  New Posts New Posts RSS Feed - 74 nautique impeller housing
Dan King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan King Quote  Post ReplyReply Direct Link To This Post Topic: 74 nautique impeller housing
    Posted: June-27-2009 at 4:05pm
I am trying to find a complete impeller housing for my 1974 ski nautique. The bearings are leaking. The rubber impeller is in good shape. Appreciate any help!
Daniel King
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 5:40am
Hi Dan, I have this off a 1988 351 pcm, I also have an engine mount to go with it. It has about 460 hours but needs a new impellor. It is for sale if you think it would work.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 5:44am
Oh, It is a sherwood pump.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan King Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 4:46pm
Thank you for your reply. And thanks for the pictures, that was my next request. Unfortunately it doesn't match up but thank you so much for responded.
Thanks, Dan King
Daniel King
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan King Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2009 at 4:31am
Daniel King
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2009 at 11:35am
Dan,
Are you sure you want the complete pump? If so, try: Depco Pump
If it's just leaking then it may only need the seal (bearings don't leak!!) You can go to Depco for the seal or a industrial/power transmision supply. Better check to see if it needs bearings too. They would have both the bearings and the seal. If the pump is one of the more unusual ones, rebuilding may be your only choice. Take the bearing and seal #'s with you to the supply house. They will need the numbers because they will not have the cross reference to the actual pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan King Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2009 at 6:27pm
Pete,
Thanks so much for taking the time to post the information. Bruce at Correct Craft in Indiana is sending me a seal kit. Hopefully it will be the right one. If not I will take your advice. Thanks again!
Dan King
Daniel King
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan King Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2009 at 4:54am
To: 8122pbrainard,
Sorry, I thanked the wrong person prviously. I have been talking to Depco Pump. They seem to have a Sherwood G55-2 that will work. Thank you for your input. It's so nice that people take the time to help someone in need.
Thanks again,
Dan King
Daniel King
gearhead66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gearhead66 Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2009 at 12:56am
I hate to jump in on someone elses forum question but your pump may work for me. Let me know what you want for it.
Thanx
Gearhead66
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan King Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2009 at 4:54am
To Gearhead66,
I am waiting to receive a seal kit for my pump. If it works I will keep the pump. I also have a replacement pump lined up with Depco Pump. I will be discussing this pump with georgec@depcopump.com this week. If all goes well I will order a Sherwood G55-2. I will have to drill new holes in my belt pulley. The specs match up but I won't know for sure until I do a dry fit with the new pump. I hope it works. My boat has been down for a month now. You may want to contact n3boatworks.com and talk to Bruce. He was previously with Mid-West Correct Craft. He may be able to help you. I will keep you posted.
Thanks,
Dan King
Daniel King
Post Options Post Options   Thanks (0) Thanks(0)   Quote gearhead66 Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2009 at 3:45am
Thanx Dan, I'll give it a try.
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan King Quote  Post ReplyReply Direct Link To This Post Posted: December-01-2009 at 6:13pm
Scott,
Do you still need a pump? I just sold my boat after putting in a new Sherwood pump. I kept the old one plus a new seal kit. My boat was a 74 Nautique. Let me know. Sorry it's been so long.
Dan King
Daniel King
