Fuel gauge problem |
almabes
Senior Member Joined: March-20-2008 Location: Acworth GA Status: Offline Points: 263 |
Posted: June-01-2009 at 2:56pm |
She's a '76 Martinique with PCM 351W. Gauges are Teleflex, I'm relatively sure.
We went camping/boating this past week and a wierd thing happened. As I consumed fuel, the gauge went down as I would expect, until finally I got near empty. So I go over to Victoria Harbor marinia, and fill her up with gas. 14.7 gallons later the gas pump quits filling and I screw the gas cap back in then head to the pilot's seat. I turn on the ignition, expecting to see the fuel gauge point to the reassuring "F", but was alarmed when no, it was pointing at roughly 1/4 tank. Just for grins, I take the cap back off, and take a gander inside my now full gas tank, and verify I didn't just pump 14.7 gallons of liquid gold (at the price they're charging) into lake Allatoona. Annoyed, I replace the cap, start her up and head on to the cove the kids want to swim in. The gauge appears to bounce in response to the fuel sloshing around in the tank but only reads 1/4 instead of full. I intend to check connections at the gauge and sender, continuity, resistance etc. I'm thinking it's either a loose connection, or the sender has an issue. Anyone have any other suggestions? Can the sender be bounced out of calibration? How much of a PITA is it to change the sender? Thanks in advance, Anthony |
favorite computer wisdom: net helpmsg 4006
'76 Martinique PCM 351W |
Anthony,
Sure sounds like the wiper on the senders variable resistor is giving up because of the erradic gauge readings. At least you know the gauge is reading something - the Teleflex would be a expensive repair. Check to make sure you are getting the nominal 12 volts to the gas gauge. Remove the wire on the top of the tank sender and ground it to the tank. The gauge should peg at full. If it does then it's time to replace the sender. If not then it may be a ground to the tank issue. Run a jumper to the sender wire to a good ground on the engine and see if the gauge pegs. If it does now then it's a tank ground problem. A new sender isn't the worst repair but depending on the clearance to the bottom of the aft deck, the tank may need to come out to pull the sender. See if you can confirm the Teleflex ohm range needed by doing a search. Most likely it will be the 33 to 240 ohm. Universal senders in this range are common. |
almabes
Thanks Pete. It looks like you're correct the range should be 33 to 240 ohms.
I assume that the reading should be 33 ohms at full, 240 ohms at empty, correct? I think I have at least a few inches of clearance between the top tank and the rear deck. I haven't had the rear seat out in a long time so I don't really remember. It's got to have more clearance than the exhaust manifolds on the old Dodge RV. THAT was really tight. It was like someone in Auburn Hills thought "Hey we have these great cast iron exhaust manifolds, lets build a motorhome around them!", but I digress... It looks like skidim sells a Teleflex sender for <$30. Curiously, they don't sell a gauge. |
Anthony,
Yes on the 33 full (more volts) and 240 empty. If you want to try to ohm out the sender, you may have better luck with a analog ohm meter. Some of the digitals don't react quick enough - you need to be very steady on the sender arm movement with a digital. |
Donald80SN
Anthony,
I wanted to fix mine, but after doing a search on this very helpful forum I came to the conclusion that the guages and senders were not very accurate at all. I filled the tank with gas and took a wooded dow rod ( Stick) and marked the top wet line of gas with a Sharpe Pen. Then I found the half full mark and quarter tank marks with a Sharpe Pen. Now I just insert the dow into the tank to see what I have. This works well, but I too need to change my sender. My guage seems to be working in some manor. I hope this helps, Donald |
Donald, Have you done any testing to make sure it's the sender before you go to the trouble of a R&R? |
Donald80SN
Pete,
No I have not. I do have a meter and just recently became more comfortable with the use of it. I will check it out. Right now the Red Neck Stick in the tank method is doing the job. LOL Thanks Donald |
almabes
Donald,
When I took flying lessons, we'd check the level in the wing tanks on the Cessna 172, or Piper PA-28 140 with a calibrated stick. I think Cessna or Piper even supplied some of them. Hopefully, tonight I'll get a chance to work on the boat. My back is killing me after 4 nights of camping, and getting flung off a tube at who knows what speed. |
almabes
Checked the wiring and gauge last night. The gauge pegs out if i briefly short the wire attached to the tank to the top of the wire attached to the sender with ignition on. That means gauge and voltage should be ok. So I guess I need a sender, or a stick.
