1969 Barracuda project |
Page 12> |
Roachie ![]() Newbie ![]() ![]() Joined: October-17-2008 Location: United States Status: Offline Points: 12 |
![]() ![]() ![]() ![]() ![]() Posted: October-28-2008 at 7:57pm |
OK, I've spent the last several months lurking the archives here for info on where to start restoring my 1969 Barracuda. My Dad has owned the boat since about 1990, and it's been in his garage since '02. Based on my Dad's description of his last trip out, I'm pretty sure the 318 needs a complete rebuild. Based on what I've read here, I've resigned myself to the fact the stringers need replacing (a job I would not attempt without the information available here, and only here). Those two jobs are my goals for this winter. I'm leaving the cosmetics for next year.
In praparing to dig in to this mess I've read every thread I could find on the stringer job. I know I have to support the underside of the hull (off the trailer) and pull the engine, but I have two questions: 1) I've found several threads on jacks/supports/braces for replacing stringers, most discuss three points of support stern port, stern starboard, and front keel. However, all pics I've found have four supports with two at the front. Which way is best? 2) Where's the best point to attach the hoist to lift out the 318? Thanks to all of you for you're knowledge. I can't wait for my Dad to hear that unmistakable sound. Joe Roach |
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Welcome! The Barracuda is a great boat and well worth the effort. I'm just finishing my floor after much procrastinating. I am not a carpenter, but the job was very doable. All you got to have is time and patience, and occational support from fellow members on CCF.
The engine should have lifting rings. I used a board bolted to 2 trees and a come along. Other members can guide you on the support for the hull. I did everything but the main stringers, so I didn't have to do that. |
critter ![]() Platinum Member ![]() ![]() Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
Welcome Joe,
I have just replaced the Primary and Secondary stingers in my 66 Barracuda. I left my hull on the trailer, made sure that the Stingers were level (started level, should end level) and braced all 4 corners. I then removed the 2 Secondary stringers and installed the new wood. I then removed a single Primary stinger at a time and replaced. This made me feel better about the hull remaining stiff while I worked inside the hull. It probably took longer as I had to grind away the old glass and clean the boat with each stringer replacement. I am now getting ready to install the new longitudal stringers. Lots more to do. As for the motor, that 318 is heavy. Lots of cast parts. I manufactured lift rings that I attached to the front of one head and the rear of the other. Then used a chain and my motor hoist to remove. Had to remove a wheel and lower the axle to the ground to get the motor over the side without having to remove the oil pan. Made it with 1/2 inch to spare. Good luck with your 69 and keep us posted. I will put this topic on my watch list as I would like to follow closely..... |
1980 Ski Nautique
1966 Barracuda |
Joe,
How about some pictures? The 60's hulls were quite thick and I really don't feel you need to worry very much about hull distortion. On the trailer is fine or the 3 point method. In later years, the hulls got thinner and relied more and more on the stringer system/foam to maintain the hulls shape. Doing one stringer at a time is really a good method. Besides keeping the basic shape, it also gives you excellent reference points for checking locations and dimensions. |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21143 |
I agree with Pete 100%. When I replaced one small stringer in my '90, the hull would oilcan a bit if you stepped on it. That was not the case at all with my Tique- that little hull is solid. |
Thanks for the inputs. Photos to come tonight.
Here are some pics of my '69 Barracuda. I took it off the trailer this evening. I figure that sould make it easier getting the engine out. I'm not really sure what's original and what's not. I'm pretty sure the original color was not brown, but some type of green. The thin brown paint on the hull chips easily which I don't think would happen with a gel coat. The base boards in the interior were painted brown, but had some green on the underside of the fabric. I know the starboard exhaust manifold is not original; my Dad replaced it in the mid '90s.
Before... ![]() Does anyone know what colors the '69 was originally available in? That may get my wife a little more interested. ![]() Already started the fun stuff... ![]() |
If you haven't already, spend some time looking through the 68 brochure in the ref. section. We don't have the 69 but I don't think the colors changed or were added onto until 70. This will give you a idea of what the interior is supposed to look like. Then you can go to the diaries and look at the 69 Cuda's. You should be able to spot the originals over the non. Interior colors didn't necessarily match the hull colors. I've seen some rear "off" combinations like your brown with a blue hull. I really don't think CC had a staff of interior designers back then. It was more like Billy Bob grabbing a roll of vinyl they had on hand!! Get your wife going on looking at the pictures. She'll do a much better job and hopefully enjoy getting involved. If you find a picture you (and your wife) like, post it and we'll be able to tell your if it is original or has been done originally. A hard item to find will be the flooring used. It is actually commercial grade vinyl wall covering. Lots of it is available on line but I've never been able to get close to a match by looking at the on line samples. Go into a wall paper shop with a sample and see what they say. When you get to the upholstery, you will not be able to do the fake heat stamped pleating/paneling done originally on the seat backs and bottoms. Have the upholsterer stitch it in by stiching the vinyl skin to a 1/4" sheet of foam backing. He'll know how to do it. Now the fun work starts - foam and stringer work!!! BTW, I'm one for not refoaming under the floor. |
Youre probably right- paint will peel off and gel wont. Is there green gel underneath the brown? If I were you, Id be stripping off the paint to see what kind of condition its in. |
Pulled the engine and about 4 garbage bags of wet foam today. I started looking for douglas fir for the stringers, but nobody in the Montgomery area carries it. That's just one more reason I hate Alabama and can't wait to move.
Is there an alternative to douglas fir to use when replacing stringers? As for the foam/no foam decision... Does the foam have any floor support, acoustic, or vibration mitigation qualities to it? |
[QUOTE=Roachie]
As for the foam/no foam decision... Does the foam have any floor support, acoustic, or vibration mitigation qualities to it? Be prepared for about 4 different answers! |
The Lake ![]() Platinum Member ![]() ![]() Joined: May-13-2005 Location: Lk Winnebago MO Status: Offline Points: 1157 |
Welcome to the site; good to see the little guy getting his hands on this project. Thanks for the pictures, we are all boat voyeurs.
Chuck |
Joe,
On your question on foam or no foam - No on a 60's hull. Keep looking for the Doug fir. |
storm34 ![]() Grand Poobah ![]() ![]() Joined: November-03-2008 Location: Dexter Iowa Status: Offline Points: 4492 |
Looks like a great project! I agree with TRBenji- see what the original gel looks like, cant beat a Green Machine!
korey ![]() Senior Member ![]() Joined: May-09-2008 Location: United States Status: Offline Points: 130 |
Good looking 'cuda! I brought a '70 'cuda back from the dead this summer, and am loving every second of it. keep those photos coming!
Korey Morris
1970 CC Barracuda Project 1993 Sport Nautique |
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6119 |
Tim's last green machine. (no joke, it really is) ![]() ![]() That bit of humor aside, looks like a great project...good luck with it. I too like the father son aspect of it. Always enjoy it when I have the engine cover up and my son walks by and starts asking questions. How many kids know anything about internal combustion engines any more. Certainly can't point out the basic stuff on new car engines. |
That Freeport may not have been my favorite boat, Larry- but I really did like the color! Id love to have a Mustang in the same combo.
Agreed. |
There have been a few dedicated threads on foam plus a good discussion somewhere in the pumpkin patch.
This is all new to me. I tore the engine down this week to see what I'm up against. Looks like #3 is bad. I'm working to get this to the point I can get it in to the machine shop this week. I hope they can help.
WakeSlayer ![]() Grand Poobah ![]() ![]() Joined: March-15-2006 Location: United States Status: Offline Points: 2138 |
Joe,
Meant to give you props for the visual on your motor cart. I needed to slap on together late last week real quick and used yours as a guideline thanks! Mike |
Mike N
1968 Mustang |
Sounds like things are moving right along.
When you take the block and heads to the machine shop, make sure that you tell them that it is a marine reverse rotation engine. Also may want to tell them about EGGE as they will have the intake and exhaust valves you will need. They will also have pistons if needed. My machine shop said they looked for 2 weeks when I called for a status update. Gave them Egge's 1-800 number and they called me back in 10 mins to say the parts were on the way... Thanks to Reid for this site. |
1980 Ski Nautique
1966 Barracuda |
by the look of the engine cradle, we may have another OCD' er,
my vote, no foam nice job your doing |
No OCD here. Just too cheap to buy a proper engine stand. I think I'll need one though when it comes time to pick the engine up and reassemble it.
sanity ![]() Gold Member ![]() ![]() Joined: September-16-2008 Location: United States Status: Offline Points: 799 |
I am still battling with the foam/no foam issue myself. I say no foam and JB says foam. I think he's more worried about my safety and the effect it would have on me if God forbid anything should happen to the mustang when it's completed. Have time to toss this around so I will keep watching this thread.
BTW, the boat that the excavator is picking up...looks like something I would bring home. ![]() |
Hmmm... it looks like something I did bring home. ![]() If the only issue regarding the foam vs. no foam decision is floatation/safety, consider packing the cavities between the hull and floor with pool noodles. I think I will be going this route on my next restore. |
I saw that in one of your other postings and suggested that to him. He thought I was teasing.
That should take care of "both" of our issues regarding the foam. Solved! ![]() |
I really like the noodle idea too. Sounds silly, but I like it.
Cheap, easy, floats, and doesn't absorb. I need to find some blue ones for the Mustang. |
Mike N
1968 Mustang |
It could easily be my memory, but maybe some have changed their opinion on foam? Maybe some of the older threads on this are worth a re-read?
LOL...if that is in reference to me - heck, I've already gone from painting the boat to keeping it original. :) For a first boat project... I'm not doing so bad. ![]() |
Page 12> |
