Transmission Swap |
luckyenough ![]() Newbie ![]() Joined: January-20-2010 Location: New York Status: Offline Points: 30 |
![]() ![]() ![]() ![]() ![]() Posted: April-09-2010 at 12:50pm |
I will be removing a PCM 40 1:1 from my 1989 Sierra Supreme 21’ and replacing it with a Borg Warner Velvet Drive 71 C 10-17-004. Eric has been very helpful with advice and instructions. Has any one else done the swap? Looking for tips or tricks to make the job a little easer. Reason for the change, the prior owner had the PCM rebuilt in 05 then he hit the trailer (probably power unloading). I bought the boat with a cracked drum thinking it was the prop cavitating, my mistake. This site has been very helpful and I hope you won’t hold it against me that I own a Ski Supreme
Luchog ![]() Grand Poobah ![]() ![]() Joined: April-17-2007 Location: Argentina Status: Offline Points: 2135 |
is transmission lenght the same?
Fl Inboards ![]() Grand Poobah ![]() ![]() Joined: January-20-2008 Location: United States Status: Offline Points: 2159 |
The Borg is a different length overall then the PCM, You changing prop shafts to? I am suprised Eric suggested a Borg over a ZF Hurth. Me personally I would would stick with the PCM 1:1 you can get them reasonably inexpensive I can sell you a new one for $1,299.00 DIM has them for $1,399.00. One year warranty!! |
My boat is still in storage. Looks like the Borg Warner is 10.5" long, how long is the PCM?
I’m worried that if I get the PCM rebuilt and in a year I hit something, I’ll be right back to ware I am now. |
Not sure why you are afraid of the PCM unit, Yes when they do fail they more than likely take out the drum, however in my experiances their failure rate is no higher than that of the Borg or Hurth, Last year I replaced or rebuilt far more Hurth's and even had to Warranty a 1 hour old NEW 71-C borg.
Stay with the orginal configuration you will be happier in the long run. |
Does anyone have or know the overall length of the PCM 40 1:1?
I always get my ass in a ringer, lol, when asked what is a better transmission, my answer will always be a borg warner....hands down, if im asked will it fit in place of a PCM, my answer will be yes, it will without any other major purchases besides a drive plate, used Borg warners are always available anywhere from 50.00 bucks to 600.00 bucks,
I have access to a lathe and have used spacers in the past between the flanges, not prop savers, spacers made to within .0005, so alignment wouldnt be an issue, I also have access to new shafts that are cost effective. believe me im in the business to make a buck, but I will answer a question truthfully, and the question was such, and from my standpoint, i have changed out a few zf 45s and PCM 1:1"s with the BW's because of cost effectiveness to the customer, and in my own boat I would never consider a PCM 1:1, even though thats what it came with. now the 1.23 is a different story only because of the down angle. thats me though, may be a little biased, but the Borgs have a proven track record and the question was asked and answered that way, I know most will say Ive had that trans in my boat since 89 with no problems, but on the other side of the coin, why should the guy have to purchase a new trans, because in reality, what were saying is, its a throw away transmission and is not cost effective enough to rebuild, because of parts pricing. |
Parts pricing is truly the issue with rebuilding small 1:1 transmissions. Eric, I like you can replace new for just about the same cost as a full re-build.
Me I have customers coming from all over the south east and I do not like re-building something that I can replace with a better warranty for a few hundred more to the customer. The Front pump on the borg is it's Achiles heal just like the drum situation with the PCM and the Hurths Well yes they truly are throw away when they go bad from the start. Again I would like to think I have a great test bed for the PCM 1:1 as I have one in front of my 600HP plus 502 and regulary spin it up to 6000 Rpm. No runs, no drips, no errors. Can't say so much for the old AeroMarine throughbred V-drive as it grenaded on Christmas day. |
put a 17 inch wheel on that thing and let me know what happens on power up lol, you better be in the next county.
no really though, these boats are not recessision proof and the question was asked that he could get a BW 10-17-004 trans for 650.00 with low hours and will it fit. and the answer was yes, chances are you have to purchase a damper plate while the trans is out anyways, he is doing all the work himself and there was no financial gain to me. maybe a bit of good customer service. ??? now if he had an open checkbook.....flys onsht
Cant get a wheel that size under the boat, 9* shaft angle. Running a 11.75 X 21 four blade stainles, custom built by OJ Propeller. |
Transmission Swap step by step. I’m no expert but this is how I did mine, with lots of advise form Eric.
1) Removed starter. 2) Unbolted prop shaft (prior owner had stainless steel bolts.) 3) Loosened front motor mounts. 4) Removed rear motor mount bolts to stringers. 5) Unbolted the Elec. Box and moved it out of the way. 6) Disconnected shift linkage. 7) Unbolted the trans cooler from the bellhousing. 8) Used a scissors jack under the back of the exhaust manifold to lift engine up. I cut a 2 x 4 to fit under the “other exhaust manifold”. 9) Removed the four bolts that hold the PCM to the bellhousing. Could not get it out and around the exhaust hoses with the rear motor mounts attached. Reinstalled the trans, removed the mounts. It came out, hoses and cooler attached, no problem. (65 lbs.) 10) With the PCM and the BW on the bench I measured the overall length form the face to the output flange. The PCM is 10 5/8 long and the BW is 10 ½ long. No problem with the prop shaft (trans 1/8 shorter) 11) Removed the bellhousing (see photo). 12) Marked the holes in the flywheel that the damper plate used. Removed PCM damper plate (springs were very loose). 13) Installed the BW damper plate with new lock washers finger tight. Made sure the outside diameter of the plates were the same. 14) Drilled an access hole in the bellhousing to match the location of the damper plate bolts. (see photo, black plug behind cooler hose) 15) The BW uses 4 studs (lower) and 2 bolts (upper) to mount to the bellhousing. These need to be “manifold studs” ¾ long thread into bellhousing 7/16 -14 X 4”. I purchased grade 5 bolts 4” long cut head off and threaded ¾ on one end. I think you can buy these from Crusader Marine. 16) With blue locktite and double nuts I installed the studs into the bellhousing. 17) Reinstalled the bellhousing to the block. 18) I used the old PCM mounting bolts in the sides of the BW (where the mounts go) as handles. This is a two person (min) job 95 lbs. Placed some grease on the spline, slid the trans down the studs to the bellhousing. It took two tries to get the splines to line up, slid her home. Upper bolts & nuts and lock washers, it’s on! 19) Bolted on the motor mounts to the trans and drilled new mounting holes. The BW motor mount holes are 7/8 farther back on the side of the trans. 20) Rotated the engine off the front of the crankshaft until I could see the damper plate bolts through the access hole, tightened all three. 21) Made and installed a shifter cable bracket, adjusted the cable. 22) Had new cooler lines made to BW specs, installed. 23) Reinstalled the starter. Aligned engine/ prop shaft. 24) Tested in the driveway on the hose, no leaks and shifted fine. 25) Water tested great, put the hammer down and she pulled like a freight train from 750 rpm to over 4000 rpm. I have not had a chance to run it wide open, the prop is a Acme 541. Thanks Eric!!! ![]() |
kapla ![]() Grand Poobah ![]() ![]() Joined: March-27-2008 Location: BA, Argentina Status: Offline Points: 6148 |
This looks like a nice guide to post in nautiquechick thread..LOL
