BF Boom Safety |
Post Reply | Page <1234> |
Kap, an alternative would be to have an entire new clamp machined locally, using the BI as a referece. We had this done a number of years back to emulate the Casad clamp, which essentially incorporates the HA and the clamp in one piece that gives you all the adjustment you'd need.
kapla
and in what alloy should i consider it would be strong to take that load and also the rust?
Disregard the "stub" boom section, but this is basically the same clamp.
kapla
here is the link to the boom i´m looking...looks like and old model due to the tipe of cable lenght adjuster...I think newers have the square piece with allen and the cables slides through it...
boom on ebay argentina can so confirm? price is in argentine $ at $4 for a dollar that makes around 150 us dollars |
Yup, thats an older BI. $150 for that would be a very good price for it over here.
Warning, you cannot use the BI height adjuster with that boom without some extra hardware! The clamp is milled to accept the full diameter 2" boom section. It is not notched like the current booms, so the HA will be loose in the clamp. You will need to shim it to get a snug fit. You might want to get another picture, either way it is a deal.
kapla
that my thought also..but I would need to buy or fabicate the boom extension...
thinking loud...I have the BI skylon,,and it has a pin in the lower section for mounting the top section higher or lower...anyway, if I mount the clamp in the middle of the pylon.. and remove the pin in the skylon..is it an option..or not much of the skylon will mount on the pylon thus making it unsafe? you follow me? at least I´don´t use words as pole, rod , insert...LOL |
kapla
kind of a quest i´m into..I think the best would be to talk to the owner of my boom and ask him if he would take the one for sale as an exchange.........
Based on what? All of the earlier BI's Ive seen were notched like the curent ones. Kap, you either have a Skylon (made by ECI) or a Fly High (made by BI, whcich doesnt have the pin you describe). It cant be both! |
Based on the silver colored BI boom in our garage. The large section on this is also hollow, and there is no knurling or rope notch on the thinner outer section. The boom kapla posted does look like it has knurling between the cables. The large section does look like it has the full diameter all the way to the end, and the milled section in the clamp. kapla, if you have an adjustment pin you have a Skylon, I'm pretty sure that is correct from the pictures I've seen before. Do NOT bump it up at all, or flip the lower section upside down and use that height adjustment pin as the pylon "stop" for the lower section. It could bend your pylon and it'll come sliding off in use! It should be fully seated to the lower pull point through bolt (or non removable pin if you have an older Skylon). The removable height adjustment pin should be above. FYI - the bottom bolt on the lower pull ring should exactly half-way up/or down of the lower section. You need this much of the Skylon slipped over the pylon to prevent damage to the pylon, and safety. |
kapla
I mixed up..I have the ECI...so i´m positive it has the pin...
kapla
thats why I ask so I don´t damage any equipment..so if the height extension is needed thats the way to go then...
I just make my friend the question if he would take the straight boom..so I can keep the contoured one..i´ll keep my fingers crossed... |
kapla
pics on the add don´t make justice but I think HW has a point there...
Well, based on the silver BI clamp that I had, I would venture to say that the color alone isnt a definitive clue as to whether the clamp is notched or not. More investigation into that particular boom is necessary, Kap! |
kapla
I will certainly do..Tim...It seems I may know the seller so eventually I will be able to take a look to the boom before making any decisions...
about the 3/4 wrench HW suggested..is an option but those bastards tend to have a life of their own and walk away when needed lol, more when little kids are around the boat |
Come on Tim, that clamp is obviously faded out red.
I don't think I said ALL silver clamps are milled, so basically buyer beware! |
Sounds like a blanket statement to me! |
"The" as in "The" clamp that kapla posted. Obviously you haven't gotten taht eye checkup yet... :rolleyes:
Hey, I'll bet Rick the Tachyon guy could easily make these. Perhaps if enough interest he can run off a batch for CCFan at an affordable price? |
Apparently you havent gotten spellcheck yet. Doctor says Ive got 20/20. If you can see that the Kap's clamp is milled, you must be better than that! |
I think you should get a second opinion! This clamp is milled on the right. |
kapla
ha you kill me lol....
I think its bad lighting. I see a gap on the left too- I think the halves are evenly spaced the whole way. I think the end of the boom is milled on the right! If Tachyon were to make some boom clamps, I might be interested- their SDBM is one solid, nicely finished piece. |
behindpropeller
I have a friend who makes boom clamps. Nicer than anything out there. Wish I could find a pic.
Tim |
I have a picture of those at home. It is basically a copy of the ECI design quick release sliding clamp, which won't help you run a boom with an extended pylon at the same time.
behindpropeller
He could make them to fit over the ext. pylon....
Fashionably late to the party, here was our setup. Didn't even need the extra room behind the pylon.
davee40
Senior Member Joined: May-22-2009 Location: LAKELAND,FL Status: Offline Points: 249 |
what an A hole
davee40
lakeland,fl |
FrankT
Senior Member Joined: September-07-2006 Status: Offline Points: 245 |
Sportster is one of the best. Ours is a late 90's with the Monsoon engine. These are with speeds around 30. Please no jokes about the vintage banana suit. We still have it but save it for our best friends. http://www.youtube.com/user/7121Family?feature=mhw4 This is another one of my Sportster videos, local end of season ski show last year. Love the music. http://www.youtube.com/user/7121Family?feature=mhw4#p/a/u/2/0Wf4VakVGGE FrankT |
Love your banana suit, looks just like these.
That Sporster sounds awesome in the around the boat video. |
