camshaft and seals needed |
rookie ![]() Groupie ![]() ![]() Joined: July-26-2009 Location: florence,ms Status: Offline Points: 74 |
![]() ![]() ![]() ![]() ![]() Posted: January-08-2010 at 4:07pm |
I am rebuilding a 78 sn and need a right hand turn cam and multidirectional seals for the 351w...any idea who still sells that stuff? it is a chain set up and not gear driven.
thanks rookie |
do it right the first time...
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21207 |
For the cam, call Cam Research.
critter ![]() Platinum Member ![]() ![]() Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
I think the cam can be ordered from Summit or Jegs online. Or you can order one from Research Cams if you are perking up the motor.
What seals ? Most seals are available from Napa or CarQuest Auto parts stores. |
1980 Ski Nautique
1966 Barracuda |
WakeSlayer ![]() Grand Poobah ![]() ![]() Joined: March-15-2006 Location: United States Status: Offline Points: 2138 |
I believe you need to make sure you have RR crank seals. Not the automotive ones.
Mike N
1968 Mustang |
Marty helped me with the part numbers of the RR seals from CarQuest.
The important ones for RR are the Timing Chain Cover seal and the Rear main seal. Skidim # 1139 = $75.81 (Rear Main) Fel-Pro # BS-400-42 = $10.00 (Rear Main) Victor # JV614 = $ 10.00 (Rear Main) Fel-Pro # 17795 (Timing Cover Seal) = $20.00 |
1980 Ski Nautique
1966 Barracuda |
Boat dr will have them too,
1-318-299-8547 |
Mike N
1968 Mustang |
At some point, Ford switched from having directional seals and smooth cranks to universal seals and wick lines on the crank. Or is it the other way around? And what year did they switch? I think Ive read early 80's.
Either way, might want to verify which set up you have to make sure you order the right parts. |
Good point Tim...
My 80 had the wick lines on the crank. I suspect that the 78 would also have the wick lines. That would result in a smooth seal needed. The part numbers above are for smooth seals. |
1980 Ski Nautique
1966 Barracuda |
Waterdog ![]() Grand Poobah ![]() ![]() Joined: April-27-2006 Location: United States Status: Offline Points: 2020 |
Pretty sure the 1 peice r/main seal is 85 & newer. I looked all over, SECC sent me one for around $90. If anyone knows of a cheaper one, I'll take two for my other blocks.
When I bought my cam from Scott at Cam Research I also got a R/R gasket set - Not. He was great to work with let me keep the std. marine gasket kit AND sent me a windage tray for the hassel. Cam Research = Good People. |
thanks you guys are great... pat at marine engines reman. said that the the parts book called for directional seals but he did not have them. of the information offered who is a member as i would like to give my business to them first.
thanks rookie |
CorrectCraftParts...........Karen
1-318-299-8547 |
boat dr ...is that a la. prefix? if so i can drive over and get what i need.
dave |
Thats Karens # Magic Jack............Mine is 1-318-386-2825
