Drive-line problems |
ehardingn
Newbie Joined: March-25-2010 Location: Alberta Status: Offline Points: 4 |
Posted: March-25-2010 at 7:01pm |
I have a 92 Ski Nautique, I replaced the transmission last year and runs great when it's cold, but when it warms up it's hard to get in gear, when you push the control forward it feels like it's in neutral and than goes into gear but wants to rev-up first. Can anyone help? Someone said it may be a cracked housing but when I pulled the trans off everything looks fine in there.
Thank You for listening to me and your help.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21186 |
It sounds like you need to adjust your control cables.
ehardingn
That's what I thought and have tried it but it didn't help, is it possible that it may have something to do with the clutch or clutch plate? The reason why I feel it could be something else, it only dose this when it worms up never when it's cold.
cracked forward drum, PCM Trans? they crack at the base and are often overlooked
ehardingn
Where would I find that forward drum? Is it in the transmission or part of the clutch assembly?
why did you replace the trans? with new? more history and yes, the forward aluminum drum inside the trans cracks typically and slips the clutches, the crack will open more under pressure so its quite often overlooked
ehardingn
Hi Eric the reason why I had the transmission rebuilt is because when I lent the boat to a friend of mine he came into the dock to fast, panicked and hit the reverse hard and broke the reverse gear, after the transmission was rebuilt I put it back into the boat and have had this problem, tried linkage adjustment but did not help.
its very possible that the forward drum cracked too, very common, and was overlooked by the experienced rebuilder. i would say dig up some paperwork and take it back to the rebuilder and have him take a closer look at the drum. did your friend come up shooting with some ponies?
btw, sorry it took so long to post, its at the bottem of the forum and i rarely go there. maybe move to a new topic to one of the other threads |
