  New Posts New Posts RSS Feed - Gauges act abnormally
Larry View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Quote  Post ReplyReply Direct Link To This Post Topic: Gauges act abnormally
    Posted: August-20-2005 at 10:32am
I have a 91 Sport Nat. and the voltage gauge drops when ruuning at normal speed or when the blower is turned on. Other symptons are when the lights go on the gauge drops running the radio. I have been stuggling with this problem for a while and could use some help.
Also I would like to know if there is a complete wiring diagram for this boat?
Lefty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lefty Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2005 at 2:07am
Check your grounds.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2005 at 1:26pm
Lefty,
Thanks I did check the grounds and was wondering if the problem was simlar to the other issues that I saw being reported with the voltage drop and changing the wiring.
I still need more help does someone else have any other ideas?
Is there another site like this one but for Sport Nautquie's?
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2005 at 3:01pm
Larry:
Easy way to check grounding issues is to run a wire directly from the negative battery post to the ground connection on the volt meter. Run this wire exposed if you like, because it is temporary. If the guage then acts normally, you must clean all ground contacts and repair poor wire terminals. My suggestion is to solder all crimped connections.
Tom View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2005 at 9:55pm
Sheesh, Larry... This topic is nearly eligible for the FAQ section!
Scroll down a couple to this thread and read the first few postings... It fixed my 1991 Nautique Excel guage problems with no questions whatsoever;
"92 Limp, Nav Lights, Voltmeter Problems"
