Rear end rattle |
Dave Island
Guest |
Posted: May-23-2004 at 2:07pm |
I have arattle in the rear end. It sounds like something is loose. Has anyone had soemthing similar?
nauti girl
Groupie Joined: January-20-2004 Location: United States Status: Offline Points: 61 |
I heard a rattle last week. When the panic subsided, I checked the set screws in the shaft coupler. One was not very tight - I tightened it; the other was pretty tight, but I put another ~1/16 turn on it. The rattle went away. Also check your prop nut.
Nauti Girl
--I think my husband uses his own login now! |
cisom
Guest |
Mine has a rattle at idle speed. I understand it is the dampener plate between the flywheel and transmission and is quite common.
tommer12
Senior Member Joined: February-05-2004 Location: United States Status: Offline Points: 366 |
yup, its a damper plate. It has about 6 springs on the outside and the springs over time just rot off. It's about a $150 part from PCM and your Nautique dealer should replace it. It is 4 hours to do this because they have to pull the tranny. Sucks.. don't run with it rattling. You risk totally out your tranny then. My 84 I replaced last spring...
64 Skier
Senior Member Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
Could be the sign of a tuning problem.
Mine rattled. All new parts...engine rebuilt, new tranny and damper plate. Scared me to death! Once I tuned the engine and re-aligned...all the noise went away. |
