what has stranded you on the lake. Sick of my luck |
Bimmerboyz ![]() Newbie ![]() Joined: May-05-2009 Location: United States Status: Offline Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: June-30-2009 at 1:47am |
My luck with this Boat is killing me,
After purchase find out flywheel is missing teeth, found out on the lake. A whole season later I take off another tooth so it wont start at all. Start of this season I had everything done new Flywheel, tune up, rebuild starter. However the mechanic never mentioned I should probably rebuild the carb. The C clip on the float broke the first time I had it out on the lake. The shop I took it to told me I should rebuild the Carb. On the way home lose a wheel and destroy the axle 200 miles away from home. Took it out yesterday and it died under full throttle 40mph to 50mph. Seems like the same thing as when the C clip came loose on the float. I had enough tools to take the engine apart but I have no idea what or where the float on the carb is. I want to rebuild the carb so any link to that would be appreciated. I feel that if I rebuild it myself I will understand what to look for in case something happens on the lake. So what I would like is your stories that stranded you in the water, what you did to repair it to limp back to the marina or fix it completely to enjoy the rest of the day. Also what is a must to take on the water with you incase it breaks. C clip Spark plugs Oil gaskets Water house Etc |
Truck
2002 F350 14" lift Powerstroke 1978 Correct Craft Ski Nautique |
I guess I don't have you "luck" as I've never been stranded out on the water in all my years of boating with a mechanical problem. However, I did need to beach my 1964 X55 once. I had bought the boat knowing that the model was prone to bottom ply delamination but did inspect it and found none. Then after about 5 years of running it it sprung a major leak! Under the engine where inspection is difficult, the inner keel had rotted. This allowed the ply bottom to open up at plaining speed. I went and got the small aluminum boat, kept the engine and bilge pump in the X going and towed it home. That winter I flipped the hull and it got a new bottom and keel.
Andrew - It sounds like you have some worn parts in your carb. Maybe it is time for a new one (just make sure it is a Marine unit). I don't think it would be wise to take your carb apart while out on the water, due to the chance of raw gas being spilled in the bilge. I hope you get ahead of the maintenace curve, nothing like a tow-in to ruin your day.
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Offline Points: 3341 |
First check that the fuel pump didn't fail. Then take the bowl and inley screen off and check for red papery flakes --if you see them the fuel pump is failing and will clog anything you do to the carb.
If you don't know where the float is, then that is an indicator the carb is not DIY, change the water separator, put in a new carb and fugetaboutit. A '78 carb has just about had it anyway. Also Check the brass pivot that attaches the throttle cable to the Morse, they lik eto saw in half and wreck a perfectly fine day. |
ah, lets see, newspaper down the fuel tank, blown blade off the middle prop, re-assembled turbo that blew, lobster trap lines around the props, I'll think of some more
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Lobster trap lines? They got those out in Mendina?
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5777 |
Well I wouldn't call it stranded since we never got 100' from the ramp but a few weekends ago I chased an electrical problem for most of a saturday morning. Boat would start and just kept dying, no power. I had changed the key switch the week before and thought I had in it but as soon as we unloaded it started cutting out again. Started crimping new terminals on wiring under the dash because if I wiggled wires the power would come back on. Long story short we found it was a corroded dash fuse holder. Jumped the horn fuse holder to the ignition and ran it the rest of the weekend.
Past sunday I got back under it to replace the fuse holder and ended up replacing all six holders, every small jumper wire I could and replaced three dash switches in the process, they were all green with corrosion and the tabs broke off. Next big wave to hit was going to break something and strand me for sure. It never ends so don't get frustrated! |
Alan,
I had the exact same issue when I got the Tique. Fuse holder corrosion and the damn .250 bad female quick disconnects. They seemed to be very poor quailty and brittle. The female tabs whould break off even trying to remove them. I ended up replacing all of them. Regretably the new fuse holders had the same .250 quick connects as I would have prefered screw terminals. |
spent some time up in Maine at the lobster boat races
Yep, everything I touched lead right to another broken connector. It was really a house of cards waiting to come down on me but I think I got most of it righted. ps. Did you see my email from last week about the Hurricane motor? |
All you need is a few hours of cleaning all those little tabs! Can't seem to totally stop it from coming back however. I certainly didn't have the patience or enough wire length to replace all the female dash blades but I believe M3Fan did on "the 90" before dumping it off. I even coated them all with dielectric grease. Still better but not what I'd consider 100%. |
I know where the float is now and have read a few DIY on rebulding the carb.
Where should I buy the rebuild kit as the carb looks to be in good shape besides needing a rebuild. A full replacement is definitely not necessary. |
Truck
NAPA carries these kits, I believe. Or there is a hundred places online, if you don't need to ask which one fits . . .
davidg ![]() Grand Poobah ![]() ![]() Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
Forgot to put the safety wire on the rudder on my '87 Martinique.....and the rudder promptly dropped out. Managed to get the boat toward shore, where it promptly ran over an underwater bouy and wrapped the rope around the prop. So, water is flooding in the boat, and I am wrapped up on a buoy 50' from shore. Had to dive in and swim to shore. Did I mention it was mid April in Wisconsin? It was COLD!! That was probably my most memorable experiece. There have been a few others as well. With boats....its always something!
PS: ALWAYS REMEMBER YOUR SAFETY WIRE ON YOUR RUDDER!!! I will never forget again. |
SUNAPEE CROW ![]() Senior Member ![]() Joined: February-06-2008 Location: Methuen,MA Status: Offline Points: 110 |
As a PM manuver, it really doesn't hurt to crawl under the dash and remove / clean each terminal and spray or coat with some petroleum based product.Air is the oxidizing agent. This will slow down the oxidization process that is at the root of all these open circuit issues. My'80 has a bank of fuse holders on the dash and they are all liberally coated with white lithium grease.
I was just checking if there was a supplier of parts on this Forum. |
Truck
Next time you're over at the auto supply, get a little tube of dielectric grease. It goes a long way and is really designed for the purpose. It's a great product! |
Correct Parts (Boat Dr.) is a parts source connected to this site, they have a link on one of the pages here with a phone #. They give good advice too.
What do we like for Spark plug wires? What brand?
Truck
k.o. ![]() Senior Member ![]() ![]() Joined: January-11-2008 Location: Aruba Status: Offline Points: 363 |
hmm we had a few of those bad lucks. most carb some battery tranny.
carb i just spray some carb cleaning down the trhoat and hurry back to shore. |
