Rear tie downs |
OverMyHead
Posted: May-17-2009 at 1:55am |
How strong are the swim deck mounts? Can I use them to secure rear tie downs to?
1987 Ski Nautique |
bkhallpass
My boat is a bit newer than yours, but that's what I use. Towed it from CA to WI and back with no problem. BKH
Livin' the Dream
My boat is older than yours and I do the same, so I think your covered on both sides.
SN206
It's not a bad idea, but I have seen both newer and old boats gels damaged or spidered from doing so. In fact I think I have some pics of a 99' damaged that way.
Ryan, Are you sure the gel damage was from trailering? Could it be from just normal use? How do you tie down the aft end? Strap over the gunnels? Hopefully you do. I wouldn't go for more than a couple miles without the aft end tied to the trailer and in fact, it's the law in most states. |
OverMyHead
I have been running this way and have no concerns under normal circumstances but it is not under normal circumstances that they are needed. Maybe a big fender washer on the inside of the transom or other reinforcement would help. The mounts themselves appear plenty strong.
1987 Ski Nautique |
jrmcmich
Groupie Joined: April-12-2009 Location: United States Status: Offline Points: 61 |
my 94 sport does not have rear tie downs either. Is this normal for Nautiques? It only has a turn buckle on the bow of the boat to hold on trailer. I drove 4 hours from where I bought it with no problems though.
OverMyHead
My Bayliner had something similar to a bow eye x2 for this pupose, they realy only come into play when something goes wrong, such as piling on the brakes, collision or bouncing over a big curb( or so I am told ). I am wondering what it takes in those situations.
1987 Ski Nautique |
carnes99
Groupie Joined: February-23-2009 Location: United States Status: Offline Points: 74 |
I second pete. I know a lot of people that tie the back of the boat down using the swim step mounts and no problems. The tie down is pulling straight down on the transom which is strong. Someone standing at the edge of the swim step jumping would cause more damage due to the extra leverage.
Morfoot
Dave, I use a racheting type strap that loops around the outer swim platform brackets(where they are lagged into the boat) then around the trailer frame. I've been doing this for several years and haven't had the first problem. I can take pics later when I get home today.
Randy_in_Ohio
I had the ratcheting tie downs added to my new Boatmate trailer when I had it built. I hook them to the swim platform brackets. The only other option I could think of was to either remove the plastic covers around the lifting rings or cut a hole in the bottom of them and use the lifting rings. I think the swim brackets are plenty strong for this. Good to see others have done this without damage.
NAUTI84
Senior Member Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
1984 - We don't need no stinkin tie downs!
I've trailered a lot of miles with no problems. No Winch, No front, No Rear. (I do add a strap from bow to trailer though - scares the sh*t out of me, especially when bunks are wet. ) |
phatsat67
tie downs are for IO's ;) Nautiques are such great boats the hold themselves to the trailer. haha
OverMyHead
Im using the ratchet strap around the trailer system, Since I came up with it myself I just wanted to know if it was a good idea, Sounds like I can continue with confidence, now if only I could get it to run so I might actually pull it somewhere.
1987 Ski Nautique |
05 210
Platinum Member Joined: February-17-2006 Location: Southern Maine Status: Offline Points: 1481 |
Tie downs get hooked to the brackets on my boat also. That's where the dealer said to put them. The black cups under the lifting rings are there to keep the ehaust from coming up thru the holes in the platform.
Mike |
akabulla
Gold Member Joined: November-15-2008 Location: United States Status: Offline Points: 649 |
What if you have a removable platform? Do you just leave the platform on for towing to have a place for the straps and then take it off when storing it? Without the platform on the only thing left on the transom are some very small channel brackets.
Randy_in_Ohio
I leave the platform on all summer and take it off in the winter. I hang it in the basement during the winter and give it a coat of teak oil once and awhile. They seem to be a good place to attach the straps. |
jbear
Well...I have had 6 C/Cs and have never tied down the stern or had a winch. Towed thousands of miles..no problems so far..quess it is just a personal choice.
john |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
My old 98 had thru hull "d" shaped tie down points. We used ratchets to secure to trailer.
P.O. must have installed them. There was some minor cracking to the gel around the bolts, but this never appeared to get any worse over the 3 or so years we owned it. We never had a problem with them. I currently use ratchets from the 89's swim deck to the trailer. I would like to install similar tie downs on the 89 instead of using the platform brackets. |
OverMyHead
I think I would use 2 bow eyes if I went that direction. |
1987 Ski Nautique |
carnes99
Thanks Mike! I have been wondering why they have the black cups. |
akabulla
Chopper was there any kind of backing support on the inside of the hull for those? Like some plywood or was it just attached to the glass itself with some washers on the inside? |
Chopper
OMH, I think that's what they probably were. They were smaller than factory CC bow eye though. |
Chopper
Hey AKA, To be honest I do not recall exactly, but I'm pretty sure it had large round stainless backing plates. Kind of like a big thick washer. We didn't "crank down" the ratchet tie downs anyway. Just nipped them to reduce side to side movement. |
gn6027
Senior Member Joined: October-15-2006 Location: Ohio Status: Offline Points: 192 |
OverMyHead,
If you have the factory trailer, you should have an eye that is welded to the main 'C' channel frame of the trailer, just to the stern of the fender. (or at least that is what is on my '87's trailer) With the boat, a strap (like you'd find on a ratcheting tie-down strap) was included that hooked into each eye, wrapped over the gunwhales, and is then pulled tight to hold the back of the boat down. This is the only thing I've used, and been satisfied with it. I'd be worried about attaching tie downs to the swim platform brackets. With the trailer & boat bouncing down the road, quite a bit of stress would be applied to the brackets, and I'd hate to think of what might happen... One thing I've noticed over the years is that my boat tends to walk towards the starboard side. I leave the house with the boat centered between the guideposts, and it always seems to end up snug against the guidepost. Perhaps this is due to the natural curvature of most roads to drain water???? I can see where my strap doesn't address the side-to-side movement of the boat, and the tie downs on the swim platform brackets would, but IMO, the risk is not worth the reward. Anyway, my $0.02. |
GN6027
1987 Ski Nautique 2001 |
Glen - I tie mine down with a gunnel strap too. But I have an opposite experience: After loading, the boat is off to one side & by the time I get home it is centered. I have been told that a loose mass will always bounce toward the center of gravity. I wonder that since you are in Ohio, is your boat subject to a gravitational pull to Eric's shop? Maybe it just needs some therapy.
OverMyHead
One thing I've noticed over the years is that my boat tends to walk towards the starboard side. .[/QUOTE] So it tends to move to the right, maybe it is just a good conservative. |
1987 Ski Nautique |
larryhfrederick
Newbie Joined: May-25-2009 Location: United States Status: Offline Points: 6 |
Have had 3 196s ('97, '02, and '08) on Ramlin single axle trailers. Normally no need to tie down at all, but it's not a bad idea. Only problem I've had is taking a curve and hitting a hump in the road simultaneously, sending hull airborne then settling off center with edge of hull over wheel well. No hull contact to wheel well, but it sure looks goofy. I do tie down now just in case.
Larry Frederick
