  New Posts New Posts RSS Feed - Cleat Screw Removal
Cleat Screw Removal
MAN - GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAN - GA Quote  Post ReplyReply Direct Link To This Post Topic: Cleat Screw Removal
    Posted: May-10-2010 at 8:49pm
1975 Mustang - trying to get my cleats removed on each corner to polish them up - one of the last things I have been wanting to do to really make it all shine - problem is the screws turn free both right and left? Best thought I have is there is some kind of "lag shield" in there that the screws are in tight, but has broke loose with the reverse splines and is just spinning - I have tried pulling up under pressure to get the screws to bite backing out and nothing seems to work - DOES anyone have any experience with this or can tell me what the heck is holding these screws in - all cleats are good and tight and all 16ea screws just turn
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2010 at 8:56pm
Do they have nuts on the back side? I ran into this problem with my Supra. I would think most of the manufacturers used nuts and bolts if mine did.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2010 at 10:00pm
They are bolts and nuts - not screws............ al least they are on my 78 Ski Tique.......... Get up under there.... not much space but you can get 'em.......
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 1:33am
And if they have never been changed, there is a good chance that they are "Robertson Head machine screws"   (small square)
AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote MAN - GA Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 11:02am
I guess I will have to slide myself up in there and take down the foam that is straped to the underside of bow I felt around already, but guess I wasn't far enough up there
THANKS for the input
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 1:40pm
technically they are machine screws, bolts have hex heads or they are carrage style bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 1:43pm
all that you need to do is get some eagle one never dull and polish them on the boat, if you remove them, I bet your going to using a buffing wheel on a grinder stand and buff all of the chrome off like others have done not what you want to be doing unless your rechroming them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 2:13pm
Chris you're correct on this one but I'm sure Steve was making the point that they aren't wood or sheet metal screws.
Steve,
It can get confusing! What Chris didn't work you over on and didn't mention is you can also call some threaded fasteners "cap" screws!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 2:24pm
Steve,
CLOSE but that is always proceeded by socket head, button head, countersink head FYI
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 11:32pm
Cool....Thanks, Chris! Great to Know! Hope that helps, Mark........
Welcome to the site. Occasionally, you will need to sift through the replies.....(usually typos - sometimes more)......... but the info is great and will help you keep your Mustang fabulous....
Take a break and come down to the Masters this Memorial Day Weekend. Several CCFan Members will be down there, Come say "Howdy"......
