  New Posts New Posts RSS Feed - eBay finds
eBay finds
 Post Reply Post Reply Page    <1 3334353637 39>
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2009 at 11:10am
Originally posted by Riley Riley wrote:
If it's a 272, it's got some value. The 256 is practically unknown and unwanted. It wasn't even a Ford engine, it was a Merc.
Bruce,
Where are you hearing that the 256 is unknown and unwanted? The first Y block was even smaller at 239 cubes. Have you ever seen the Y block history in cars/trucks? Just because the Y was used mostly in the Mercs it's still a Ford.
Ford Y block
Innovation and quality has different meanings to different people.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2009 at 10:49am
My manual only shows 2 versions of the 256. I'll look for those casting numbers. The engine is original and complete, except for the fuel pump. If it's a 272, it's got some value. The 256 is practically unknown and unwanted. It wasn't even a Ford engine, it was a Merc.
I've been reading "Parting The Waters" which is a book Ralph Meloon gave all of us at the LG breakfast. It talks about Correct Craft having always been inovative and quality minded, so I don't know why their quality wouldn't have been up there with Century. The use of plywood may have been more for performace than to cut costs? I'm not a carpenter, but this Atom appears well built to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2009 at 10:37am
Bruce,
In the Interceptor manual you have, do you have the explanation of the engine codes? If not, I've got it at home. The easy spot to look for the engine number is on the front block off casting where the automotive version would have had the circulation water pump. Your manual should also indicate which cu. in. blocks had the single carb. I think it was the 256 and then the 272 came both ways with different HP ratings. I'll take a look later.
Maybe Paul Bunyan and Daniel Boone had retired from the factory by the time they made your boat!! Up front where the keel transitioned into the stem and then up the stem is where they got real crude fastening the ply bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2009 at 10:14am
Pete, I haven't seen any dumb dumb, but I'll be on the look out for it. This boat appears well made to me.
It's got a Y block which I assumed is a 135 hp 256 ci. Is it possible that it is a 272 or 292? It has one side draft carb. How can I tell what the engine is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2009 at 9:38am
Originally posted by 81nautique 81nautique wrote:
Daniel Boone worked on my boat too!
Or this guy!!
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 11:54am
The problem with this is where do you start and stop....The proper way? Complete hull side replacement!
That's exactly what I was wondering, patch job on a bright finish vs complete reskining of that side.
If I remember correctly, the auction ends today. I'm interested to see if it makes reserve and if so, what it goes for.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 11:46am
Originally posted by BuffaloBFN BuffaloBFN wrote:
Originally posted by eric lavine eric lavine wrote:
an axe is a woodworking tool
So is a chainsaw.
LOL!!!
Not sure if it was done at the factory or when the Hurricane was repowered but Daniel Boone worked on my boat too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 11:29am
So is a chainsaw.
Correct, But only if the woodworker is a skilled craftsman!!!
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 11:24am
So is a chainsaw.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 10:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 10:20am
After spending so much time in our Atom, I'm very impressed with the quality of workmanship that went into it. The fit and finish of the framing is excellent, far better than the framing on the fiberglass models.
Bruce,
Wow, your Atom must have been built in a different factory!! No offence, but my experience with other wood boats and the craftmanship in them I've got a different opinion. One thing however is I've had the oportunity to have a CC hull completely apart so I've been into one "deeper" than I believe you have. Lots of "dumb-dumb" which is a derogatory term used for fillers or putty. Screws driven through the ply competely missing frames and then left there to become a leak. Axes used on frames for engine or shift linkage clearance!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 9:58am
That boat looks far too nice to scrap. I wish it were closer. I'd be interested in it.
After spending so much time in our Atom, I'm very impressed with the quality of workmanship that went into it. It needs sides, bottom and deck, as well as some trim boats due to rot and delamination, but the framing appears good. The fit and finish of the framing is excellent, far better than the framing on the fiberglass models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 9:46am
John,
Billy's correct that there is rot and delamination involved. The rot usually starts when there is some delamination and then the water gets in there keeping the wood wet.
I'm surprised that area was missed when the bottom work was done. Maybe he gave up after doing the bottom. The hull sides being bright takes the woodwrker into a higher level of skill!! It's quite possible that the bad area might have just been a filler type patch and paint job. Billy sure can confirm that that method doesn't work. Ralphs and Walts decision to send the Dart to the CC factory for a "restoration" was a big mistake. I think the factory handed the guy who sweeps the floors a can of Marinetex, a can of paint and a brush! BTW, Marinetex is not a good product to use on wood. In fact, I question it's use on anything!!
Getting back to the repair on the Compact, the bad section of ply needs to be replaced with wood. The problem with this is where do you start and stop. The damage goes up into the bright area of the hull. A sectional patch will always be very noticeable even done by the very best woodworker. The original hull ply was scarfed making any seams as close to unnoticeable as possible. It's close to impossible to scarf joint in the middle of a piece of plywood. Then there's the other problem with patching whether it's done with butt blocking or scarfing. Any means of glueing (epoxy) will seal the edges of the patch preventing any stain from "taking" in the sealed area. The patch as well as the old ply must be pre finished to the point where any epoxy that come out of the joint can be wiped off before it cures. If the area was just below the waterline then of course the patch could be faired and the bottom repainted. Now, if there's one bad area, are there more? A hull inspection would be needed.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 3:43am
Terp, not near the "resident Wood Dr" here , he will reply also,but that don't look like damage. That appears to be "ROT", I know what I would do if my Dart had an open wound such as the Skier has.
I have a minor "delam" on the upper deck that I will pay someone else to repair and do "Correctly".
Appears they did a bottom job and assumed the rest was fine, or I am totaly wrong and a simple fix is all thats needed.The motor and running gear will bring top price, possibly being worth more in parts than running...........Boat dr
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 1:30am
Compact Skier
Pete, what do you make of the hull damage on this one? Based on what you can see, what would you do to repair that properly?
Andy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Quote  Post ReplyReply Direct Link To This Post Posted: September-12-2009 at 12:01am
My Blue 82SOLD!
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2009 at 12:24pm
Originally posted by tullfooter tullfooter wrote:
Does anyone know where this boat is being sold locally in Ohio, or who the seller is?
Steve, you haven't located that boat yet?
Did you see it is for sale on this site?     Bannana Boat
I curious as to what he thinks it's worth or what he is willing to sell it for.
I guess it's only worth what someone is willing to pay for it. Good Luck!
Steve
đź‘Ł Steve
86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: June-09-2009 at 11:24am
May help someone, also good to see how they pipe in.
351w Edelbrock Exhaust Manifolds
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2009 at 1:36pm
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2009 at 11:39am
Originally posted by TRIP TRIP wrote:
Banana George's Boat
'85 BFN
'90 BFN
White Lake, Michigan
CCxHYPERLITEx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCxHYPERLITEx Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2009 at 12:52am
Originally posted by SNobsessed SNobsessed wrote:
Here is one to keep an eye on. Too good to be true??
Martinique w/ 97 hrs
im with you thats crazy only 97hrs
TRIP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRIP Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2009 at 12:36am
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2009 at 10:24pm
the Ertl 1/64 air nautique brought $ 42 plus shipping. They were less than $4 at Walmart
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2009 at 7:07pm
I bought a bow light at Wally world for somethin like 5 bucks...rigged it up on the hood of my old truck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2009 at 10:54am
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2009 at 2:25pm
Andy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2009 at 2:52am
Waukeshaw parts
Motor mounts
Ex Manifolds
302
trans
sellers list
My Blue 82SOLD!
Ashley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ashley Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2009 at 4:06am
Beautiful boat.
Lake Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lake Horse Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2009 at 7:41pm
Reman. Holley Marine Carbs for SB 302 $250!!!!
Holley Marine Carb
Ordered one last week! Will give update when carb gets in. I saved over $300 compared to other sites.
Lake Horse
76 Mustang
Andy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2009 at 1:39am
Yes, I'm bidding on the safari hat.
? I think I just got sniped ?
