  New Posts New Posts RSS Feed - propeler
propeler
rick44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick44 Quote  Post ReplyReply Direct Link To This Post Topic: propeler
    Posted: May-05-2004 at 5:20pm
I have restored a 1974 matinique. I have had rebuilt the original 302 c.i.d. 4 barrel holly motor. I have increaded the compression, and beefed up the cam a bit. Maybe added another 50 h.p.from 220 to 275 h.p. By the way, the boat is 17' 9" and 2200lbs.   The prop on the boat is a 12" diam. 15 pitch, right hand three blade bronze prop. { most likely original } This prop. is worn and needs replacement. Should I go with the same or can I get more performance out of a different diameter and pitch? I am inclined for more speed vs. "out of hole" performance. And, what about a four blade vs. the three blade? stainless vs. bronze? Finally, best place to purchase.
Rick
rick
SS 201 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SS 201 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2004 at 8:26am
Eric Johnson at OJ propeller, 800 359 9730, he manufactures them. Buy direct, if you have problems he will live with you.
