Shaft Strut Bushing |
Mustang 66
Newbie Joined: November-11-2008 Location: United States Status: Offline Points: 27 |
Posted: March-18-2009 at 4:02pm |
Hi Guys,
I have taken the drive shaft out of my 66 Mustang to replace and the packing in the stuffing box and the hose between the shaft log and the stuffing box. I am wondering if there is a way to tell if I need to replace the bushing in the shaft strut. I don't know if it has ever been replaced and now would be a good time to do it with the shaft out. Let me know what you guys think. Thanks for the advice!!! Pat |
change it now while everything is out. Odds are it needs replaced anyway since you realy don't know how long it's been in there and the part is not very expensive so it's worth doing now.
Basicly to check it the shaft needs installed and then you look for play or movement of the shaft in relation to the strut bushing. so you could double check the play by sliding the prop end of the shaft back in to the strut and see how much play there actually is. But I wouldn't worry about all of that and just replace them. Remove the two set screw on the side of the strut use a hacksaw blade and make two cuts into the bushing 180 apart cutting it into two pieces then remove it and drive in the new busing. The other method is driving them out which is much more of PIA to do but to each there own. it might be one long bushing or two shorter sections. I forget the OD of the bushing I believe it's around 1-1/4" OD and definately a 1" ID |
excellent advice, to add make your first cut into the top part of the strut where all the meat is in case you cut to deep..one cut usually will get it out, if not make another 180 away
note: to date i have yet been able to push one out with a press, if you can then the bore is oversize. go with the sawz-all and save yourself aggrivation |
skierbrant
Senior Member Joined: September-24-2004 Location: United States Status: Offline Points: 243 |
Since I've owned my boat for 12 years, I think that my strut bushing needs to be replaced as well. When I back up, I do here vibration and can only assume that the play in the bushing is the root cause. How much play is allowed?
it needs replaced you can stand a slight bit of movement but 12 yrs is way beyond the usable life of the part. |
WakeSlayer
Really? I have no intention whatsoever of replacing the one in my SAN anytime soon. Brant's boat is the former boat of a good friend of mine and that is definitely the original bushing in that boat. 20 years old and what 1800 hours? I know it was over 1000 when Zman sold it to him. That, I am sure, bears replacing, but ... Mike |
Mike N
1968 Mustang |
86BFN
Gold Member Joined: July-28-2008 Location: Indiana Status: Offline Points: 882 |
SKIDIM say every 300hrs. of course they sell them.....
skierbrant
Mike, I just learned that you are zmans friend. Just talking with skierox tonight. The old boat still runs as good as the day I bought it from the zman! Just a few issues here and there. I'm scared to take the drive shaft out without messing something up! |
skierbrant
isn't there some special tool that you need to take everything apart?
Brant, If you are referring to the slide hammer pullers sold for the cutlass bearing removal then yes it is special. You're welcome to try it but I feel you'll find out just how "special" this tool is. Most including myself feel it's a joke! The wall (shell) of the rubber cutlass is so thin there's not much to grab onto plus the old cutlass's are always really stuck into the strut. Just cut out the old one like Chris and Eric have mentioned. It's easy, fast and it works!! I think you've been spending too much time over on the Skidim site!!! |
I dont understand this slide hammer thing, it has its place, but not on boats....---- if i used a slide hammer on a strut,I think you would break the strut off the boat..use a sawzall
Pete, it took me 20 frickin years to figure out how to remove bushings from planetary's, I called everyone in the country for thier methods, and they were anywhere from tapping them and pulling them, die grinding them, blind hole pulling them and so on.....it was always a 2 hour process, and GD wouldnt you know it, you knock in the bushing a touch and go thorugh the oil hole and collapse the bushing.....6 minutes flat
20 years of learning curve, sometimes the advice given is golden and we handled the learning curve |
WakeSlayer
Brant, that boat was amazing back in the day, really glad to hear is still is for you today. Z is likely coming to GL with my wife and I. He would get all misty seeing that boat again. I have talked to Ox a couple times. Seems there is some common Python ground there too!!
I think the shaft removal will be the easier part. I did not think that was a big deal at all. Guarantee you need an alignment anyway, unless you have been keeping up on that. I have heard or using a slide hammer to get the coupler off, what is the consensus there? Mike |
Mike N
1968 Mustang |
yeah!!!! use one on the back of the trans too,
one day I'll put a pic of a back half of a trans that someone used a slide hammer on lol slide hammers are for bodywork |
Eric,
Have you seen the video "how to" on Skidims site using the slide hammer on a cutlass? It's a kick! New strut, new cutlass and I'm sure the set screws were never dimpled into the shell!! |
I wont even use one when no one is looking, I didnt see it Pete, shameful
skierbrant
The slide hammer was the only way I knew of taking the stut out until reading this site. Sawsall sounds much easier. I don't often go onto the skidim.com site but is that the best place (or maybe the only place now) to buy the struts? Is there any other concerns when I pull the shaft out as far as alignment issues? |
skierbrant
Mike, looking forward to meeting you and seeing the zman again. Hopefully he won't try to buy her back from me! |
WakeSlayer
Is my memory correct that you were thinking about selling it a couple years ago? I would swear he said something about buying it back.
I bet he would in a heartbeat. |
Mike N
1968 Mustang |
skierbrant
I did list it for sale. My family wanted a newer boat but our priorities were different. I wanted a 97 or newer SN but they wanted a 2003 or newer SN206! I wasn't ready to fork over that much money at the time! Now with the economy, the way it is, I'm glad to have a boat at all!
Brant, I'm assuming you're asking about the cutlass bearing in the strut and not the strut itself - correct? If you do a on line search for "cutlass" bearings lot's of sources will come up but, it's always nice to support one of our sponsors like Skidim too. You will find that there are 2 piece plastic culass bearings available. I prefer the old rubber ones with the brass sleave. In the many years I have in engineering power transmission components, I'm not a big fan of plastic bearings. Regarding alignment, you need to keep in mind that it starts at the strut and then goes forward. The prop shaft first need to align with the hull hole/shaft log. If not then the strut may be bent (they can be straightened) or it needs realignment. Then the engine is aligned to the shaft with the engine mounts. |
skierbrant
I'm not a fan of plastic myself. Brass is definitely first choice. Thanks for the info!
Brant, Actually the shell is brass but the contact surface to the prop shaft is a hard rubber. The length of the rubber is fluted to allow water to lubricate it. The plastics are too. Next time you are around the boat, get down there and take a look. While you're down there, see if there's any axial play in the shaft and see how easy the shaft turns. |
Pete - did you mean radial play? Axial play would be a bad transmission bearing!
Donald80SN
Pete,
I was under my boat last night and I am concerned that my prop is too hard to turn. I am able to turn it but it requires some effort and it feels stiff. The boat is a 1980 and I have no idea if the bearing has ever been changed. If the prop and shaft is hard to turn my hand, does that point to a wore out Cutlass Bearing? I need to tear into mine any way because at the lake today my Shaft Log Packing was leaking when it should of been dripping. Thanks, Donald |
Chris,
Yes, radial play! Sorry! Donald, A worn cutlass bearing will be easier to turn. Something may be out of alingment so it would be a good idea to do some basic checks. Have you seen Eric's pictorial thread on alignment? It covers the engine to the shaft but not back to the strut. It would be a start. Also, what is easy to turn to some may be hard to others. The cutlass being water lubricated can cause lots of drag on the shaft. |
Donald,
Erics alignment thread Since you have a leaking shaft stuffing box, open it up and take a look at both the shaft and the packing, Then unbolt the coupling halves at the trans to do the alignment check, While both are loose, go back under the boat and see if the shaft turns any freer as you move the forward end of the shaft side to side or up and down. Does the strut look straight and also not twisted? |
teodoro.guzman
Newbie Joined: January-29-2009 Location: Mexico Status: Offline Points: 8 |
Hi All,
I am tring to align a shaft, but there is some "sag" in it (The shaft coupler has some play in it when unbolted from the tranny) is this normal?? I find it hard to align the engine/trans to a shaft that is not fixed in place. Does this mean my cutlass bearing is worn? |
Yes the weight of the forward section of prop shaft as well as the coupling half is working against you. I suggest supporting it with a block of wood so the shaft is centered in the shaft log. At this time, get under and turn the prop shaft to check if it is aligned with the strut/culass bearing. This is one of those judgement calls to see if it's moving free if the forward end is moved up down port or starboard. If it turns easier when the shaft isn't centered in the log then you will need to align the strut to the hull. Cutlass bearing condition is checked by seeing if there is any radial play betwen it and the shaft. You say "the shaft coupler has some play in it when unbolted" Do you mean it's loose on the shaft? If so, you will need a new coupler and it needs to be bored to fit the shaft. With a engine and shaft misalignment, the coupling and shaft interface will fret. This is due to the small movement as it's run and will wear down the bore/shaft. The bore is a shrink to fit (-.0005 to -.001" undersize). The coupling is heated to expand and then slipped onto the shaft. |
teodoro.guzman
No, there is no play between the coupling and the shaft.
The strut bearing is gone, i will be getting a new one in soon. I will upgrade the packing rope to GFO while I am there. Does this mean I should expect little vertical/lateral play at the shaft coupling? |
