  New Posts New Posts RSS Feed - 79BFN
79BFN
 Post Reply Post Reply Page   123 7>
the grinch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Topic: 79BFN
    Posted: January-20-2009 at 11:08pm
Okay........I've started my rebuild.
I probably wouldn't post this, but I'm going to do a few different things in this build that may be useful to others.
I will primarily be using, of course, epoxy resin, however, I will be using some two-part epoxy adhesives in a few applications.
I am also planning to build my own engine cradle of sorts. I do have some preliminary concerns with the overall shape and contours of the 79BF primary stringers and how the motor/trans mounts are located, however, I will attempt something. I'm going to get a little more involved in it this weekend and I'll get some of your opinions later.
Here is where I am so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2009 at 11:16pm
Sorry guys. I'm new at the picture thing, I'll try some more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2009 at 11:20pm
Kirk,
Before this thread gets longer, please go back and edit you post. Use the "enter" key between the pictures and they will stack top to bottom instead of side to side. It makes reading and looking at the pictures easier.
Keep us posted with your ideas. We've got plenty of experts here to critique them before you get into a potential problem.
So, it sounds like you're going to be getting some "sample" epoxies!!!
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2009 at 11:21pm
Go back and edit your post, hit enter to add a line between each photo. Also, if you are able to resize to 7 inches wide they fit perfectly without having to scroll over.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2009 at 11:23pm
Looks like a lot of fun, btw !!
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2009 at 12:44am
Thanks for the help guys. Let's try a few more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2009 at 8:22pm
Have you seen all of my rot? It's amazing someone would take such bad care of something. If you'll look at one of the pictures that shows the motor mounts, you can see that I drilled some holes in the primary stringers. I drilled with a 3/4" hole saw to get a core sample from them. I was amazed that two of the four cores were completly dry. The stringers are very solid, however, that moisture in there will eventually be a problem so they got go! Here are a few shots to bring some things up to date.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2009 at 8:29pm
You need a new key chain!
Looks like nice work...I almost recognize some of it. You did check the keel piece? Mine was a mess.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2009 at 8:36pm
You probably can't tell from the pics., but the bulkhead that is furthest forward is bonded to the hull with epoxy adhesive. The other two are in with the epoxy resin mixed with cabosil and 1/2" fiber. Using the epoxy adhesive is a far cleaner and simpler method. I don't know the exact strength specs of the epoxy resin, however, the epoxy adhesive is around the 3000psi range. In my testing, which was quite simplified, the adhesive is stronger in this application. I don't think we're trying to reinvent the wheel with these repairs and the mat/cloth is what adds the strength overall, however, I just wanted to try something a little different. There is only one downside that I see to using the adhesive..........the cost. That's why I chose to do the other two with the resin combination. I am going to do some more on the project with the adhesives and I will detail my use in those applications with pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2009 at 8:49pm
I wish all I needed was a new key chain! The keel piece was good except for an exposed part in the very front where the factory glass work was crap. I cut it back a few inches and it dry/hard wood. I did not replace the wood here, only cleaned up and repaired with new epoxy/glass. There were some black colored patches in the glass up against that keel piece that can probably be seen in the pics. Those areas are where scrap wood was laying against it and foamed over. As a matter of fact, there were scrap pieces of wood all in the foam and of coarse usually laying against the hull and rotten. This boat has been inside my shop since August of 2007 and it's amazing how much water and moisture was still in the foam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-22-2009 at 9:58am
Kirk.
You sure made lots of progress in one day. Keep it up!!
Greg asked about the inner keel towards the bow. I too am curious if you took a core sample from it. Greg's, as mentioned was a mess!
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-22-2009 at 11:18am
Can not tell a lie.........I started digging foam 6 months ago. I had some other projects going on and thought the boat could use a little more drying out time. I'm on it full bore right now, or at least every weekend. It's amazing how long it takes before you make progress. I wanted to have the floor in by the end of Feb.............we'll see how I do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2009 at 4:33am
To borrow from Donovan (Nautiless) You are going to have to give it horns to get even remotely close by the end of Feb. I just added up my hours on the Mustang last night and have just broken 200 hours. Being the first time I have done anything like this probably attributes to a few of the hours. However this also does not include time spent researching and ordering parts. Time spent running to West or Home Depot or the hardware store, etc. I started at the very beginning of Nov and still am a ways away. I am at it at least parts of 4 nights a week and both days on the weekends as my wife will allow me.
If it weren't her boat I would probably be........
It is a sickness.
Mike N
1968 Mustang
nautiless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautiless Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2009 at 10:14am
Kirk:
Good on you in bringing new life to this BF. I'm sure the rewards will be well worth the effort. Your first corner to turn will be when you stop breaking things and start building up piece for piece. Don't be discouraged by the passage of time but start and keep the end in mind.
1982 SN 2001 RIP (Resto in Progress)
Don's Diary
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2009 at 2:31am
I had an efficient weekend on the BF. The two big obstacles I've been putting off were the engine cradle and removing the primary stringers. The cradle is done with the exception of the U-bolts for the pylon. It is a little different, in regards to it only tying into the motor mounts and not the transmission mounts as well. I was a little concerned with the change in the angle from the motor mounts to the trans. mounts not to mention the curvature in the stringer. After thinking about this for the last two months, I reminded myself that the only reason I wanted to add a cradle was to take some stress off of the floor. It should work just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2009 at 2:55am
By the way, the first stringer came out in one piece and took maybe 15 minutes. I zipped down both sides, wacked it with a rubber mallet 4 or 5 times, and pryed it out with a crowbar. I don't have my fir 2x's yet, so I concentrated on the secondary stringer. It took alot of adjustment to get it right, however, I left tonight with one side laminated and one side of the lateral supports laminated as well. Going to pick that fir up tommorrow and get on that stringer tommorrow night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2009 at 12:52pm
not so sure your craddle is finished, as I think your going to run into a big oh *************** it shortly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2009 at 3:02pm
Chris, is this what you mean?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2009 at 4:25pm
well maybe it is different on the BFN but your picture doesn't look right either. From what I remember and maybe the BFN's are not the same, but the angle sat on top of the stringers then the c-channels where below and tucked under the deck.
Yours looks like it is sitting on the hull and some extra material was added. This is not like the design I have seen for the 80-81 SN, so being a BF maybe it's ok it just doesn't look right to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2009 at 12:35am
Chris,
If you look at my previous picture of the two mounts sitting on the lone stringer, you will see how low the stringers are in the 79BF. After I removed this stringer, I discovered they made it with a 2x4 and had a small 3/4" wedge stapled on at the highest part......not much there. You are correct, in that it sits down on, and rests on the stringers and the actual 3"channel that crosses is below floor height and will slightly sit under the floors edge. I was almost lucky in the way this had to be built because of its simplicity. The lateral bulkhead (the piece the vent hoses come through) sits too close to the pylon to make one like on Greg's 88BF. It would also completely block off the vent ducts and the mechanical ducts. I'll post pics. once I get the new stringers in and can mount the cradle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2009 at 12:46am
Check out how clean this stringer came out.
I was able to get the secondary stringer dry fit along with the lateral supports that brace it. Started laminating. The shop is averaging about 36degrees unless I'm there with the heater running. I should be able to get back on the other side of these by Wed. night and get one of the primary stringers laminated on one side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2009 at 10:27am
nice to pool your resin when you lay the new wood, dont grind it away
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2009 at 10:30am
for a keel board a built last night, i used 1x3's staggard, board glass board glass board...very strong, i wound up right over the 2 inch mark on the width
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2009 at 10:35am
The pic above may be misleading...
1988 BFN-sold
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2009 at 1:05pm
Grinch, really tight work you've pulled here!!!
My question is why would you put those pieces where the vent tubes go through before the stringers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2009 at 10:27pm
I guess there were really two reasons for starting up front. I was really tired of being up under that dash and was ready to get some of the nasty work done. The main reason was with the nearly completely decomposed bulkhead at the pylon and my plans to compromise some type of a cradle, I needed some type of baseline to start with. By that, I mean I had to make the bulkheads and figure out the clearance for the vents and other ducts as not to interfere with the cradle. I didn't, however, have to glass them in, I was just ready to be out from under that dash for a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2009 at 12:32am
I really wish I had gone with the faster epoxy now. I bought the medium, and with the shop temps kind of low, it's taking forever for it to dry. I'm talking 2 days! I could have made alot of progress this week.
If anyone has figured out a way to laminate both sides of a board at once, let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2009 at 1:37pm
Grinch,
Are you using West or US?    I used West 105/205. Is done drying in a few hours. I keep my shop between 50-55 when not in there.
It would be tough to do large boards on both sides, but little stuff, you can clamp with decal backing paper, shiny side to the epoxy. Or pieces of stiff blister packing. A trick I heard from the Boat Dr.
Mike
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2009 at 1:49pm
I'm glad someone is finally restoring this boat! The pictures look great, what are your plans with the engine, doesn't it have at least one sleeve?
Post Options Post Options   Thanks (0) Thanks(0)   Quote the grinch Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2009 at 8:11pm
Mike,
Thanks for the trick on the decal backing paper. I bought some wax paper today and I'm going to give it a try on some small stuff as well. I'm using the UScomposite stuff. I'm happy with it with the exception of the dry time. If I could keep my shop 50-55, I think I'd be fine, but I can't do that when I'm not there.
