  New Posts New Posts RSS Feed - Rub Rail falling off
markb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Topic: Rub Rail falling off
    Posted: October-26-2005 at 10:22pm
Hi,
My imported '81 is starting to get to me now with all the little jobs that need doing. I am sure one day I might think it was worth it.
The rub rail is ill fitting and falling off in some places with the screws ripped out of the glass in some places.
Apart from the fitting it's not looking too bad so I am hoping to refit it and restore.
Is this feasible/worth doing? What's the best thing to fix the old holes with (gelcoat repairer?)
The other option of course is to junk the old rope one and go for a solid new rub rail.
Opinions please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2005 at 8:12am
Hey Mark, the best way to repatch hoels in fiberglass is with resin. If you lucky enough to find some "down under" then try to mix some milled fiberglass ( basicly fiberglass dust) with the resin to make a paste to fill the holes. If you can get to the back side of the hole put some tape over it so that that the resin won't run out of the hole. Do the same on the front side once you fill it so it won't run out of there either. You'll even minimize sanding too.
You could always use a machine screw with a nut and washer if you don't want to mess with a fiberglass repair.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2005 at 10:27am
You can get some auto repair resign with chopped fiberglass already in it.
Tim D
az86-2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote az86-2001 Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2005 at 11:54am
You could just drill new holes, make sure you countersink them to avoid spider cracks in the gelcoat
Jared Johnston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jared Johnston Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2005 at 12:01pm
I just took out some bondo/body filler when I did the same job on my boat. That was just to fill the holes and give my new screws something to bite into. I haven't re-installed the rub rail, but don't expect to have any issues because the bondo is nice and hard.
You can see the images of where my rubrail was before I did this at www.78skinautique.zoomshare.com
A boat is just a hole in the water to toss your money into. Here is mine! http://www.correctcraftfan.com/diaries/details.asp?ID=865&sort=&pagenum=1&yrstart=1976&yrend=1980
Post Options Post Options   Thanks (0) Thanks(0)   Quote markb Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2005 at 12:51am
Thanks guys,
Been doing a bit of reading and body filler should be good since it was originally designed for fibregla** repair.
I just took delivery of my '76 as well today so as soon as she's out of fumigation (thanks california) I'll be doing a double restore job.
The rope on this one is quite manky as well so if it won't clean up then it's job x 2.
tleed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tleed Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2005 at 9:43am
MarkB:
(I'm recycling someone else's advice here, with a couple of additional pointers.)
I think you should stick to epoxy resin, not polyester resin (like you typically find in auto parts stores for car fibergla** repair). Epoxy resin is better for marine use, mostly because it's stronger.
Get a small piece of foam and soak it in resin, then poke it into the hole(s). It will hold the resin and harden into a ma** you can drill or sink a screw into without drilling. Auto body filler won't be anywhere near as hard.
My '69 rub rail is aluminum and has several loose screws. It takes a beating against docks, and I don't think auto body filler would stand up to the wear and tear.
Thomas
82tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 82tique Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2005 at 1:09pm
off the subject but, Whenever a word like 'perfect pa**' or 'fibergla**' is typed .....it automatically censors the 'a**' ....funny.
Sorry I'm an a** and had to that point out.
I wonder what happens when I type the words t*ts, sh*t, and f**k?....OK what about sh*tzu?
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2005 at 2:21pm
Hey Tleed:
You recycled my method of patching holes. It works better than any other method I have ever tried. The secret to its success is that the foam expands on the back side of the stripped out hole thus locking itself into the hole like a rivit. the resin soaked sponge holds screws exceptionally well, BUT not quite as strong as originally.
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2005 at 7:12pm
Hi all. Been a long while since I had time to post - been travelin'. What kind of foam are you fellows talking about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: November-04-2005 at 7:44am
open cell foam rubber.
