seat brackets |
kevin719
Senior Member Joined: June-18-2008 Location: United States Status: Offline Points: 231 |
Posted: October-23-2008 at 11:45pm |
Does anyone have or know where I can buy the metal brackets for the captains and observers seats?Thanks
kevinindy
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
christines around $180 each
Not sure, but Paul Carpenter might still have some, I know he did at one time. Christines |
kevin719
it is a 74 southwind and what I am looking for looks exactly like what is in pic!!
kevinindy
kevin719
is that 180 per seat or per bracket????
kevinindy
75 Tique
Its been a while since I looked into it but if I am remembering right, its for a pair. Check with Christines.
Larry's right- its $180 for a pair of brackets (1 seat's worth).
Be careful- I think the Southwind brackets were taller than the other boats- the seats sat higher off the floor. |
Kevin,
I just looked through the ref. section looking at Southwinds. I was curious to see if I could spot higher brackets like Tim mentioned. All I see is bench type front seating ether split in the middle or on the port side like the Barracuda used to have. The cuda of coarse did have the bucket option as well. When you got your Southwind, was the interior completely gone? Just wondering! |
kevin719
yes no rear seat and the front seat was difinetely home made lookimg!
kevinindy
The CC bench seats were plywood with foam and vinyl. If real beat up, the originals would look home made!! Any pictures? I even saw that the Southwind open bows had the fold out to flat seats like a I/O! |
kevin719
The front seats that were in the boat was two forward facing seats with a console in between just big enough for a six pack.They were sitting on ply. boxes.They also had indoor/outdoor carpet on the bases and backs.If that was actually stock then I definetely want something different.I just want the double observers seat and captains seat(not on a pedestal.The boat shop that is doing my upholestry can make the seats but he will need the brackets.I do think that they will need to be taller for my boat.
kevinindy
Kevin,
I thought you were doing a original restoration on the boat! Shame on you!! You're going for a wakeboarding boat aren't you?? I did a search looking for JIH's print on the seat frames. You would just need to make the frames taller like you mentioned. Here's JIH's print: seat frame |
kevin719
Paul it will be original except for the front seats.I have plenty of pics of the original rear seats so that will be no problem. I just do not know what the heck came in the front. Every southwind that I see has something different! Maybe has something to do that they are over 30 years old.lol
kevinindy
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1154 |
I have a set of frames like you are looking for that are made to fit a Ski Nautique. If you want teh deat to sit up taller for the Southwind, you might build a base to elevate the seat. I'll take $100 for the set.
bartonh2o
Newbie Joined: January-11-2009 Location: United States Status: Offline Points: 4 |
Kevin,
I think I might have what you need. The brackets are used but I have driver seat and observer seat brackets from an early 80's model 2001 nautique. Let me know! |
todd johnson
Newbie Joined: January-13-2009 Location: United States Status: Offline Points: 31 |
hey kevin just wondering if you had any luck
on finding the seat brackets. i have a 70 sn and now have a 69 sn as well. im looking for brackets as well. |
ScottZ
I have a set made by a local machine shop I can sell. I'l take $100 for them. I will try to post a picture.
Scott, Im interested to see what youve got. Which style bracket are they- the ones for the fiberglass buckets (base only) or the ones for the 2-piece cushions (pictured above) with the back rest support?
When you say set, how many is that for- one seat (2 brackets) or 2 seats (4 brackets)? |
ScottZ
They are for the 2 piece cushion. I also have the base plates the attach to the floor. I have 2 brackets for 1 seat.
kevin719
Scottz No I stopped looking for the brackets.It seems that a bench type seat was original to my boat(like pbrainard said).The boat guy that is doing my upholestry found some pics here on c.c.fan and talked me into restoring it to original.Should be finished this week!
kevinindy
