PROPS FOR BAREFOOT NAUTIQUE |
QUEBEC
Senior Member Joined: August-30-2009 Location: NEW JERSEY Status: Offline Points: 216 |
Posted: September-12-2009 at 12:03pm |
HEY, ANYTHING NEW ABOUT PROPS OUT THERE FOR MY 90 BAREFOOT NAUTIQUE. WHAT WORKS AND WHAT DOESN'T?
Which engine (330hp 454?) and which tranny (BW 1:1?) do you have?
RH 3 or 4 blades work good.
QUEBEC
454 PCM 330 HP TRANS 1.1
Acme 1598
QUEBEC
HOW DOES IT WORK FOR YOU
AWESOME
QUEBEC
OUT OF THE HOLE / TOP END / WAKE TABLE / POWER BAND ????
ALL AWESOME
ejojprop
Newbie Joined: May-05-2009 Location: Loudon, TN Status: Offline Points: 24 |
OJ 13 X 14 RC 1" 4-Blade, worth a try.
Eric, you have anything in the XMP line that will work? Preferably a 3-blade?
ejojprop
No 3-blades in the XMP's. Have a 14 X 14 RC 1" 3-blade. The 13 X 14 4-blade has worked well too.
So you do have a 13x14 XMP, its just a 4-blade? How much cup does it have? The 14x14 may be a good option for Quebec, but the 79-80 BFN's (like ours) doesnt have the notch in the keel and cant fit a 14" diameter wheel. Im curious how the OJ would compare to the Acme. Im seeing about 56mph at 5200 RPM with the 1598 equivalent that Im running now (13x14, .080 cup).
ejojprop
The 13 X 14 RC 1" 4-blade is from the FORCE line, not an XMP. It can have any amount of cup, .090 is standard. Don't be afraid of the FORCE props, they are created from CNC machined patterns and then hand crafted. Hand crafted does not mean we change the propeller in the finishing process, we are just cleaning up the casting, not changing the accuracy of the part.
QUEBEC
I HAVE THE 14X14 STOCK PROP NOW ON THE BOAT RUNING ABOUT 49 MPH. JUST LOOKING FOR A GOOD PROP THAT WILL HELP THE PERFORMANCE OF THE BOAT ALL AROUND. NOT JUST IMPROVE ONE THING
ejojprop
What is the max RPM that prop will turn? Is it a Michigan Wheel?
C-Bass
Tim, in your opinion, what would happen to your performance with the 1458 vs. the 1598... the 1458 having the larger cup.
I tried the 1458 and then dinged it up (dont ask)... when Acme repaired it, I had them recup it to .080, so its essentially a 1598 now.
I think the 1598 is the way to go. It gets the revs up (~300), which should improve the performance of just about every 454. If you stroked it to 502, etc, then it may be beneficial to lower the revs in order to gain speed. Our BFN breathes better than average (56mph @ 5200 RPM with the 1598) and the overall performance is great with this prop. I cant imagine youd want anything different with a stock motor- and definitely not something steeper (more cup or pitch). |
BuffaloBFN
I'm luvin' this thread. I have some prop tinkering to do to catch up with Tim!
Amy, all I want for Christmas is... |
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
Ok Tim. My 1598 is on the way to replace the 4 blade that somebody abused at GL this year (no names mentioned right Tom). Acme agreed the 1598 should work well & up my rpms that I need.
The stock 81+ (notched keel) 330hp 454 prop would be a MW 14x14 3-blade.
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
I get the blame because someone else stops the boat in 2 foot of water and says "here you drive awhile".
BuffaloBFN
Yikes; the draft on mine is listed at 26". I found out how much BFN's hate shallow water at the river last year...also how important markers can be!
kytom2
Actually the depthguide said 4 ft of water...but it obviously lied!
QUEBEC
ABOUT 4800 RPM
C-Bass
Thanks for the input Tim. Yeah our's is bone stock, runs very well, however max RPM with the current prop is around 4300, quite a bit less than your 5000+. According to the manual though, mid 4k's is right where the max RPM should be for the stock motor. I was mainly trying to decide which one (1458 vs. 1598) would be a better fit for our setup. We use the boat for about 80% slalom, 15% cruising, 5% other.... and I didn't know which arguement to use. The 1458 would probably lower the RPM's a bit at any speed, maybe being a tad more fuel efficient. Don't know about top speed, and don't really care all that much about it. The 1598 would pull out of the hole better, get into the power range of the engine a little more at slalom speeds and make it easier to maintain speed (no perfect pass . But would cruising around be less efficient with this prop? The stock prop our BBC SN is a Fed. 13x15. I would think both of these props would definitely be light-years ahead of this (especially since our's has several nicks/dings), but I'm just trying to figure out which one to pull the trigger on. |
wakeboardin2k4
Platinum Member Joined: December-14-2006 Location: Hopatcong, NJ Status: Offline Points: 1117 |
c-bass what did you decide? And were you happy with your choice?
On a stock 454, youd be crazy not to go with the 1598. It will turn ~200 RPM more than the 13x15. The 1458 would turn about 100 less. These comparisons are based on a really dinged up 13x15 Fed, but for as bad as it was, it still pushed the boat to 53.
C-Bass
Yeah I'm extremely close to pulling the trigger on a 1598...especially with Delta's 25% off they're currently running. I just gotta clear it with the "accountant" ...
No matter what I do though, I won't have results until next spring. The boat is asleep for the winter. |
84BF454
Newbie Joined: September-09-2007 Location: Hartland, WI. Status: Offline Points: 23 |
I have a shaft for a 84 barefoot for sale!!!!
msa84bf454
