  New Posts New Posts RSS Feed - rub rail insert
rub rail insert
jdarwin View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdarwin Quote  Post ReplyReply Direct Link To This Post Topic: rub rail insert
    Posted: September-27-2005 at 3:25pm
Looking to replace the blue rub rail insert on my 1997 SN. Dealer says they are back ordered. Any suggestions?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2005 at 3:56pm
try west marine or the manufacturer directly. Ask CC who the supplier is and then go to them. It will save you cash going that way, no mark-up. There maybe a logo on he rub rail as well identifying the manufacturer.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2005 at 7:39pm
I believe the OEM is TACO. However, the blue insert is probably manifactured exclusively for CC and not publically available.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdarwin Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 4:55pm
Actually, all I'm looking for is the blue insert - not the entire rub rail assembly. The insert is a plastic tube that resembles a small garden hose. Somebody makes this. I just need to find out who.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 5:31pm
Ok I'll try and not be nasty but two of us have already told you all you need to know. Do we have to buy it and ship it as well?????
GO TO WEST MARINE AND BY THE BLUE INSERT TUBING FOR TACO RUB RAIL OR YOU CAN ORDER ONE OF THE OTHER THREE COLORS THEY HAVE AVAILABLE.
DO you have it now or do we have to look up the item number for you as well????????????????????????
It sounds like you never looked at WESTMARINE.COM It was pretty clear all you wanted was the insert.
882001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 9:24pm
what a complete jack ass!!!!
pswann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pswann Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 9:35pm
I didnt know that was even available much less just the insert. Kind of expensive and a long piece but news to me. Thanks for the info!
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=59968
All I need to learn is one thing a day and I will be a smart fella soon.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 9:48pm
If you go to a west marine store they will sell it by the foot and you don't have to buy it bulk
882001 you should read some of the dumb ass advice you have given
Post Options Post Options   Thanks (0) Thanks(0)   Quote pswann Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 10:05pm
The 20 foot southwind has that stuff in rope form that has to be fixed to be perfect. I had no idea that stuff was so readily available. Maybe I am just easily amused but I am glad to know this. I didnt even know what it was called.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 10:17pm
pswann,
On the older boat's it was rope, on the newer one's they use rubber. It really makes no differnce you can use either or just as long as you have the same diameter as what's in it currently. I perfer the rope it holds up better against nick's and cuts and you have more options in colors and availiblity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2005 at 11:32am
79....
Just so you know the insert in the newer boats is plastic, not rubber.
Also, I believe the TACO rubber rails listed in West Marine's catalog are not the exact size (profile) as used by CC.
