  New Posts New Posts RSS Feed - Straps for Pylon
Straps for Pylon
MEB View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote MEB Quote  Post ReplyReply Direct Link To This Post Topic: Straps for Pylon
    Posted: August-03-2005 at 3:44pm
I just bought a 1985 2001 Ski Nautique and need to get the straps to secure a tall Pylon. Does anyone know where you can buy them or does anyone have some they would like to sell? Thanks.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2005 at 3:28am
what straps are your referring to? Do you
mean the cables from the high pole to the
bow harness? Do you mean the bow harness?
Put another way, what brand of high pole do
you have, and what parts are missing?
BKH
Livin' the Dream
MEB View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote MEB Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2005 at 12:32pm
I'm referring to both the cables from the high pole to the bow harness and the bow harness. All that they had when I bought the boat was the pole. The pole doesn't have a brand name on it. I think they had it custom made.Thanks for any help you can give me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2005 at 1:56pm
Big Air Pylons (bigairpylons.com) has the lowest cost extended pylon I've seen, $285 for a complete unit. They don't advertise replacement parts, but I would think if you gave them a call, they would probably sell you the harness assembly separately.
I've seen used pylons on craigslist.com for
as little as $100.
If you have to piece together, you could buy the plastic coated cable almost anywhere. You can use a ratchet type tightener from a set of nylon tie down straps, you can get a caribiner from any outdoor supply stoor, and you can use a trailer guide, or shock tube for the protective tube to go over the cable. What I'm clueless about is where you'll find the webbing used for the bow harness.
BKH
Livin' the Dream
MEB View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote MEB Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2005 at 4:37pm
Thanks. I'll check it out.
Ride_Klein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ride_Klein Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2005 at 7:36pm
The webbing for that front harness you can get at any camping/outdoor store that sells climbing and rapelling gear. It is very inexpensive and strong as all get out.
You can use a rachet strap from that harness to the pole if you'd like. You can get one rated at 10,000 lbs at your local home depot for around $11.
Good luck. Remember to always run the front harness around the bow and through the bow eye/trailer eye so it doesn't slip, tighten the strap from the harness to the pole tightly, and check the bolts holding the original pylon periodically to make sure they stay tight.
MEB View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote MEB Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2005 at 11:04am
Thanks. I appreciate everyone's help.
