hei distributor |
Post Reply | Page <12 |
No mine is electronic, with H-6 Crane CD ignition with a DEC 9500 Crane controller with a LX 92 Crane coil.
I thought MSD and Crane Cams where two seperate independant(sp) companies, one was founded in 1953 and is headquatered in Daytona beach and the other was founded in 1970 in new mexico If you say Crane Cams and MSD are one in the same I must be looking at the wrong web pages. And of course you are right because you always are. |
SS 201
Senior Member Joined: October-20-2003 Location: United States Status: Offline Points: 232 |
I didn't say that you did,Thats right, I knew Harvey Crane when he had a three bay station in Hallendale, Fla. Repaired our race boat there while raceing in the Marine stadium. However Crane now makes Dist they are only 1500.00 right up your alley. Byeeeeeeeeeeeee
yellowdog
Senior Member Joined: December-21-2003 Location: United States Status: Offline Points: 135 |
All right, I am totally confused!
Are MSD & Crane the same or not? From what I have seen they do not appear to be the same. SS-201, are you so miserable that you have to belittle others and play the 'my dog's bigger than yours' game with everyone. It's boring. Why don't you act like a distinguished septuagenarian instead of a bratty child? It seems you have some good information to share, but I am not sure that the cost of your tirades is worth it. You have promised to quit posting here for several reasons including the fact that you need no answers. Prove it. MODERATOR; If I have crossed the line, so be it. Dump me. I for one am tired of reading this guys brags and slams. |
Caretaker of the wife's '78 Ski Nautique
SS 201
No they are not the same company and I never said they were. Sorry If I offened you If you feel that way it was not intended as so.I'm only trying to give you the truthful answers. A question get asked and always ,always,the answer got to be debated, never wants to be accepted, always a come back. Hey your right I don't need the answers, The CC boys quit posting so will I. Go back to your Chit Chat.
You go yellowdog.
I'll quit egging him on. I just find it entertaining. He does have some good advice at times. Just wouldn't lock down the maechancal advance and distroy a good dist when all you need are new springs and weights. |
SS 201
I see, you show your true intellect, Egg this.
I could, but I think other's see and feel the way I do. I just hope when I'm as old as you I'm not as cenial(sp)
yellowdog
BC on Wawasee, hmmmm, that puts you a bit south & west of us here in Steuben, home of the 101 lakes. While there may be that many here, we prefer Sylvan. Wawasee is just a bit too far. On the other hand, I never know where we'll go next. One of the advantages of living in 'cow town' as opposed to being on one of the lakes here.
As for locking down the advance on a distributor, the only guys I knew that did it ended up regreting it. But, that kind of stuff is beyond me. For that reason, I try to stick with what it says in the book or maintain it as it came from the factory. For me, it's safer that way! I hate the looks I get from the wife when HER boat isn't ready and SHE wants to go skiing. |
I plan on keeping a spare module on board as back up for when I go down to Dale Hollow. I've got friends on my lake that will come out and tow me in if the module goes out, which I shouldn't have to worry about for a couple of years. The points style are real reliable I just don't like to adjust things that often. If you do come down to Syracuse I would do it during the week. On the week-ends with all the lakers and concrete sea walls around 3/4 of the lake it's a little rough on the classics. you need a deep-vee on the week-ends. Have you seen the new SV-211? went to indy's boat show last week and it's awsome looks like it would ride real nice on rough water.
danman
Groupie Joined: February-04-2004 Location: United States Status: Offline Points: 56 |
well not to interupt all the fighting thats
been going on under my topic of "HEI DISTRIBUTORS" -- I recieved my hei distributor Friday, and installed it, and I fired the freshly built engine (out of the boat) for the first time that evening, and it sounded goooood! I will let everyone know how it performs in the water! |
Danman did you have any clearance issue with the intake or anything else? I'm assuming that Performance Distributors installed the gear for the rev. rot or did you have to do it? Was the wiring much of a hassle. I would think that you would have to splice them so that they would reach. Wish you would have posted this a little earlier I spent about the same money for a Mallory dist. and coil and this H.E.I. would have been a much cleaner install. I have to fab a bracket to mount the coil they spec'd and it would be a lot easier extending the pos and neg leads and not having to mount a coil on the intake.
tryan
Senior Member Joined: November-12-2003 Location: United States Status: Offline Points: 345 |
from reading stuff from the chevy powered guys i have two questions mr.d:
one guy had a moroso weight/spring kit for a twin instalation. did you have to flip the weights? (standard chevy dizzys spin c.w. from what i have read.) will or did you have modify the distributor shaft for the oiling groove or the oil pump drive? |
danman
79nautique - there is no clearance issue with
the intake at all - wiring is a breeze - 12 volts and a tach wire, no ballast resistor is required. It is a simple, clean install, and you cannot build a more powerfull ignition system for what I spent on the distributor($360) tryan - the distributor is custom built for the 351W from performance distributors - the distributor turns counterclockwise (because of the gear on the end of the shaft - you can use the stock shaft, but I installed a ARP chrome moly shaft, and the oiling groove looks identical to the prestolite, actually to give you a better picture - the distributor looks the same from the base down to the very end of the gear. The weights are set up just dead oppisite as they would be for a chevrolet due to rotation of the shaft -they have me dialed in base on the specs I gave them of my boat - weight, compression, cam specs, max rpm, pump gas, and what I am doing with the boat - and they came up with 24 degrees of advance at 3000rpm. I told the folks up at performance distributors (dui) about our prestolite set-up with one light spring and one heavy spring, and they laughed like crazy. They said that is not accurate every time an engine is revved. |
Danman did you run a new tach lead back to the dash or where you able to use the neg lead from the old coil?
danman
I used the neg lead from the old coil for now,
which judgeing by looking at the dash schematic, that should work... I am trying to upload a picture I took today of the distributor, and it won't upload |
MARTINIQUE351
Newbie Joined: March-11-2004 Location: United States Status: Offline Points: 6 |
HELLO IM LOOKING FOR A PLACE TO GET CC PARTS RESONABLE.THE LOCAL DEALERS HERE IN AL DONT GIVE YOU MUCH HELP,THEY WANT YOU TO BRING IT IN AND PAY FOR THEIR HELP.I CAN DO ANYTHING TO MY BOAT MYSELF.I JUST NEED TO FIND A PARTS DIST.THAT WILL HELP ME WITH PARTS NEEDS.
THANKS LUKE |
BOUGHT MY FIRST CC LAST YEAR AND LOVE IT,76 MARTINQUE.I HAVE ADDED A PYLON,AND 1500 WATT SONY EXPLOD SYSTEM.
tryan
stop yelling. vince and richard at skidim.com will help you with your parts needs and engine advise.
AWhite70
Senior Member Joined: March-05-2004 Location: United States Status: Offline Points: 242 |
Danman, how is the HEI distributor from Performance Distributors working out? I just received mine yesterday. It looks like a nice unit. Mine was also set for 24deg. @ 3000rpm Did you go with the increased plug gap that Perf. Dist. recommends?
It'll still be a couple weeks before I get my engine back in the boat and try this thing out. |
danman
awhite- the hei distributor is working great!
I am running the factory autolite 24 plug with .055" gap, with a set of taylor spriro core wires. I have been playing around with base timing the last couple times out, I will let you know where I finally decide to leave it at. I think its doing great around 13-16 degrees btdc - |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11113 |
Hey 79 This was what you said a couple of years ago, which is different than what you're saying today so you got me confused about what you think is right, might help clarify Yaniv's problem. Interesting post I must say. Later keno |
