Muffler Wrap |
pumpdad
Newbie Joined: February-27-2008 Location: United States Status: Offline Points: 29 |
Posted: March-27-2010 at 5:46pm |
I am replacing the exhaust hoses on my 81 SN. Could any one tell me why my mufflers were wrapped in carpet and if I need to do it again? The carpet was pretty rotten and it looked like this was a bad trap for build up and didi not allow water to drain.
Thanks, Chad |
Chad Lankford
Chad,
The carpet is there as a cushion to prevent any rattling/noise from the exhaust from vibrating against a stringer/floor. It's also there to prevent the exhaust from rubbing through it shouldn't. I'd put something back in there. |
PAPA
Senior Member Joined: October-06-2009 Location: Fremont, In Status: Offline Points: 202 |
I spent the day yesterday with my son taking out the complete interior and carpet out of our 1977 Ski Nautique and found the same thing. No mufflers just steel pipe wrapped with what appeared to be original carpet. I know for noise we will have to put something back in there. Is that the best option? I guess its not too bad as it lasted 30+ years. Anybody use anything else ?
Some of us do run mufflers,but most don't,it's all a matter of personal preference. If you like the sound you had before,put it back together the same way.Most run pipe to the back,but using hose all the way may quiet it down a little.Here is one of the old threads I found.
PAPA
Gary, Sorry to throw you a curve, but by noise I meant the vibrating of the pipe against the floor. I love the sound of the boat the way it is. Any option other than carpet to put around the pipe to stop it from vibating?
SN206
rubber door mats work well.
pumpdad
Thanks for everyones input. I may try the rubber floor mat trick. It just seemed the carpet caught a lot of scum and held to much water.
Chad Lankford
SN206
If you look on the floor of most bars, you'll see some 3'x 5' perferated rubber mats that are about 3/4" or 5/8" thick. They are soft and pliable(hope I spellded dat right)and well work well if cut into smaller strips. You can find that material at some flooring stores or rest. supply stores. Then you can use the rest in your shop or in the bed of your pick-up.
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
I use a 1/2" high density foam that I picked up at my local hose and rubber supply. I cut it into 6" strips long enough to wrap around either the muffler or pipe and then attach with big daddy Zip ties. This needs to be located and spaced accordingly to the length of tube being isolated. This stuff is not cheap as I paid nearly $50 for a sheet 24"X36", Carpet reminants are far cheaper but do not finnish out as well.
pumpdad
Thanks for all the info. I found something that worked real well and is very affordable. I used 4 inch rubber pvc joiners. They have two stainless clamps per coupling. I had to cut 2 inches out of the couplings, but they still clamped tight. This will let water pass by and keep the troughs clean. I will post a picture when I complete the project. These couplings were $5.00 at my local hardware and I put two per muffler. You have to offset the clamp screw, so it will not interfere with the floor. Chad
Chad Lankford
Chad,
Like these? Fernco flex coupling: Great idea but the rubber shoulder next to the hose clamp isn't very tall. Keep a eye on them so the clamp doesn't start eating into the fiberglass. |
YooperSully
Senior Member Joined: August-07-2009 Location: Hancock,MI Status: Offline Points: 316 |
why not use the Fernco's without the clamp, or put a zip tie on em. They are only being used for cushion, correct? I don't see the need for the clamps. They are not holding two pieces of pipe together.
87' 2001
pumpdad
I believe I will put some zip ties on them. I put the clamps on and I see what you mean about rubbing the fiberglass.
Thanks, Chad |
Chad Lankford
OverMyHead
Timely suggestion for me as I am replacing exhaust hose also. Thanks. I might visit my local AX-man surplus for other options. He has a lot of foam and rubber left overs.
1987 Ski Nautique |
OverMyHead
Here is my bargain option. Went to Axman surplus, Found bright yellow 1/8 sheets of closed cell foam, 1x2 feet for .45 cents each. I cut Them down to 4" strips and packing taped them end to end to make a 4" x 36" strips. I also purchased 36" wire ties 4 for a buck. Totoal cost per muffler 1.50 with tax. Of course the yellow wont stay bright for long in the bilge. I wanted black. but at the surplus store you get what you get.
1987 Ski Nautique |
OverMyHead
My new exhaust hose should show up Friday, What is the best thing to cut it with?
1987 Ski Nautique |
A spoon?
A hacksaw works pretty good. Assuming you got wire reinforced (hopefully the corrugated) you will also need to snip the wires as you go around. |
OverMyHead
Sounds good. Yes I ordered the wire re-inforced corragated. Can I use a sawsall with a metal blade, or will it look like I chewed it with my teeth.
1987 Ski Nautique |
OverMyHead
Looking at the inside of the muffler it looks like it can be orientated to let water flow through and not stay trapped, Is there an official up to them. Nothing is marked.
1987 Ski Nautique |
I would think so- just go slow. Its pretty easy to get dragged up the hose along the wire, so pay attention and cut each one as you get to it. I usually smooth the cut surface on a bench grinder before installing.
I would say orient the mufflers so they dont hold water in the winter- mine werent marked up or down either. Front to rear became obvious as they would only install in the pockets one way- but Im not sure if theyre really directional (performance-wise). |
I wrap the hose with masking tape just for a reference to make a straight cut. I then use a regular hacksaw making the cut all the way around the hose.Don't try to cut thru it like a piece of wood,cut around it like a pipe cutter cuts pipe or tubing. You will feel when you get to the wire,go around it. When your done you can twist the hose a little and you then reach in and use a cutter or a dremel to cut the wire. My mufflers have a decal telling you which end is up. When you look inside from either end it looks like your looking into a cup. About 1/3 of the side of the cup is cut out and this faces down when mounted.
Behl
Senior Member Joined: December-05-2006 Location: United States Status: Offline Points: 404 |
I use a chop or cut-off grinder. It is like a miter saw only a thin
grinding wheel. I cut my stainless exhaust pipes as well as any type of hose. |
OverMyHead
I was thinking about trying my angle grinder but I didnt know which disc to use. I have them for metal and masonry but not a general purpose.
1987 Ski Nautique |
Dave,
Stay away from the angle grinder with the cut off blade in it. The rubber's going to bind and the grinder will want to come back to bite you!! The stuff really isn't bad to cut. Stick with the hack saw. |
athhud
Groupie Joined: November-09-2006 Location: United States Status: Offline Points: 80 |
Strap a hose clamp on at your cut line and you'll have nice straight cuts with the hacksaw!
Andrew
OverMyHead
Its nice to order stuff online, it gives me time to ask you guys how to do the job correctly. Thanks.
1987 Ski Nautique |
OverMyHead
My order showed up. I applied two hose clamps about a quarter inch on either side of the cut line as guides. I then used my Rockwell sonicrafter, Similar to fein multimaster Saw, (vibrating blade). to make the cuts through the rubber,I could not nip the wire reinforcment with any hand held nippers that I own, so I used a metal cut off wheel on my angle grinder to cut the wires and retrim them back inside the rubber wall. Each cut took under a minute this way with nice clean results.
1987 Ski Nautique |
