73 Skier Restoration |
Post Reply | Page <1 23456 26> |
Author | |||
Keeganino
Good news thanks Tim! I was getting a little bit nervous there. Getting ready to take her down to my friends place and pull the motor. Then back to digging out foam. Its all happening pretty fast, but I have not started grinding yet.
1973 Skier |
Keeganino
Eric you need to get out more then! Mostly the bad joke are coming from me. |
1973 Skier |
Keeganino
Which seals are you referring to? PO said that the rear main seal needed to be replaced. My mechanic said that the worst one to deal with if it is bad would be the "rope seal". I don't know what that is or what is involved so... I told him to give me an evaluation and ball park for the work he thinks need to be done. Told him I would like to make it look show room, but if there are problems that need to be addressed first we will do the cosmetics next winter. WHen he gets that information to me I will post it here for the ccf members thoughts. I don't know much about working on engines, but want to learn and eventually do my own mechanical work. Probably more fun than grinding fiber glass for days! There is a sweet 70's CC Mustang just rotting away not a block from my house. The guy just wants it of his property. If this goes well I may be repeating the process on that boat too. |
1973 Skier |
82 Nautique 1
Senior Member Joined: January-06-2007 Location: Rock Island, IL Status: Offline Points: 265 |
Keegan,
You will be so happy to be finished grinding fiberglass (and itching) you will snap up that 70 Nautique in a heart beat. |
kapla
be carefull with the while Im at it..LOL you will end up redoing the engine..LOL I think the rope seal the mech is referring is the shaft seal were the prop shaft goes through the hull..in the worst you can simply replace the whole assy with a dripless seal for under $200...but repacking the rope ain´t a hard task..search and you´l find some threads on the subject |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21190 |
I dont think so Kap- the packing is one of the easiest things to replace! Im guessing the mechanic is referring to the rear main seal, just like Keegan said. There are a few different types- rubber, rope, etc. Ive never had to do a rope seal before, but I know some people have used them on reverse rotation engines instead of the direction-specific rubber ones with good results. I believe Reid has one in his Classic and Gary S may have on in his Mustang. |
kapla
thats why I said "I think"..LOL
but a rubber seal can replace a rope seal or it depends on how the block was casted? |
I believe even the early windsors all had rubber seals. The rotation specific wick lines were cast into the crank, so generic automotive seals can be used. It wasnt until the early 80's sometime that the switch was made to put the wick lines in the seals and not the crank... smooth cranks would require a direction specific seal.
My understanding is that the rubber seals are generally better and easier to install... but you can probably put a rope seal in if you want to. I believe its an option to consider when a rotation specific rubber seal is not available. |
I don't believe you can interchange a lip seal for a rope seal or a rope seal for a lip seal. A rope seal has to have two walls to contain it plus an O.D. to compress against simular to how an o-ring groove is machined and would be used. A lip seal only requires a bore for it to be pressed into.
only simularity is they both ride on a polished journal. |
BuffaloBFN
This site is about sharing experience so here's a little of mine...
I had 3 major decisions to make with my BFN. It needed stringers, it needed an engine rebuild, and the tranny was shot. That's what I felt needed doing to have it seaworthy. Stringers-I felt like I was in my skill set and found this site for most excellent advise. The stringers and floor came out well. Engine-I really wanted to do this myself and did. I should have a nickel for every time I've had it back apart...even with parts spread all over the dock. Wish I had a pic. Tranny-I sent it to Eric at Fantastic Finish Marine...1 price and perfect! My point is sometimes it's better to let a pro do his job. The next good 4-bolt core I find will be going to Race City Marine. |
there is a learning curve on everything you do in life, and the second time doing something is a result of learning from your mistakes the first time.
Keeganino
All good information- thanks. The rope seal he spoke of was inside the engine and not on the prop shaft. He did mention you would have to remove the crank to do that repair if needed. Like I said this guy owned the boat for a long time so he probably has a good idea what is inside. He is only dealing with the motor, and I am doing everything else. He was working on a fully restored Studabaker and a 1933 restored Pontiac when I got there. They were both beautiful cars!
1973 Skier |
Keeganino
So true! That is why I can see myself doing another CC restoration. Eric I would love to consult with you on a few things outside of the forumn. I have been reading your posts and like your realistic approach to restoring these boats. |
1973 Skier |
he's refering to the rear main seal then.
A quick google search revealed many applications where its possible to replace an original rope rear main seal with a new-tech 2-piece rubber/neoprene one. I do believe either block and/or crank machining would be required if you wanted to install a one piece seal on an engine that wasnt designed to have one. |
lip seals are a one piece seal, and yes you have to machine the block to use it in place of a two piece or rope seal.
Keeganino
Thank you for sharing your experience. That is why this site ROCKS! My boat basically just needed stringers to be seaworthy but The motor will look really old back in a clean new boat, and probably will need some maintenance work while it is out. I agree- Leave it to the pros! I want to avoid too many "while you are at it" expenses, but plan on doing a few things like replacing all the electrical wires from the dash back, and running them through conduit. Steering cable was replaced 2 years ago so that is good to go. The fuel line was original so it has got to go. |
1973 Skier |
Keeganino
IS there any reason not to use a rope seal? Is this an expensive procedure? |
1973 Skier |
no unless you want to do some machining and spend more money |
Chris, the original seal on that boat would be a 2-piece rubber seal. They should be the generic automotive (bidirectional) so theyre readily available. Why would he go with a rope seal? Theyre harder to install and just as prone to leak.
Keeganino
No sir, I just want it to work and not leak in the new bilge. |
1973 Skier |
kapla
sometimes having the engine out is good for replacing those doubtfull parts..me I got chaep and overlooked the starter..said it worked fine prior to the rebuilt so why bother..then I got stucked almost 3 weeks taking to the rebuilder and back to the boat...always found a new thing and it think work...anyway it was cheaper to rebuild than getting a new one but the time lost was fun lost!!!
just because it's a molded piece of neoprene doesn't mean it's still not a rope seal, the groove they both go in are exactly the same so use what you can get, now the better solution is using a lip seal aka one piece seal that is pressed into a bore and requires a different bearing cap and block or a machinest that knows what they are doing. Do you really thing the wick lines on the crank actually ride under the seal, take a close look and you'll find they stop right before the contact area and that holds true for lip seal as well if it has ribs they are only to help push some of the oil away from the contact area. |
WakeSlayer
You can replace all your engine and trans seals, and put a new timing chain, and a few new gaskets in it for under $100 in parts. Depending on how you value your time it is far cheaper to just do it now. If you are bartering the work for website design, you have a distinct opportunity to get it done by a professional for whatever it costs you to add a couple blingy things to his website.
Mike N
1968 Mustang |
Sounds like inconsistent terminology. Several articles (like this one from Hemmings) made the distinction between three different types of rear main seals- rope, split neoprene and one-piece. |
Keeganino
I will have top show this to my mechanic. He's going to get a kick out of all this discussion.
What would be cool is if I could go over there while he works on it and learn how to do it from a pro. I had to leave the boat there because he got slammed with customers this morning. Going to pick it up tomorrow with no engine! Since I did not have the boat I sanded the platform to get it ready to be oiled. The platform had been polyurethaned at some point and had flecks in all the cracks so I used a variety of sand papers and tools to get the little bits out of the grooves. Looks much better but I still have a ways to go, especially on the sides. |
1973 Skier |
Keeganino
Before
1973 Skier |
Keeganino
I used 80 grit to knock down the top and get the varnish off. Then a tool I bought to repair grout. It gas a triangle shaped tip, not a grout saw, but have no idea what it is called. Anyway it was great for digging the varnish out of the grooves. Then a brass brush. Have to get all the edges and insides but it looks a lot better and will look great once I oil it.
1973 Skier |
Keeganino
Since I will be using a different stringer layout than the one currently in the boat. I am thinking of removing all the secondaries and just leaving the mains for measurements. Is that a bad idea? I don't see why I would need the secondary measurements at all if I am going with a different layout. Comments, Suggestions? |
1973 Skier |
Keegan, the stringer itself appears to be the same in both boats. Its just the build up around the exhaust cavity thats different. Since the changes are minimal, it might not be a bad idea to leave it- its one more data point that you cant get back once its removed (especially if it comes out in pieces). There is an advantage to being able to grab measurements off of it for the new stringers while its still in the boat.
Then again, the really critical item is the main stringers- specifically the height and location of the motor mounts. Im sure you could get by without the secondaries in there. Your call! |
