  New Posts New Posts RSS Feed - AT&T project Lightspeed
 Post Reply Post Reply Page    <1 34567>
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2009 at 12:18pm
One think for sure, I'm now getting plenty of attention. A phone call yesterday and then again this morning to see how the U-Verse is working. In both recent conversations, I did state is was up and running but also emphasized the drop problem and that it has been reported by techs 3 times that it needs to be changed out.
I'm getting the feeling that AT&T doesn't want any bad reports of their U-Verse service getting around.
I got a new "ticket" # from the support person but it seem to be different than the one from the other day. The new one is PL1FJT08. Is this a support # they issue? The one from the other day was F24270379. Is this the actual service ticket the techs/linemen use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2009 at 4:07pm
I just took a walk out to the pole in front of my house. This is where the underground is directly spliced into the overhead drop at the old abandoned hard box on the pole. I noticed the lineman yesterday re spliced the underground blue/white and white/blue to the overhead yellow and orange/white pair. It had been connected to the blues/whites before his visit. John, I wonder if he did the "force" test you described to me and found the other pair "better"?? Of course who knows what he found at the next pole. There, is another hard box hanging off the aerial, no cover and with a "rats nest" coming out of it!!!
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2009 at 7:08pm
Here's the scoop the way I see it.
The test I mentioned is the "stress" test. You disconnect the signal and just test the "bare" wire....starting at the NI and looking toward the feed or aerial cable. You want to test the drop first, then the aerial, each section on its own, not all connected up. You get a better stress reading on smaller "sections" or pieces of the circuit. In other words, if you look at the circuit as a whole you will not get as accurate a test.
If you lineman is just now, after all this trouble and all these reports, changing your drop pair well then I don't know what to say. Drop trouble, especially a long wire-out such as yours is the FIRST place I and I bet Gary would've looked. The Blue/Blue-white pair is always number 1.....Orange/Orange-white is always number 2. So you use blue first then switch to orange if you have trouble. But it is of course a very tempoary fix 'cause the orange pair goes the same distance under the same jacket as the blue pair. In other words, if the jacket is bad (lightning, squirrels, tree rubs, pinches), well then of course the orange pair is gonna soon be bad as well.
If I was satisfied that the drop was PERFECT then I would look at the copper wire distance. They say it will travel up to 11,000ft to sell it to you (at least in Ohio) but I never had it run that far with any reliability. To much depends on number of times the wire is spliced, cable gauge changes, humidity, plus what else is running in the binder group with your line. Also, no "bridge-tap" allowed...that is no side legs. Your cable pair can only run dircetly to your working terminal, which SHOULD be in front of your house. To make more lines avalible in more places they used to run the aerial cable all over the place...me and Gary would call those extra locations "multiples".
I know this is not much help...sure wish I could do more. Used to love this stuff. Just not in the snow and cold!
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2009 at 11:56pm
Hey what does it mean when you use say the solid blue wire and maybe the orange one with the stripe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2009 at 12:06am
Pete that ticket with the pl prefix is for the outside guy,like John or myself. I'll bet the other one is for the inside u verse tech. John, some of the new test equiptment is really something,they will tell you if you have 3rd legs and how far away.The trick is figuring out what your reading. The days of fixing a line with a butt set and snips are gone.
TDR tester
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2009 at 12:13am
How do you spell "split".
probably ok in the drop..if it ain't to (1200ft) long but a definate no-no in the cable. How do you like a hum on all your calls. We used to call guys who did that "butchers".
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2009 at 12:28am
Well you know that one time you do something wrong and someone catches you- well one guy who retired quite awhile ago was called the magical mystical meatcutter from Mchenry. You only tease the guy's you like----
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2009 at 12:50am
There will always be a spot for a guy with a butt set, a orange buzzer and some common sense.
I had a TDR...good tool if you knew what you were looking at as you said. My UG partner, the moe-man, had one of those fancy hand-held 965's with a built-in TDR feature. Slick and more user friendly than my older one.
I am always amazed by how phone guys are the same all over...so you guys called them hacks "butchers" just like we did.
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2009 at 1:35am
john
Then more than now as you know we were all family,and every family has the "crazy" uncle or aunt. We have a tentive contract as of tonight,so Pete's line might just get fixed.
Some highlights John,the most important 1st-   * Lump Sum Option protected throughout the life of the Agreement.
    * GATT rate protected through March 31, 2012, then begin transition to the PPA.
Health Care:
    * Preventative and Disease Detection paid at 100% (no co-pay or co-insurance)
    * Bi-weekly contribution: $16.15 Individual/$34.62 Family (paid on a pre-tax basis)
    * Deductible - $350 Individual/$700 Family
    * Zero Co-pays
    * Co-insurance – 90%/10% (Network) 60/40% (Out of Network)
    * Out of Pocket Maximum - $1,000/$3,000
This will be the last contract I'll ever sit thru
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2009 at 3:00am
Doesn't look to bad to me considering the economic climate right now.
Next contract me and you will watch from the sidelines while drinking cold ones!
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2009 at 2:08am
C'mon Pete...what is happening on this?
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2009 at 2:29am
john
It's a deal!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2009 at 2:35am
If they do it in March or April you will have to come down here....in the summer...I'll come visit your river.
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2009 at 9:42pm
Gary,
For now don't start cleaning off the seat in you truck for John!! I got home today and I have a new drop to the pole in front of my house plus a new plastic 12 stud terminal box on that pole where my underground is terminated. This new cable is different that the old stuff. Remember the old rectangular cable was two pair (the blues and oranges) plus it did not have the aluminum shield/bond/ground. The new stuff is 3 pair (blues, greens and oranges) plus does have the aluminum. Green bonding wires are attached to it, my underground and then to a new lug attached to the poles grounding wire going to the ground stake next to the pole. Now, I don't know how far they ran this new drop. I don't think they ran it all the way between the 6 poles to my old working terminal. I'll have to get my binoculars out and check but for now, one pole over was a aerial "hard box" (the one I said had a rats nest hanging out of it) and I think thats where they terminated the new drop. The hard box looks like they did some work on it too because no more rats nest and it even has a cover on it now!!!
Getting home today and finding the work done on the drop was a surprise but, as mentioned, I really think AT&T wants to keep their U-Verse customers happy. Time will tell to see what happens!! No blinking lights on the bottom of the portal in my house. Solid green and that's good! Blinking is when the portal and the Vrad are correcting faults. If they turn red, thats a total fault that couldn't be corrected.
Gary and John,
Do you think I should still call my manager when she gets off vacation to see what she knows or could find out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-19-2009 at 11:55pm
What I would do Pete is see how it works 1st. It's raining out nice now,lets see if it makes it thru Sunday. If it does, make the call to her and butter her up, tell her what a great job they did. If it does not make it,you know what to do. You know that old saying- you catch more flies with sugar than vinegar. Hope it works out for you,I'm still jealous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-24-2009 at 12:50am
So...how is it working?
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2009 at 9:19am
So far not one problem with the portal faulting out!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2009 at 12:52am
New shorter drop + new aerial terminal location=good service most of the time.
Wire-outs are just trouble. Sounds like they rebuilt the areial terminal 1 pole away from you and placed you a new drop to it. Hopefully good to go now. As I said...its where I would've looked first...bet Gary would have too.
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2009 at 9:09pm
Well it's been over 10 days and I haven't noticed a single blinking LED on the bottom of my portal which would be indicating it was making copper fault corrections with it's counterpart at the Vrad. So, for now, it looks like the rebuild/cleanup of my drop as well as the aerial working terminal is working! BTW, it has been moist and raining the last week so that's a "thumbs up" plus for the guys who may had done a decent careful job!! More time will tell.
Gary and John,
How common is it to bring in AT&T repair personal in from other areas? The guy who I feel finally (after the multiple reports from the other linemen/techs) again confirmed the sad old 6 pole drop to my working terminal was out of the Evanston shop. Are there "specialists" brought in from other areas or are they just sending in the good guys? (BTW, it would have been a MAJOR pleasure seeing both you guys showing up in the same truck!!!! - of course we know that wouldn't be possible!!)
Once again, I'll state that AT&T, has really bent over backwards to keep me happy with the U-Verse service. Even though it only took several calls from me to AT&T "support". My only frustration was getting the "support" person to understand what the hell I was talking about. The one who was able to pull up the 15 faults while I was on the phone with her seemed to be on top of what was going on! My being educated with the details from both of you really helped!!! She also had access to all the tech reports. A big compliment for AT&T support!! Good training and well educated personnel. - and no, I never once talked to India!!!!!!
I'm however pissed with the "sales" people who told me my lines had been "conditioned" BS!! Because of you guys, I knew the correct questions to ask the "sales" people and still got the BS from them!!. Sales people? BS!! Conditioned!! Two kids - yes, I saw them looking at my old terminal on the pole with all the rotten green studs!!! Then, installation day came and the inside tech needs to bring in a lineman to "twiddle" the old copper!!!! 6 poles worth!!!
What happened to your other co-worker Kurt (88 nautique) Kurt, your last post was back in April 09 Where are you? You were the one who convinced me to go with the fiber!! Kurt, still with AT&T?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2009 at 11:38pm
Good to hear Pete,just don't keep it rubbing it in, wish I had it. Before the end of June, due to the contract, alot of people have retired, and since then we have been running all over. For example our dispatcher used to keep an eye on us and line up work in the same town we were in if she could. She's so busy now that she can't over see what the computer dispatches us on, and it sends us out by the commitment time. So if I'm in Palatine at 9am and say there is a job due down the street by 1100, it will send me to say Island Lake for a job due by 1030. Someone in Wauconda picks up at 915, they might be the one to go to Palatine! Then if they need us in other areas because their busy or we have no work,off we go. A couple of weeks ago I was in Marengo, Gods country, and the drop wire alone was over 1700 ft long and the mosquito's almost carried me away.
88 Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-31-2009 at 3:26am
Hi Pete, J Bear & Gary,
I'm still around. Still working for AT&T. My boat is still winterized and parked in the garage. I got involved in a music project that kept me tied up all summer so I haven't had time to do any boating. I've been following your story Pete. I still get the emails from posts that I have chatted in and I'm glad you finally got your problem resolved, or so it seems. I haven't really been on the site much, but now that my music project is over, I'll be back. Looks like Keith has made some changes I'll have to get used to.
I'm jealous though. I work there and I can't even get DSL at my house, let alone U-Verse. I have to have Direct T.V. and Wild Blue satalite internet. My house looks like an F.A.A. radio site with the dishes I have mounted on it.
Anyway, I'll be back on here more. Thanks for asking about me. Hope everybody is all good.
Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 1:28am
Good to see every thing is fine Kurt. My neighbor had DSL and I went around and around with them trying to get it. They had drew an imaginary line and I was on the wrong side. Finally Randall Stephenson came out to the garage to give a pep talk to troops when he was second in command, and I asked him how many customers were losing because of this system. Don't know if it worked,but a month later I was able to get it. They then built a new house between my neighbor and me, they told him he couldn't get dsl...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 1:36am
Gary and John,
Hmmmm...drop and distance...just like I thought. Still can't believe it took your hometown guys so long...glad I could "call it" and help you out with some tips of what to ask about. Just wish I could've pulled up in front of your house with Gary. I used to get all the "go-backs" in my area. All the jobs other guys had been on and still weren't working. Until after I was there that is! I might have been slow (for sure) but I most always left 'em fixed. Gary too I bet.
Very cool to hear from you Kurt. Not very cool that your boat is still "winterized"...
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 1:45am
If you can't dazzle them with brilliance, then baffle them with BS. John it seems the new way of doing things. The new way seems to spend more time trying to get out of work than actually doing the job. Got some ot today, a 300 pr splice taken out by a county mowing crew, and not reported
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 1:56am
The "new way"...not where I worked...thats the way most of the guys always worked it. At least the guys of my generation or newer...the old guys that taught us were not that way.
"Not reported"...used to love when the gas company or the road crews would hit your cable then cover it up and say "we weren't here" and all ya hadta do was look at the ground or the pavement to see that SOMEONE was there!
Man me and you would've had fun...just like me and my partner the moe-man did.
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 2:11am
Well you've been out of the game for awhile, things seem to be changing faster. Not many of us Bell heads left John and by March '12 when the lump changes it will be the end of an era.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 2:18am
No doubt about that. Just cannot stop change...no matter if we feel it is good or bad. But I had my run..it was a good long one and I left on top, as the "lead Tech" in my area and with over a year and a half extra pay. I love talking about this stuff..like Pete's problem but I think you know I have never looked back and been one of those guys that said that I wished I had not left. There is life outside the Bell System!
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 2:26am
john
There is?   It's all we know-- You know your right,I have never known anyone who has said I wish I'd stayed,I guess you know when your done. I have to go now, it's way past my bed time
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 2:44am
Night-night..
john
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2009 at 11:27am
Sounds like things are the same throughout the old Bell system or the New AT&t. I miss the good ole days when you could go out and do a job right the first time no matter how long it would take. Then the bean counters came in and people started pushing pencils. The outside plant suffered and the the customers more so. Glad to hear you finally got back working Pete.
I am close to going green in my area and will try it when its available.
John and Gary good to hear there are still some old timers that still feel care about customer service. Glad you have a tentative contract.
We are still waiting in District 6. Gotta go to work! Monty
