improves and do a plug chop. |
would have been much easier to tap in the battery lead at the back of the motor, still don't understand the need, existing wire should have been fine, oh enjoy the hassles of not having it curved right. |
BuffaloBFN
It runs from the ignition swith straight to the dist. The ballast resistor is bypassed. |
from what ign post alternator? ign switch? did you keep the ballast resistor in the loop or something on the orginal wire? Sounds a little squirlly to me. |
this is your biggest issue not enough timing you should have at least 30 degrees at this rpm 24 is what you should have just after 2K oh well the DUI guys know how to get people to buy into BS if nothing else. Easy to sell parts to the unknowing uninformed folks out there especially with all of the free PR they get here. |
BuffaloBFN
As I understand it, it's full alternator voltage. It's a 12 gauge wire from the ignition post to the dist.
As far as fixing the rich carb, I thought smaller jets and PV would work towards that end. |
how are you stepping up the voltage your not going to get 14.5 volts out of a 12 volt battery and your just going to burn up the electronics if you do anyway, another great bit of advice along with the 24 degrees of total advance. The more you guys talk about those DUI units and what they are telling you to do just shows me they are full of it.
pv 6.5-5.5 but you need to get that rich carb fixed before you burn off all of the honing marks in the cylinders leaving power on the table big time. |
