  New Posts New Posts RSS Feed - Foam Removal between stringers
Tag962 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tag962 Quote  Post ReplyReply Direct Link To This Post Topic: Foam Removal between stringers
    Posted: April-07-2010 at 12:04pm
Unfortunately the floor in my 1990 Ski Nautique has some soft spots. I have removed the fiberglas and the foam is very difficult to get out. Any suggestions? Thanks!
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 12:35pm
Greg,
Lots have used anything from pitch forks to trenching shovels but most find a "flat bar" to work the best. Don't forget to get us some pictures of the project!
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 1:20pm
I had great success with a flat bar. I thought about using a drywall saw and cutting out in big chunks.
I'll second Pete's motion for pictures!
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:11pm
cut the foam around the stringer with a saw, and then the flat bar or even a shuble to remove the large pieces of foam..not a nice job...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tag962 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:19pm
Here are some pics so far
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:27pm
I assume you will be replacing stringers as well?
you have a long road ahead if so..
good luck..I did the job last year and it took almost 5 months...
Eventhoug I sourced out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tag962 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 3:54pm
The stringers are only bad on the very top. I am going to shave off the bad spots & fiberglass over them. If I have to redo all of it this winter I will but im not skippin a summer.
Greg
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 4:56pm
I used an air chisel. That worked pretty good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 5:08pm
Greg,
I really don't like the idea of you having to do the job twice. Trust me, if the tops are bad there will be bad spots on the bottom as well. Try to find the time to do it correctly once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 6:44pm
I agree with pete..If you got into the point of tearing the floor like you did I don´t see why not to continue. Yes rot is there, my 1992 was in the same condition as yours, soft floor in the front area, wet foam and wood black and all wet. IMO I could have continue using it like that for sometime, but as I had to rebuilt the engine I decided to do everything at once and forget about it for the next years. If your plan was to use it in the summer best option was to leave as is and address later on the winter.
and what are your plans for the foam? you want to remove all foam from the boat or just the affected area, and then refoam?
Now if you want the boat for this summer, don´t touch anything leave it as is, glass over it and put the old carpet..At least cost will only be glass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 6:46pm
this is the wood of the stringers...
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 7:11pm
I was in the exact position you were last spring. Our 88's stringers were in bad shape on top (looked just like yours) and needed a new floor. Since it wasn't my decision, we cut the top 2" of the stringers, made a sections to replace the top and bedded it in epoxy. Then we replaced the foam, new bulkhead and put PCV piping to the airbox. It was pretty solid once we were done but there was still rot in the rest of the boat, just not as bad.
Again...this was my dad's boat and not my decision.
After doing all the work on the boat myself, I would do it again in a heartbeat BUT....I would do the whole thing. I had 3 months and a bunch of money in the job. The boat didn't get on the water till the 4th of July
I would strongly suggest you do the entire thing all at once and do it right. It will be cheaper in the end than doing it this year and the entire thing next year.
srbranum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2010 at 9:51pm
Check out my comments under "75 Skiier Stringer Replacement". I thought I did not have any problems with the main stringers either. These guys made me think otherwise. After deciding to do it all if I do any of it, I found out this week that the passenger side stringer was completely rotten to the point I do not know how the engine stayed in the boat. I am so glad I listened to this forum and replaced everything.
I have to keep her running 'cause I can't afford a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tag962 Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 12:24am
Thank you for all of the input & I know you guys are right. I just dont feel that I am qualified to do the work. Does anyone have suggestions of where I can take it in upstate NY? I have contacted Adirondack Marine but I would like to get other quotes as well. Thanks, Greg
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 9:08am
Greg,
Some have said the same that they didn't feel they had the skills to handle a stringer job. They read restringer threads here and took on the job. I haven't seen a poor or botched up job yet. You stated you were planning on shaving off the bad spots and glassing over them. That's saying you're confident with doing the glass work so you're half way there! Do some searching and reading here. I do not think you'll be happy with the costs of jobbing the work out!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 9:45am
Greg,
Pete, we have seen some poor work, but that was done by the shops not the owners!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 9:51am
Greg,
Greg,
Take note here. Chris is correct!
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 11:18am
Greg,
Can you run it this year and dig into it in the fall? By far the most difficult part is the time it takes to do it right.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tag962 Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 11:22am
I think I will patch it up so I can run it for the summer, then do it the right way over the winter! Again I appreciate all of the feedback! She is my baby & deserves to have it done the right way!!
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 12:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 12:46pm
Just make sure you start early, then you will be done for Spring for sure.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 3:16pm
Greg,
I'm one of them. Eventhough I have a different brand boat, the concepts are similar. Pete helped me through a shaft log replacement last spring and many have helped through the rebuild on this site and the Supra site I'm on. Check out my rebuild thread and you'll see the progress and all the help from others along the way.
If you feel confident you can patch it up to be strong and safe for the season, go for it. Just know you're going to cost yourself more in the long run. You'd e better off doing it right the first time, but it could stop you from going out this season. I'm going to finish minesoon, but I've been working on it since October.
jimrogers74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimrogers74 Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 6:49pm
guys, i can't help but think that if i look carefully at the stringers of my 76 i won't like what i find... even though it seems solid. the boat has hung on shorestation in summers and been in barns during the winter.
i was talking to a guy the other day who said he cuts out the stringers, digs out the wood, and fills them w/ a composite that makes it "stronger than ever for a lifetime!"
any of you heard of this approach? sounds better than wood to me.
i have a suspicion that i'm in for this same project one of these winters, and would like to make this tank even more rock solid. after 32 years, there's no use entertaining the thought of a new boat. i've had her longer than any of my kids, or wives! ya?
jimrogers74
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2010 at 7:02pm
Jim, you may want to start your own thread to discuss...
The pour in method has been discussed here before. While it sounds good in theory, I have yet to have a stringer come out of a boat as easily as your guy makes it sound. Its certainly not just a matter of "digging out the wood"! I cut all the way through the glass (on both sides) all the way down at the hull, and it still usually takes a bit of prying and coaxing to get even a rotten stringer out. Even if you could get it all out easily, I have my doubts of whether the pour in method (Seacast?) would be a good approach. If you want to go with no-wood, then do a search- a few members have rebuilt their stringers with various composite products, the most common being Coosa. JoeinNY was the first to use the material on his stout '83 2001. I am doing a Barefoot Nautique with Coosa right now (see "Another BFN Rebuild"), and I expect the structure to outlive me.
