UKs 78 SN |
Page <12345 8> |
Roger - I think you are onto something - waterproof foam! It satifies both sides of the foam/no foam discussion (although what will we argue about next year?) You should patent this. Maybe there is a way to seal the seam using a process similar to the food-saver storage bag sealers? Maybe the foam could just be painted with bed liner or similar waterproof emulsion.
65 'cuda ![]() Platinum Member ![]() ![]() Joined: July-12-2005 Location: Cincinnati, OH Status: Offline Points: 1091 |
I love your thoughts but you will never create "waterproof" foam. The idea would be to give the water a place to go. Place 1" foam insulation board in the bottom of each cavity prior to foaming, then foam as above. Pull the foam out in its baggie. Remove the foam insulation board and replace with glassed in 1" ribs running with the slope of the hull toward the bilge. (or even corrugated fiberglass roofing) Lots of lateral drainage holes in the stringers to make sure the water gets out. If the water cannot stay in contact with the foam, I suspect the foam would never adsorb much of it.
form&function ![]() Senior Member ![]() Joined: August-21-2009 Location: OK Status: Offline Points: 342 |
Correct crafts have a large amount of foam in the upper cap that never even touches water in sinking conditions.I would be willing to bet you can take the foam out of the floor and still not sink the boat.
Of course if you think about it air is more bouyant than foam and creating a trapping system in the hull is the most effective solution. Does anybody know how they build the new boats? |
uk1979 ![]() Platinum Member ![]() Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1415 |
Thanks Chris now that's an idea to paint something over it could you treat it like wood and coat it with CPES and Epoxy that should seal it all up and now built in drainage by Gary along with Ryans's air pockets too, how about saving your plastic bottles with caps put them in with the foam so less foam to take up water no gaps between the bottles and you save on foam cost too as you use less, the collective brain is kicking in we will soon have it all worked out
Lets have a go
Or you could cap a series of tubes and fill in the blank spaces with foam.Then seal the whole package.
Kristof ![]() Grand Poobah ![]() ![]() Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3394 |
Keep the ideas coming... We might be up to something!
Revolutionize the boating industry... ![]() We had all our cheap handles and flag poles we use in the show team filled up with foam and sealed afterwards to make them buoyant... A series of these foam filled tubes (f&f's idea) isn't all that far fetched. |
Ryan tubes would do the job, maybe the flexi type that can bend back and forth so only 2 ends to block off then fill with foam in the Pvc and wrap for a sheet floor or coat for a lay up floor, looking good.
Just did the weight of the block after 24 hours in water and looks like the skin on foam is much better at stopping water soaking in now @ 193.4g think some of the gain is due to loss of the skin when I took it out the mould if you look a picture you can see. At the moment its added by 2.4g (0.084657)oz now back in the water,next weight after a week. ![]() |
Lets have a go
Epoxy is not hydroscopic.Just build some tubes out of epoxy and leave them full of air caping both ends.Then build a bracing system that holds all the tubes in the hull.You could do some tests to see how bouyant the factory foam volume is then calculate the tubing volume.
Ryan that's a good call on the old foam as you said I still have some up under the bow, will try and cut some out with the skin on to test how much it soaks up and buoyancy, as for epoxy tubes yes would work too, brings us full circle as I have the 2 epoxy ballast tanks, if I get the pluming right will work as buoyancy when not in use, as for how much buoyancy they make will need to try and work out, now you got me scratching my head.
If others know how here are some stats each Tank weight dry 35 lb Tank full of water 201 lb |
Lets have a go
The foam skinning on the inside surface of a enclosed area is one of the reasons I've mentioned foam injection over pouring several times. If you must foam and don't want to go to the extremes of some kind of auxiliary tubes, I feel a epoxy stringer job, a epoxy coating of all inside surfaces and injection will give you the best possible resistance to moisture absorption.
This is what I have found so far with my 78 SN using the numbers on a standard boat just the hull should be around 553.2 lb just unsure if the weight given in reference include platform and back seat? if not need to add back onto hull weight, feel free to add of amend would be great to get actual weight of an complete engine and drive as the one I have is off the net and my scales won't go that high.
UK's 78 SN weight lb Ref boat weight 2100 lb 350 engine and drive 1:23:1 950 lb Wood stringers Dug 136 lb Ply wood 40 lb Fiber glass stringers 241.5 lb Ballast tanks 70 lb Foam used new type 3.368 lb/3 Vortec heads complete 2 off 86.20 lb Strut 3.8 lb Prop and shaft 16.1 lb Pylon 21.3 lb Rudder & port 21.4 lb Floor seat mounts 5.6 lb Platform brackets 7 lb Front lifting ring set & pull 6.4 lb Back lifting ring set 4.6 lb Exhaust ports 3.16 lb Exhaust silencers & pipes 29.6 lb Back floor ply and tank support 26.4 lb Extract fan and pipe 1.6 lb Side pockets in ply and wood 2 off 38.4 lb Fuel separator 1.8 lb Battery 110 amp 61.2 lb Driver seat 23.6 lb Passengers seat 29.6 lb Back seat covers 13.6 lb Dog house with extinguisher 72 lb PCM 1.23.1 dry 68 lb Velvet Drive dry ish 95 lb Engine mounts 4 off Chevy 48 lb Engine mounts 4 off Ford 51.6 lb My Guess on all wire and cables 15 lb My Guess on helm, gages, throttle 21 lb Back seat frame 18.2 lb Gas Tank 20.8 lb Teak platform 18.6 lb Windscreen 34.2 lb Ski mirror 3 lb Air guides and mount panel 3.6 lb Steering wheel 14in 4.6 lb Tracking fins 2off 8.2 lb Edelbrock manifolds 2off 25.2 lb My guess on all scews,rubber bump rail,log,ally trim & fittings 32 lb Carpet 16.6 lb Standard Hull with stringers works out at 553.2 lb |
Lets have a go
98lbs on the Velvet, lol
Here are my findings on the foams.
![]() Foam with a cut face 2 wk underwater now 61.7g has 15g of water soaked in. Foam block with skin 1 wk underwater now 196.9g has 5.9g of water soaked in. Foam like pool noodles 1 wk underwater now 14.2 has 3.2g of water. Thanks Eric will update my spred sheet now back to my specific gravity tables. |
Lets have a go
As Ryan suggested have cut some original foam off the under side of the bow to see how
much it will soak up . Dry 42.7 g after the first 24 hours under water now 61.7g ![]() Some other picture for ref ![]() ![]() ![]() ![]() ![]() ![]() |
Lets have a go
Done my attempt on working out floatation on a 70s SN came up with 20 cubic feet of the foam I'm using, think it would be around the same for a Ford boat
Interesting to find how much flotation there is built in the boat, wood stringer system is worth 115.85 lb and the total for the boat without foam 219.92lb I have tried to post my excel spread sheet with no joy so put it in word still no luck! if someone know how to please let me know and will post and Easy on the red pen all you engineers out there. |
Lets have a go
I still think a correct craft will float without the floor foam.
Just need to find someone willing to sink there boat ![]() |
Air206 ![]() Grand Poobah ![]() ![]() Joined: September-28-2008 Location: Roanoke, VA Status: Offline Points: 3000 |
Someone already tried.......... but not a scientific study!!
Well I think I'm there now you just need to pick what you have on your boat to work out flotation.
![]() Easy on the red pen guys |
Lets have a go
Did these a year or so ago, may be of help to others and could help keep the average age of boats here down
![]() Sorry but sizes are mm ![]() ![]() ![]() Sizes taken off my old stringers at the wide side of each,always check your ones are the same if you use the above drawings on your project. Have Cad file if you need to print full size for template. |
Lets have a go
Update on my foam in water tests.
![]() New type foam dry 46.7g with a cut face 3 wk underwater now 66.1g has 19.4g of water soaked in. New type foam block 6x6x6in with skin dry 191g 2 wk underwater now 199.5g has 8.5g of water soaked in. Foam like pool noodles dry 11g 2 wk underwater now 15.9g has 4.9g of water soaked in. Original Foam dry 42.7g 1 wk underwater now 88.2g has 45.50g of water soaked in. |
Lets have a go
storm34 ![]() Grand Poobah ![]() ![]() Joined: November-03-2008 Location: Dexter Iowa Status: Offline Points: 4492 |
WOW! That original foam took on some serious numbers! What a cool project!
So there is no such thing as waterproof foam. Great data!
Roger, excellent source of information, more reasons to solidify the foam issue, and its one of those issues that is mandated by the powers to be but the end result is not positive. to date we have one positive reason for foam and that is flotation, but you took on the task and once again turned the issue into another negative. Foam is put in these boats to satisfy the USCG, but with extensive testing and time we can see the many negatives of the foam, you really have to sit down and reason why or why not you would want to re-foam your boat if you plan an extensive rebuild on it. the foam does provide short term flotation, but after time does it become a safety issue and possibly weigh the boat down and increase the chance of it sinking with the saturation of water and being a catylyst for rot does this create safety issues?
I think they put foam in these boats to save cost on stringer and hull materials.All they have to do is make a paper thin hull with a few pieces of wood in it and shoot the foam to it.
Thanks Chris,Chris,Eric,Ryan a few things have crossed my mind with this little test, if you look at the top of the foam block its sunk quite a bit, its been in cold water and that may of effected it ! also those of us in the cold parts of the world could the freezing of water in the new and old foam brake down the closed cells each year so in the spring the foam is ready to soak up more water?
Lets have a go
New type foam dry 46.7g with a cut face 4 wk underwater now 69.1g has 22.4g of water soaked in and is up this week. New type foam block 6x6x6in with skin dry 191g 3 wk underwater now 199.5g has 8.5g of water soaked in and no change for a week. Foam like pool noodles dry 11g 3 wk underwater now 15.9g has 4.9g of water soaked in and no change for a week. Original Foam dry 42.7g 2 wk underwater now 91.9g has 49.20g of water soaked in and is up this week. |
Lets have a go
So:
New foam cut approx 50% weight gain New foam uncut 4% gain Noodles 50% gain Original (I assume open cell) 100%+ gain I know which one I would use! Interesting thought about freezing. I wonder if freezing for an extended period would dry the foam back out - you know how old ice shrinks from solid evaporation? (or whatever the phenomena is called). Maye one of the Northwoods guys might have to set up that part of the test! Okie - got any old foam leftover? |
Thanks Chris for taking the time to work out the % and your right the old foam is open cell will keep the tests running until they all stop taking on water.
Lets have a go
davee40 ![]() Senior Member ![]() ![]() Joined: May-22-2009 Location: LAKELAND,FL Status: Offline Points: 249 |
If i may chime in her after numerous test and still many other mitagating factors left to resolve, cold ,heat ,freezing , why not just eliminate the foam ?. like Erick said the boat companys do it because its mandated by the USCG. most of have enough life vest and ski vest to keep our boats afloat.
davee40
lakeland,fl |
you also have to take into account on the mandate that it is all 22 ft and under boats no matter what type of water the boat sees, typically a ski boat has the advantage of flat water and not open ocean, the boat is for waterskiing so that means most on board should be pretty damn good swimmers. the USCG also requires flotation (life vests) on the boat, and most of the time the boats are on smaller lakes with other boats in the same area. boats are replaceble. with air tight pockets the boat will float for a few hours.....now if you were out in the middle of the ocean those few hours would make a difference..on a private lake or river help is within a half hour i would hope
Page <12345 8> |
