  New Posts New Posts RSS Feed - UK’s 78 SN
UK’s 78 SN
 Post Reply Post Reply Page    <1 23456 8>
form&function View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote form&function Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2009 at 2:36pm
There is one test I really wanted to do but not having any foam in my shop I can't.I noticed a slight curvature in the floor and the side of the boat along with cracks all along the bottom and sides where foam meets hull.Most people say its from the floor breaking away from the hull and the side flexing.I think foam expands when it takes on water in turn forcing the hull outward past its cracking point.If a person took a block of foam and covered it with resin on three sides you could emerse it in water and see if the expansion causes cracks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2009 at 4:17pm
It has long been my contention that a lot of the floor seperation and stress cracks along the seperation were caused by the wet foam freezing in the winter. I doubt that water alone would cause a significant expansion of the foam, or at least one that would apply such pressure. Wet foam can be squished relatively easily, frozen wet foam cannot. After you see if your wet foam block cracks the resin, throw it in the freezer for a bit.
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2009 at 5:34pm
Will see if I can do some of the other tests, as I found the new foam has sunk over time in cold water will measure how much, just a guess but could it be happening to some newer boats giving a soft floor ?
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Cslaten33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cslaten33 Quote  Post ReplyReply Direct Link To This Post Posted: January-03-2010 at 11:53pm
How has your project came along since the last picture posts?
Thanks Clark Slaten
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2010 at 10:29am
Not much done just back in today, I think some of this cold weather has come across it been as low as -10c here from midd Dec and no sight of it changing.
Have been trying my hand at tig welding and there is a knack, as yet I haven't got it yet.
Tried this out to bend the bronze bar for the front keel lift just stuck it in our waste wood heater for a while.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2010 at 5:37pm
Update on my foam in water tests.
New type foam dry 46.7g with a cut face 6 wk underwater now 70.3g has 23.6g of water soaked in and is up by 1.2g this 2 weeks.
New type foam block 6x6x6in with skin dry 191g 5 wk underwater now 199.9g has 8.9g of water soaked in and up by .4 for 2 weeks.
Foam like pool noodles dry 11g 5 wk underwater now 15.9g has 4.9g of water soaked in and no change for 2 weeks.
Original Foam dry 42.7g 4 wk underwater now 98.1g has 55.4g of water soaked in and is up by 6.2g this 2 weeks.
Have now put all outside to freeze for a week, then shall put the tins of water and foam on some heat bars for a few hours.
Also took the measurements of how much the foam block had sunk on the face that had been down in the water,all sides had sunk a bit but this side had sunk the most by 3/16 to 5/16, but the skin had kept its size of 6x6x6 in, will now see what freezing and heating will do.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2010 at 6:18pm
This foam stuff is very interesting, just noticed it. Nice work Roger!
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2010 at 7:31pm
Roger,
Brainiac at work LOL. Science in action...
Bremsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2010 at 5:20pm
I'm finding this experiment pretty interesting. I was wondering if you thought about a test using new foam with one cut side coated with epoxy or epoxy/glass? since the cut side is up when using foam, its covered in glass. There really isn't a cut side of the new foam directly exposed to water once installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2010 at 11:50am
Ryan,That’s a good point on the cut foam, my tests have just grown over time when working on my boat, still have my first attempt on a block of foam that I could use to cover in epoxy and test, just need this could snap to brake to get on.
Hope my little tests can help others decided what’s best for there needs.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2010 at 3:53pm
Well, that's exactly what its doing for me. I'm still leaning towards new foam for mine (much to the chagrin of other ccfan members I'm sure) so this little experiment is really giving me good information to go by. I almost dug into it this winter but have decided it can wait one more season. Glad I did, its darn cold here too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2010 at 9:12pm
Thanks Ryan good to know its been of some help, this site now has so much info for CC's it take a few winters reading to take all in.
You will soon be ready to start your boat.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2010 at 9:08am
Roger, you're quietly becoming a legend around here.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2010 at 10:24am
Roger are you trying to convince us or deny us the use of foam?, would it be pssible to build a box and foam and water it and inspect the expansion, this may solidify hull cracking
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2010 at 1:05pm
Greg no legend here the thing about this site is what you learn on it, as its been said before the older I get the more I realize how little I know,with all the great input on here and idea's, looking from a different country you are shown how its done there which is often much different, that can lead to a new train of thought and a new way forward and to learn something new.
These days it all about celebrity chef's, I think we are all chef's knowledge is our ingredients and its how we mix them to come up with great repair's/Idea's.
What a great cook book this site is.
Thanks for your post Greg the only down side is some of the great materials you guys have in the US that we don't which is a real pain.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2010 at 1:09pm
Eric, As for foam I would like it in as I hope to cross the channel here and you do have the odd semi submerged container and other things after a big storm,also do a bit of Island hopping in the med.
Just putting out what I find on the foam,so everyone can make there own mind up what best for them.
Will see what I can do for you.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-17-2010 at 5:44pm
Update on my foam in water tests and outside freezing then warming for 3 hours, water temp kept at warm only.
New type foam dry 46.7g with a cut face 6 wk + 2 wk outside in freezing weather, underwater now 70.3g has 25.8g of water soaked in and is up by 2.2g this 2 weeks.
New type foam block 6x6x6in with skin dry 191g 5 wk +2wk outside in freezing weather, underwater now 202.5g has 11.5g of water soaked in and up by 2.6 for 2 weeks.
Foam like pool noodles dry 11g 5 wk +2wk outside in freezing weather, underwater now 15.9g has 4.9g of water soaked in and no change for 2 weeks.
Original Foam dry 42.7g 4 wk +2wk underwater now 98.1g has 55.4g of water soaked in and no change for this 2 weeks,but to get the weight I had to pick out all the small edges that had broken off after freezing.
Now after freezing outside has sunk much more and skin has begun to delaminate on edges, has sunk to 1/2 to 5/8 all sides have sunk see picture.
Will now stop testing all above have now coated a new type foam block in epoxy & cloth leaving one face cut/open and will soak under water and freeze also cut some old type foam which I will do the same but coated in polyester & cloth.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: January-19-2010 at 3:13pm
Any hypothesis here? I think the old foam is going to be wasted! The foam in my floor froze really hard the beginning of January and now it is breaking up. I never saw it before that happened but am pretty sure that freezing foam and expansion are the main culprits for the broken glass I found on the stringers. http://www.correctcraftfan.com/forum/forum_posts.asp?TID=16254&title=stringer-questions-73-skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-19-2010 at 11:46pm
Thanks Keegan for your input,yes I'm sure the freezing along with the wood swelling up as it soaks up water overtime are the culprits for cracks in the stringer system.My small tests may not show much when I freeze as I think you may need a large amount to get the pressure to crack the fiberglass.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2010 at 9:04pm
Just a update on my foam test, both old and new type foam have dried out back to there dry weight give or take a gram,took around 6 weeks up on a shelf.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2010 at 9:51pm
Few things I got done,
Exhaust mounts and extra mounts for the platform.
Repaired the bow hook as mine had the nuts pulled through the glass where it had been over stressed, and only small washer used.
Then shaped the 10mm glass and bonded in with thickened epoxy
Then a layer of biaxial overlapping by an inch then another layer of 10mm glass with biaxial over lapping by an inch,finishing off with a layer of 5mm glass,then biaxial and final coat of quadraxial.
Made the new bow lifting mount out of Silicon Bronze and S/S
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 12:02am
Nice work there! It was boating weather here today. Very motivating to get cracking and finish up!
1973 Skier
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 12:11am
Looking top notch as usual!
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 2:46pm
Thanks Guys, here is the other part I made up out of S/S box,and to all the welders out there cut me some slack I'm a newbie to this tig welding thing, hats off to you guys its an art.
I have had a go at making the lift ring more stable so you can use it for holding a extended pylon.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 2:55pm
Wow now that's a tad bit of over kill there and a ton of extra weight in the nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 2:59pm
Thats some fine workmanship right there Roger- yet another innovation! Boy, I wish you were a bit closer than across the pond- Id have you fabbing up stuff for me left and right.
If your boat was anything like our BFN, the little bit of extra weight you added with that assembly should be a very small percentage of weight you took out in waterlogged foam. Many people put many times that amout of weight in stereo equipment up under the nose as well- I wouldnt give it a second thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:01pm
It is pretty though and will be around long after all of us!
1973 Skier
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:02pm
LOL ain´t that much?
roger this boat will outlast you, your son, grandson, great granson....
piece of art...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:11pm
hope that the threaded rod is grade 8 but I'm betting it's standard S/S and the weakest link too. Doesn't make much since building all the extra support just to have the threads pull out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:20pm
what kind of load or force is needed to pull all the threads out?
