  New Posts New Posts RSS Feed - Dirty bilge
Dirty bilge
Tom Richards View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Richards Quote  Post ReplyReply Direct Link To This Post Topic: Dirty bilge
    Posted: October-25-2003 at 4:11am
My bilge has some oil and transmission fluid in it. I want to clean it really well so I don't dump oil in the lake when I turn on the bilge pump. Pulling the plug out-of-water doesn't get rid of it all. What's the best, non-toxic, way to clean the bilge?
Jason View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2003 at 8:50pm
Bilge cleaner and really hot water. Tow your boat around to slosh it around and then rinse it out of there. Don't let the water cool down.
862001 View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 862001 Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2003 at 4:10pm
I have good luck using Simple Green (bio-degradable and non-hazerdous)and a rag.
But then again my boat doesn't stay in the water. Give it a shot it may work for you to.
Brad View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad Quote  Post ReplyReply Direct Link To This Post Posted: November-17-2003 at 2:23pm
An oily bilge is a frustrating issue to deal with! I recommend finding the source of the oil leak and repairing it.I've been battling this for a couple seasons now. Every couple weeks pour a half gallon of bilge cleaner down there and let is slosh around with whatever water is introduced.Before adding more, pump the water into a container and dispose of it properly. Disconnect the automatic bilge pump sensor if your boat is equipped with one.I disconnect the bilge pump hose inside and use it to pump the oily water into a container. Repeat the process and it should eventually clear up. Mine has!
Good luck!-Brad
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: December-13-2003 at 11:17pm
try a squirt of dawn dish liquid once in a while to maintain a clean bilge.so long as you dont have a major oil leak it works good for me
kenny g
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2004 at 1:47pm
My 66 hs a very small rear main drip. I use an oil absorband pad from West marine. I cut it into 4 12X12 pieces and put it under the rear main. The absorbant grabs the oil and the water I pump out is clean
882001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2004 at 2:04am
i bought some castrol super clean engine degreaser. amazing stuff. i dont know about non toxic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2004 at 10:35am
Double check but I do beleive that castrol's super clean is non-toxic and it works great, spray it on and rinse the oil away.
