  New Posts New Posts RSS Feed - I’ll be learning some fiberglass repair!
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Topic: I’ll be learning some fiberglass repair!
    Posted: January-15-2006 at 6:34pm
Got off my bum today and started stripping down the boat. Pulled all the hardware, took out the interior, removed the floor and... discovered some rot in the stringers, seems to be mainly in the secondary stringers and the cross bracing, also the bottoms of the vertical ribs that hold the upolstery panels are shot looks like I'll be cutting out and replacing a fair amount. I'm hoping to probe further, I really don't want to mess with the main stringers (removing the drive train). If I need to pull the motor and replace the stringers under the mounts, what do I use as a reference to reposition the motor? Just measure off the transom?
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2006 at 9:41pm
Gary, some pics will sure be appreciated. How do you determine if you have rot in your stringers?
pmt2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pmt2234 Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2006 at 11:31am
I pulled my motor to fix the main stringers on my 84 2001. I did one at a time, and used the aluminum engine bed/frame/weldment to transfer dimensions from one to the other. I don't know if a boat like yours has one of these between the motor mounts and the stringers.
That said, I think that if you did measure off the transom, you'd be fine. You'll have to reallign the motor with the driveshaft at reinstall no matter what.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2006 at 8:18pm
I pulled the pylon and the rest of the floor this evening, both the secondary stringers are shot, the main stringer on the port side is rotted badly in the bottom third (along the hull).
I'll try to get some pics posted ...
Any advice on the best way to proceed...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2006 at 2:18pm
After thinking about this and reading up on stringer repair I'm planning this:
Pull the motor, tranny, fuel tank.
Remove the secondary stringers and all the cross bracing ourboard of the main stringers. I think that its all there just to hold up the floor. Someone please correct me if I'm wrong.
Cut the top pc of fiberglass off the main stringers and pop,pry,dig, drill the wood out leaving the fiberglass channels in place.
Mix a reinforced (chopped fiberglass)/ filled (Microsperes) epoxy and pour in the new stringers. Reglass the top of the stringers.
Reroute all the wiring, hoses, cables etc inboard of the main stringers. Install aluminum channel bracing for the seats and ski pylon. Foam everything outboard of the main stringers and glass a new floor in outbord of the main stringers. Keep portions of the center section of floor removable for service. New carpet, reinstall the interior and then get back to whats really important and figure out how to reproduce the Correct Craft emblems!
If anyone else has a similar experience please give me your insight. Is there anything obvious that I'm missing here?
Thanks
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: January-25-2006 at 9:07pm
Got some pics:
<center>
<img src="http://i38.photobucket.com/albums/e147/65cuda/DSC00864.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i38.photobucket.com/albums/e147/65cuda/DSC00863.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i38.photobucket.com/albums/e147/65cuda/DSC00862.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i38.photobucket.com/albums/e147/65cuda/DSC00861.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i38.photobucket.com/albums/e147/65cuda/65rearquarter.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i38.photobucket.com/albums/e147/65cuda/65ontrailer.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i38.photobucket.com/albums/e147/65cuda/65left.jpg" alt="Image hosting by Photobucket"><br><br>
<img src="http://i38.photobucket.com/albums/e147/65cuda/65atspeed.jpg" alt="Image hosting by Photobucket"><br><br>
</center>
Any advice would be helpful, thanks.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2006 at 7:10am
65:
IMHO, the stringers main purpose are two fold: engine/drivetrain support and hull support. The engine part is obvious, the hull support not so. What I mean by hull support is that fiberglass in inherently very flexible. Take away the stringers, and the hull will flex and twist AND the bottom of the hull will "oil can".
Now, you idea of chopped glass fill for the stringers will certainly provide a firm engine mounting, it will also be VERY stiff and the ride of the boat will end up being very harsh. In otherwords, the wood stringers allow some flexing of the hull which absorbs some of the shock when slapping the hull over waves. CC composite stringer system is designed in such a way as to mimic the limited flexibility and shock absorbing qualities of wood.
Bottom line: I would suggest that you replace the wood stringers with new Douglas Fir. Go ahead and replace any secondary stringers as well (the oil canning thing again). You might even find that you save a ton of money as the volume of resin required to fill the stringer void will not be insignificant. Good luck.
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2006 at 9:30am
To add just a little to what Dave is talking about when refering to oil canning, when you are replacing stringers it is very important to support the hull true to it's original shape. You can bow the hull out lengthwise as well as side to side and that will contribute to porposing at high speeds. That is usually only fixed by putting small trim tabs on the boat or by adding or grinding a small hook to the bottom of the boat at the transom.
I rebuilt an old MC years ago and when I got the boat the stringers were already completely removed so I had no reference points. Put it back as best I could but I had to add small aluminum trim tabs that I kept filing down until I got the boat handling right. I lost almost 2 mph top end adding them but I could not get the hull to work with out them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2006 at 4:30pm
Now that I've ripped out the interior of the boat, and commited to the repairs, I would like the results to be better than new if possible. So if I'm going to replace the stringers, and a glass filled composite will be too stiff, are there any alternatives that won't rot? What are the stringers comprised of in modern hulls? If I do put wood stringers back, white oak or mahogany would be much more resistant to rot than fir. I'm looking at this from a results vs. labor point of view. This will take relatively more time than money to do these structural repairs, In others words a few hundred additional dollars in materials will be money well spent.
I'm ready to pull the motor/tranny. Whats the easiest way. My local rental shop says a motor hoist equiped with the extended boom that would be required to reach it wouldn't safely pull that kind of weight. I'm thinking of calling a wrecker. ($$$) any better ideas?
Thanks, I'm learning alot!!
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2006 at 10:37pm
For motor pulling an A frame with casters is the way to go. The ones I have used were 10' tall aluminum with an I-beam to hang a trolly and hoist from. They were adjustable for width. Once you get the engine out you can roll it away from the boat and put it on a stand.
Bob Ed
83 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2006 at 7:45am
Another way, if you can get the boat and trailer in a garage: Support a doubled up 2x? that spans the width of the boat with 4x4 posts. Brace or anchor the 2x? to the garage ceiling. Using a chain fall or come along, hoist the engine/tranny to clear the deck of the boat and then pull the boat out from under the engine/tranny.
I suppose you could use pressure treated lumber for the stringers. However, if you go this route, i would let the lumber completey dry out before fitting/cutting. It will take several days/weeks left in the sun to dry the pressure treated lumber. I would anchor the lumber to something to help keep it straight while it dries.
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2006 at 2:05pm
I removed mine(from a 62 classic 312)with a delco engine hoist I purchased at the auto store($275.00). I did need to remove one tire and block the trailer to get a bit more clearance...it handled the engine and tranny weight with no issues.
stang
Face plants are not that funny when it's you face!
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: February-14-2006 at 4:11pm
I found a friendly wrecker owner who stopped by and pulled the motor for 30 bucks, great deal, quick and easy, and very safe.
I've decided to put the fir back in the stringers, I'm going to pretreat is with epoxy and be obsessive about sealing any penetrations.
I have another issue: flotation, the boat has none. What are your thoughts. If I ever swamped the boat, as it stands right now, the thing would sink like a stone. I did some quick measurements at the waterline and the void spaces under the floor between the stringers and If I foamed every cubic inch I don't think the thing would be bouyant. thats not even including what I will leave unfoamed for the drivetrain, stuffing boxes, exhaust, etc. If I foamed around the fuel tank and added flotation up umder the bow The thing will float even full of water.
What would be the best way to go about this?
Is it even needed? Any input would be helpful.
Thanks
Gary
