  New Posts New Posts RSS Feed - Chrysler 318 Poly Internals
dhaas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhaas Quote  Post ReplyReply Direct Link To This Post Topic: Chrysler 318 Poly Internals
    Posted: December-23-2009 at 11:56am
Thanks for reply Frank. Maybe someone could tell me if the dip stick assembly is for marine engines only or would an automotive one work also. I also would like to know the proper amount of oil to fill the 318 poly. Thanks again Dan
1965CudaSS
FrankT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankT Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 11:32am
Sorry,
I will be using this piece on my boat.
Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhaas Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 2:28am
Frank, I am in need of the dip stick assembly for the poly 318 for my 65 Barracuda. If you would like to sell it or any one else would have one let me know. Thanks Dan
1965CudaSS
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankT Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2009 at 11:54am
I have Polysphere internals, pistons, crank, camshaft, and oil pump from a 318 ā€œDā€ motor. All look to be in good condition but I do not know the dimensional specs so I can not verify if any of the parts are over sized or if the crank has been turned. If anyone has reference material I can verify what they are. As far as I can tell the ā€œDā€ motor is the 235 horse power version of the Poly incorporating high compression pistons and a more aggressive cam.
Frank
