Engine weight |
WhiteLakeSkier
Senior Member Joined: July-03-2009 Location: White Lake, NY Status: Offline Points: 197 |
Posted: April-29-2010 at 1:45am |
Anyone know how much the 302 engine and tranny weigh? Might be a little more obscure, but anyone have a weight on an older 502 with a tranny?
bzirk
Newbie Joined: February-24-2010 Location: Florida Keys Status: Offline Points: 19 |
The 302 as it sits with tranny, cast exhaust, and alum head is 600 - 650 pounds, the 502 would be 750 - 800 pounds.
WhiteLakeSkier
Thank you!
Those weights are way off. A PCM 302 weighs in at 780 lbs, the 454 weighs 1095 lbs. I do not believe that would include the weight of the transmission. All things equal, I would expect the 502 to weigh a few pounds more than the 454, as it has a slightly taller block. All of this info is in the reference section of this site- you should check it out sometime.
