prop questions? |
bdanley
Newbie Joined: May-08-2008 Status: Offline Points: 29 |
Posted: August-30-2008 at 9:56pm |
i have a 78 ski nautique im looking into getting a 4 blade prop for it since i mainly use it for wakeboarding and tubeing....I have been told it will do better under load....i want some opinions on wether it is worth it to go for a 4 blade or just stay will my regualr 3 blade....I have been doing some research and have had some trouble finding out what size of prop my boat has stock.......Another reason why im looking into a new prop is because last weekend i went to my local mudhole of what used to be called a lake and hit a tree that was submerged didnt do any damage to the glass, the major damage was to my prop so now im faced with ether just fixing this one or getting a new one....im leaning towards getting a new one and fixing my old one just so i have a spare....
nuttyskier2002
If you hit a tree as hard as it sounds, you better check your drive shaft for damage. Also you possibly could have knocked your strut out of alignment or bent it. I hate to be the devil's advocate but I'd definitely check those two things.
wait a while for a couple more posts, alot of guy's prefer the 3 blade nowadays because they have evolved and will out perform the 4 blade.
bdanley
my prop is a braL 13x13 1" im having trouble finding anything on it to even buy a new one i have found 13x13 1"1/8 as a standard size would that even work
Bradley950
Senior Member Joined: February-07-2005 Location: United States Status: Offline Points: 168 |
I Went with am ACME #540 this is a 13x12x1" your boat had a federal 13x13x1" if it was the original. The Acme #540 is the same diameter with just a little less pitch. This will give you a better hole shot. These new three blade props have come a long way and will pull like a four blade out of the hole and run like a three blade on top end. I tried a used four blade a friend had and loved the pull but it would not run out as good for barefooting. The #540 will impress you. Here is the link check it out.
http://www.skidim.com/prodinfo.asp?number=540 |
Brad Miller
bradley950@yahoo.com |
Bradley950
I forgot to tell you to make sure you have a Right Hand rotating engine. They make the #540 for right and left hand. Call Ski DIM they will help you out.
Brad Miller
bd, the 540 will be a RH. The 541 is a LH. go to Delta prop they are one of the site sponsors. Eric (FFM) at one time was talking about decent prices on Acme props too! |
bdanley
ya i talked to the acme, they told me to go with the 540 but at $439.00 bucks it better be worth it. is acme the only company out there to go with?
81nautique
Don't buy direct from Acme, buy from Delta through this site. enter promo code DP5CCF08 I think that gets you 5% discount. Delta price is $412 less %5 and free ground shipping. |
jbear
Got a 540 on my '80 with minor mods (GT40P heads & Performer intake) and it is awesome. Think you'll like it.
john |
79barefoot
Newbie Joined: August-16-2007 Location: United States Status: Offline Points: 24 |
I have a 79 Barefoot w/ a 14x14 three blade, the one on it now is stainless, it came with a bronze one that needs repair, it too is 14x14 not sure what brand or model but I have been thinking about trying something different. Either a 4 blade or one of these new 3 blade ones, what are other people running? any sugestions.
Chris |
Bradley950
Is that a 454 boat?
Brad Miller
79barefoot
Yes, and we mostly wakeboard, add about 900lbs ballast and it still pulls up nice and tops out probably around 55-57mph, I am quite happy with the way it runs but wanted to see if any one had any other prop experience and how they worked out.
Bradley950
Sorry no Big Block prop experience here. I am kinda jealous of all that pull though.
Brad Miller
get a GPS and come back to reality please, the speedo's like are real accurate until they hit 40. |
Chris (79barefoot), What are you doing this coming weekend? You should make it out to our northeast reunion and run your boat against the big boys. They all have GPS's that I'm sure you could borrow. |
75 stang
Senior Member Joined: August-11-2008 Location: northwest ohio Status: Offline Points: 475 |
There are better deals to be had out there from other dealers on the same prop. |
