FCT tower project!! |
Posted: January-20-2010 at 9:16am |
Sure looks like the platform has been moved up on the transom for some reason. Wet foam so it was under water?? To plug old holes, the inside is filled with resin and the outside filled with gelcoat. Sanded flush and buffed out. |
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13517 |
nau7iqu9
Senior Member Joined: September-07-2009 Location: Port Orange, FL Status: Offline Points: 135 |
Pete, this will probably be more descriptive
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21189 |
CC didnt always through bolt top of platform brackets- though I do agree its a good idea to do so when reinstalling. Thats assuming they enter above floor height- which they should (but it may be close!). None of the boats Ive taken apart have any plywood backers though. Depending on the thickness of the hull at that point, I may not even bother adding them. The Tique was about 1/2" thick (all glass) so I just used large fender washers. Thats all that was used on my '90 from the factory. |
Waterdog
3M makes a pin stripe eraser, it's a 1/2 X 4in. wheel you chuck in a drill. It dosen't harm the substreight under vinyl stripes on cars. Thou I haven't tried it on sealant, I think it would work. A fiberglass scraper will work. I don't want to tell you to use a putty knife but if you do be REAL CAREFUL.
Chris, Are you asking about rebuilding the hole or sealing the hole? For sealing, I wouldn't use epoxy but rather something with some flex to it like the 4200 mentioned. |
storm34
Grand Poobah Joined: November-03-2008 Location: Dexter Iowa Status: Offline Points: 4493 |
Pete, Would using epoxy be sufficient when refastening a platform bolt?
Shaun, Considering there's a combination of sealants, I'd have to say the PO tried to do a half a$$ job of sealing out water. They make not have even been leaking but the PO must have thought there was a problem. I suggest removing them completely and then refastening them with some decent sealer like 3M 4200. NO silicone!!! You can not seal a leak up by glopping stuff on the outside. Now, considering the condition of your stringers, there's a good chance that the wood behind the brackets is bad too. Pull the tank and take a look. The top fastening should be through bolted and the bottoms lagged or large sheet metal screws. |
nau7iqu9
I agree on removing the platform I'm planning on leaving it attached until most of the top and sides are sanded so I can put a little more elbow into it. I also want to polish the supports like I did my mirror brackets. It looks like theres a combination of sealants built up around mounting points any suggestions on removing them safely from the gel?
Shaun,
I suggest unscrewing the platform from the brackets and do the work on it off the boat. It will be easier and you'll be able to do all sides with the oil. Some have also had problems with getting the oil on the gel of the hull. Won't hurt it but a PITA to get off. Andy, Don't you trust your butt welding? Pipe fitters do it all day long! Actually, sleeving isn't a bad idea but I would question getting a tight enough fit for it to do ang good without plug welding each end. |
Andy
Senior Member Joined: July-27-2008 Location: M'boro, TN Status: Offline Points: 382 |
Umm maybe its just me. If someone brought me something in tube and I had to cut and splice it, I'd probably just sleeve it and not worry. A butt probably isn't the best solution, structurally. I'm just sayin'. Then you could sand it smooth and never see it.
My Blue 82SOLD!
PLBC
Gold Member Joined: January-25-2006 Location: United States Status: Offline Points: 568 |
Here is where the tower spent its first 10 years, now jumping back 20 model years from a 99 to a 79.
nau7iqu9
Thanks Guys
Sunday's progress.. Polished and repainted mirror/round 1 of many on my platform |
Donald80SN
I love the two tone on your interior.
Nice. Donald |
gn6027
Senior Member Joined: October-15-2006 Location: Ohio Status: Offline Points: 192 |
Don't confuse tubing with pipe. Tubing is traditionally thin wall, and pipe is thicker. Tube is also typically traditional in OD; 1/2", 3/4", 1", etc., where pipe is oddball in OD and comes in either schedule 40 or schedule 80.
Wall thickness on tubing probably doesn't get heavier than 1/16" or maybe 1/8". Pipe wall is typically thicker than 1/8". My tower was made from aluminum sch 40 pipe (OD = 1.900" which is 1 1/2" pipe). Your Gen 1 FCT tower might be made from tubing rather than pipe, I just don't know. If you have a set of calipers or micrometer, measure the OD. As for the alloy, I'd bet 6061. I agree with bkhallpass, I think cutting 4" or so out of the top & re-shaping the legs would probably do it. From my experience, cut off the mounting feet, and re-weld them to fit the shape of the deck of your boat perfectly. My $0.02. Glen |
GN6027
1987 Ski Nautique 2001 |
nau7iqu9
I guess why I asked about the tubing was because I'd like make the fabrication as unnoticeable as possible so i thought about possibly making a new crossbar instead of shortening and scabbing it together, just a thought probably not reality.
The 5052 may not be the greatest choice. It's forming and working is better but thats because it's yield strength and hardness is lower than the 6061. The biggest problem is you may find it's not available in many tubing sizes. It's typically used for small dia. soft tube applications |
bkhallpass
I'm not seeing why you will need to add material. Looks to me like you are going to need to cut about 4 inches our of the top bar on each side of the tow mounts, and reweld the tubes together. Perhaps a little bedin on the mounting legs. BKH
Livin' the Dream
Waterdog
6061 is a good choice how about 5052 ?
nau7iqu9
Kurt,
Thanks for hookin me up! The tower was some good motivation. I Restored my mirror last night and spent 2 hours sanding on my swim platform. We'll definitely be seeing you around this summer, lookin forward to it. |
I don't know what was used originally but I can take a good guess at it. 6061 is available in tube, would give you the weldability needed, a decent yield strength, mid range hardness and still be a alloy that can be bend without too much of a problem (with proper equipment/mandrels). It's corrosion resistance isn't as good as some others but still very good. If it was around salt water, it would need anodizing. |
Thats a pretty serious boat congrats, where are the pictures?
PLBC
99 Air, now essentially a Sport
What boat was this on Kurt? |
PLBC
Shaun,
Keep the pics coming as the project proceeds. You got a deal, I got a tower off my boat and cash, win win. See you around this summer. Kurt |
nau7iqu9
Pete,
Any idea what alloy CC used for my fct1 in case i need some tubing? |
4000 what? Gauge? Are you referring to a 4000 alloy? Just for everyone's information if someone is thinking of fabrication, a 4032 aluminum is: Medium hard, is just under the half way point of all aluminum's in yield strength, not a alloy that is recommended for welding, has fair corrosion resistance, very poor forming and workability qualities but does machine well. |
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 613 |
My tower was built by the PO it looks sharp . when I pull it out of the garage I will post pictures. It is aluminum . If you use aluminum you have to get the right gauge I think it 4000. The hardest thing is finding a shop w/ a mandrel. Muffler bender will work but very tough.
nau7iqu9
Thanks Glen, I was trying to find a 2nd gen fct, but this was a deal I couldn't pass up.
nau7iqu9
Pete,
Alan stopped by last Sunday and the stringers are solid for the time being seeing as I'll be using a tower but in order to repair the pylon and build a cradle he feels the stringers and the floor will be necessary. I'm thinking that will be next winters project. |
