Dash Panel |
YooperSully ![]() Senior Member ![]() ![]() Joined: August-07-2009 Location: Hancock,MI Status: Offline Points: 316 |
![]() ![]() ![]() ![]() ![]() Posted: April-26-2010 at 11:02am |
I see that a few people have remade the plastic piece on the dash that the indicator lights go into. I was wondering if any of you have a CAD file for it? I'd like to bring it to a local shop and get one of these made out of billet on their CNC machine.
87' 2001
OverMyHead ![]() Grand Poobah ![]() ![]() Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
Roger, I cannot offer much help, but would like to replace mine on an 87. Maybe a volume discount.
1987 Ski Nautique |
Roger, Maybe you should have the machine shop start with some heavier gauge sheet rather than a billet. Then they won't need to machine so much and you won't need to deal with the machining marks left on the face. Definition of a "billet": A section of metal used for rolling into bars, rods and sections." Some nice 8 gauge (.128") would be stiff enough and still give you room for the lettering. You could even get it with a pre "brushed" finish. The aftermarket world started to use the term "billet" when they started to CNC machine complicated heavy parts from solid blocks rather than having them cast first. A good analogy in carpentry terms would be you starting with a 4x4 to make 1/4" dividers for a kitchen drawer. |
lewy2001 ![]() Grand Poobah ![]() ![]() Joined: March-19-2008 Location: NSW Australia Status: Offline Points: 2234 |
I downloaded the file from 2001.com I think. It is a *.ai (Adobe Illustrator) file. I also have it as a PDF that I can email to you. It prints out the correct size (you need a plotter or A2 capable printer) then you can use it as a template to make the switch panel.
I made mine out of 4.5mm polycarbonate. ![]() |
Bremsen ![]() Senior Member ![]() Joined: June-26-2005 Location: United States Status: Offline Points: 171 |
Yooper, I (well, my brother and I) created the original file that lewy is referring to. I have it in pdf and ai. I'll have to find it though, been a while since I used it (if lewy has the pdf, he can just email it). I prefer the pdf since it cannot be modified. I only ask that its for personal use only and not for commercial use (ie, don't make a bunch and start selling for a profit). I took the file to a local acrylic shop and had it made out of 3/16 black plex. They had no problem using the pdf file.
Swatkinz ![]() Platinum Member ![]() ![]() Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
Yooper, I was told at the White Lake Gathering this weekend that White Lake Marine currently had the replacement panels for the 88SN. Not sure if the same panels were used b/w 87 and 88, but thought I'd throw it out there anyway. Maybe they're the same. If not, maybe WL has them for the 87 too?
Steve
They have the 88 dash but not the 87. It is the same. Shape but has a different layout.
1987 Ski Nautique |
Nice to come back from work and see good news on this issue.
87' 2001
Roger, Dont feel any obligation to say yes to me. I was just hoping to luck into an inexpensive dash replacement without re-inventing the wheel myself. If Ryan ok'd making a few of these I would say take yours for free and let the cost be split over the remainders. I would also like the stereo cut out so I could get my glove box back. My boat spent time uncovered in the arizona sun and needs some dash help. On the bright side it was not wood grain. Lots of us are looking for the same things on these older boats. My feelings are help if you want and say no if you dont. If I start with nothing, and gain nothing, what have I lost? NOTHING.
1987 Ski Nautique |
Yooper, please don't take it the wrong way. If you have a few guys go in together to make a handful and distribute the cost across 4-5, I don't have a problem with that either. I just don't want someone using my file to go into production (like the decals, labels, etc on here).
The good thing about the *.ai file is that you can custom make it to your specs. I left the breaker side mostly original (except changing ACC 1 to 'Stereo') and as you can see in the picture, re-configured the other side to fit the remote, ignition, etc. ![]() *note, pic was my first dash which the company screwed up and made it out of 1/8 and not 3/8 (hence the wavy look). |
Sounds good Bremsen, thanks. When you can, will you email me the file? rogeresullivan@yahoo.com
87' 2001
Jtonor1 ![]() Groupie ![]() Joined: December-01-2006 Location: New Orleans, LA Status: Offline Points: 65 |
sent you an e-mail with a few files of a panel I drew up last year I tried to get keith to put them up in the reference section but no luck. I cut my panel out on a laser cutter and it turned out really nice till I tried to squeeze the radio in a cracked it so I'm going to make another, this time i think I'm going to use teak.
Thanks, Lou
87' 2001
Roger,
I'll have to locate the file. Had a HD crash since I used it so I'll have to so some searching through my backup. Should have it to you by the end of the weekend if thats OK. -Ryan |
