  New Posts New Posts RSS Feed - V Drive Oil Question
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Topic: V Drive Oil Question
    Posted: June-18-2009 at 4:14am
I'm sure the answer is here, but since the search isn't working her it is.
93 Excel with a Walters V Drive, manual and everything I can find on PN says 30 weight non detergent oil. I was changing all fluids this last weekend and when I got to the V Drive the oil was clean, but smelled like gear oil. I opened the bottle of new oil to check it, and it doesn't have that smell, and is thinner. then I found on the side of the V Drive there is a plate that says 30w, or 80w gear oil is acceptable. Is on preferable to the other? Should I try to flush out the gear oil to replace it with 30w, or should I continue to use 80w it because it is there already?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2009 at 8:13am
i see them both in there also, if i had to pick i would stick with the gear oil, it bonds to the gears for better lube and will rise unlike the 30w to the upper gears and u-joint section
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2009 at 9:42am
Big difference between 30 and 90! You'd think that since Walters is so picky about there "special" bearings that they would be the same with their lubricant!!!!
I'd favor the 90 just as Eric mentioned it has the EP additives for the gear tooth faces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2009 at 11:04am
Thanks, guess I'm on my way back to the store to find more oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2009 at 11:29am
Pete, i see you changed that h to a p
the EP stands for extreme pressure tx, btw
