Throttle Shaft vacuum leak |
83SN2001
Groupie Joined: September-07-2005 Status: Offline Points: 66 |
Posted: February-23-2006 at 6:25pm |
Anyone have a fix for throttle shafts sucking air besides new carb. I just rebuilt it and it is pulling air at the shafts. Other than that it runs like a champ, just a little lean.
gigem75
Senior Member Joined: November-12-2005 Location: United States Status: Offline Points: 239 |
Wrap the shaft in saran wrap tight. Clean the bore for the shaft super clean, Devcon the bore, slide the shaft in and let the Devcon set up. This will only work if the bore is worn, if the shaft is worn it will bind up. That is the southern engineering way. You could drill out the bore and put a bushing in too.
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
Ford at one time sold a kit for this.
Came with drill bit,4 bushings and reamer.but like gigem said it won't fix bad shaft. Munday |
SS-201
Senior Member Joined: October-20-2003 Location: United States Status: Offline Points: 105 |
PUT O RINGS ON THE SHAFT TOIGHT ONE.
SS 201
SS-201
OOPS TIGHT ONES
SS 201
Holley sells a throtle base plate kit for about 90 bucks at summit racing.
dantheman
Newbie Joined: February-04-2004 Location: United States Status: Offline Points: 7 |
I am pretty sure that the throttle shafts are supposed to leak a small amount of vacum around them. This is a metered vacum leak. I called Holley Technical Assistance on this before and this exactly what they told me. Who has there boat in the water right now where they could go find out if this is everyone or just me and 83SN2001?
