  New Posts New Posts RSS Feed - Seat Bottoms
Seat Bottoms
BigC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigC Quote  Post ReplyReply Direct Link To This Post Topic: Seat Bottoms
    Posted: November-03-2008 at 3:56pm
What is the best material to replace the original plywood seat bottoms. Treated plywood? Exterior plywwod coated with eposy resin? Other?
Thanks
Bruce
BigC
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2008 at 5:30pm
Bruce, I replaced all the seat bottoms in both my Tique and '90 with exterior ply coated in epoxy resin. I fully expect them to outlast the vinyl!
anthonylizardi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2008 at 5:45pm
I was thinking using King Starboard on my seats. My uncle did his floors on his 1978 29' Beltram and the material looked great. The water line came up a little since the material was ligther than the wood he had before. IMO, I thought it was great. I have seen pieces of it sold on ebay. That is my plan.
Tellarico View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tellarico Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2008 at 6:52pm
Like Benji I used exterior plywood but did not go as far with the resin. I used polyurethene which is easer and not quite as messy as resin. Benji's will be stronger and last longer but I'm 50 and the poly will Probably outlast me. Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2008 at 11:45pm
I don't know about it being lighter. I just went to their site because I'm looking at options for floor material. They have a weight calculator, for a 1/4" 4x8 sheet it weighs 40lbs.
BretC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BretC Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2009 at 1:50am
Guys - I replaced our observer with "Starlight" board. An oil base gray board. Also cut 3/4 holes near the under side of the leg lift that went all the way through the seat base (fiberglass support that swings up). This allows the water to drain out that gets caught inside the foam. I probably cut 20 holes in it. Works great!
1990 Correct Craft
Bret C
Neodesha, KS
