GT40 trans ? |
lonestar
Senior Member Joined: August-17-2008 Location: Lafayette N.J. Status: Offline Points: 290 |
Posted: April-22-2010 at 12:25am |
I have a 98 SN GT 40, the plate on the trans says pcm 40. Where the heck do I drain the fluid on this thing ? My 88 I just use a little hand pump and its done in 2 min. Any ideas. thanks
lonestar
SN206
lonestar
Thanks, the manual is informative but as far as I can see dose not let you know where the drain is.
lonestar
pump it out, or pull a line and fire the boat, at op temp
kapla
pump it out through the dipstick...use a suction gun, a turkey baster or like system to remove the oil....
no drain holes.... Its pia but once you get familiar on the optimal tool to use, you do it in 5 minutes... |
lonestar
Ya, Im going to pump it out I guess. I have a sweet little hand pump, however to get to the traans fluid you need a hose that is almost as small in diameter as the dipstick. There is no way a turkey baster or the like could work unless I rig up some really small diameter hose to it I guess.
lonestar
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1779 |
1/4" black DOT airline fits in the hole nicely. automotive stores usually have it. i then had to retrofit it to my pump with the forever useful "black tape".
lewy2001
this is what I used to change my tranny fluid.
Lewy, is that from your John Holmes super sucker kit?
