  New Posts New Posts RSS Feed - Prop suggestions
Prop suggestions
83Southwind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83Southwind Quote  Post ReplyReply Direct Link To This Post Topic: Prop suggestions
    Posted: August-27-2008 at 9:14pm
Suggestions for the best prop for a 1983 Southwind 351? On plane the quickest and cruising speed.
Thanks, wick
Wick
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2008 at 8:47am
Wick, What prop are you running now and what's the WOT RPM?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83Southwind Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2008 at 9:55pm
It has been in the water only twice in the last 5 years. The prop on it is a Federal 13x13 RH with a few dings.
I would like to purchase a new prop and send the current one to be refurbished.
I am in central Kentucky. Suggestions on where to send the Federal for re-tooling?
Thanks for the post back!
Wick
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2008 at 10:15pm
I would suggest a 13x13 Legend 3 blade...
O.J Propellers
Louden Tn.
1-800-359-9730
Ask for Sue,When you receive your new prop put the old one in the same box and ship back to Johnson Propellers to be repaired.Tell Sue what you want to do and she may give you a TwoFor One price, new prop and repair plus shipping all for one price........Boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83Southwind Quote  Post ReplyReply Direct Link To This Post Posted: August-31-2008 at 11:15am
How is the diameter of the shaft measured? Can this be done by just using a tape measure?
Wick
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: August-31-2008 at 11:25am
it should be 1 inch, same as Hollywoods
jd burton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jd burton Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2009 at 8:00pm
I have a 84 southwind , and I replaced the original prop,13x13 with a acme 1608. We ski and tube with 4 adults and 4 kids and a black lab.
Lots of weight in the boat at times. The 1608 has made all the difference in the world. With a full load in the boat ,full fuel,
and me in the water( 230lb) It will pop me out on a slalom with no hesetation. 3150 rpm at 30mph . better on fuel . Dont know WOT numbers.
I did pull a bare footer at 4300 rpm at 42mph for what its worth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2009 at 8:33pm
Originally posted by jd burton jd burton wrote:
3150 rpm at 30mph
4300 rpm at 42mph
Usually the speed vs. RPM gap grows bigger with speed, especially as you get close to WOT. It will get even larger with an increased load (skier in tow) so if that first figure is correct, then I suspect you were only pulling that barefooter 39-40 at most. You also may want to GPS the boat- the speedos may or may not be accurate!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jd burton Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2009 at 8:42pm
As far as i know the tach and spedo are original, thats 25 years old, but still work. A gps would cost more than the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jd burton Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2009 at 10:04pm
OK I just got back from the river and here are the numbers,
2400 rpm-22 mph
2600    -25
2800    -27.5
3000    -30.5
3200    -32
3400    -34
3600    -35.5
3800    -38
4000    -40.5
WOT
4600    -45
For what its worth, indicated numbers,no gps
stock 351w- acme 1608
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2009 at 12:56am
JD - I would say you have a keeper there! That's as fast as our SN.
