  New Posts New Posts RSS Feed - Carpet adhesive?
Carpet adhesive?
Wacko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wacko Quote  Post ReplyReply Direct Link To This Post Topic: Carpet adhesive?
    Posted: May-10-2010 at 9:02pm
Hey folks,
The previous owner of the boat recently replaced the carpet but it is falling down on the passengers side where it runs up the wall. Just wondering what the best thing to use to re-attach it would be??
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2010 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wacko Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2010 at 11:52pm
Thank you
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 1:29am
I know this isn't officially correct, but after doing my floor with the trowel on stuff where I found out that if you use too much it come sthrough the carpet, I used 3M spray adhesive on the vertical parts. It is still going strong 4 years later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 8:44am
Just make sure the proper knotch size trowel is used per the instructions and you won't get to much.
Okie Boarder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 1:56pm
I used the 3M adhesive, myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 2:28pm
If you have a roller, it really helps stick it down good. I use a small one that I had for sound insulation in vehicles on the small pieces, and borowed the large on from the kitchen foor the larger areas.   3M Super 77 is almost as useful as duct tape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 4:22pm
So what's wrong with the Super 77? Isn't that used in a lot of applications for carpet including sub boxes and marine carpet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 4:42pm
Super 77 or any contact adhesive can work acceptably depending on the carpet backing, if the backing isnt relatively smooth you wont get a lot of surface area to your bond. It works differently than the 263 which should give you more time to reposition and then will form a pretty serious bond to the carpet regardless of backing texture if used properly. Don't use the henry 663 currently found at lowes it is never fully water proof, and gas fumes will eat it alive. I am looking at 600 dollars of carpet that wont stay down now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okie Boarder Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2010 at 8:05pm
I did a test piece early on and once it dried it was hard to seperate...basically ripped the rubber backer. I've been pretty liberal with the adhesive, so that probably helps.
RainDog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RainDog Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2010 at 3:31am
I found the Henry 263 at our local Farm and Barn type store (Fleet Farm, (not Farm and Fleet) for us 'Sconnie boys). Try Tractor Supply or something similar. Lowes does not carry the 263.
inglesideshawn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote inglesideshawn Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 9:39pm
contact adhesive from weldwood adhesives is the best product ive used,two years and still holding over epoxy...
1989 nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2010 at 10:02pm
Shawn,
Do you know someone that's tried to use epoxy??? Wow!! Did you try it? I would think the cure time would be a real problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote inglesideshawn Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2010 at 10:02pm
my boats epoxy over 4lb foam,afer the stinger job.. that would be epoxy as in the floor..not sure if trowl down glue would even stick to exoxy,if that makes sence..
1989 nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2010 at 10:54pm
Shawn,
Got it now!!! The carpet adhesive will stick to epoxy. The contact cement you used sure will too except it doesn't give you any opportunity to move a misplaced carpet. Did you have help? Usually you need about 20 arms and hands with contact cement!!
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2010 at 11:18pm
3M Supertrim Adhesive. I've used it (successfully) for years. I have a piece of the Lowes indoor/outdoor carpet that looks like corduroy on an aluminum dock which stays outdoors through snow and sun and rain and it is still stickin.
You can adjust the spray pattern and do small areas if needed or large areas. You are allowed some reposition time too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wacko Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2010 at 12:48am
Are you using a spray adhesive or is it a can that you are spreading on? I did see some 3M Super 77 in a spray adhesive at the local hardware store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2010 at 1:19am
I used the can, I was doing things that were small at first and trimming off the extra. Worked well, so I used it o. The sides. If you have large pieces where you don't have much extra you could run into a situation like Pete was talking about where you can't move it around. I got the carpet at Lowes and it was cheap enough to where it didn't matter that I wasted a bit.
srbranum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2010 at 11:48am
Wow! Did I buy the wrong stuff at Lowe's? I only spent about $150 for a 6'X 28'piece to cover everything.
I have to keep her running 'cause I can't afford a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2010 at 12:23pm
I was more in the 6 x 40 range with the extra's that needed to be covered in a 18 foot long boat, but my 83 being a hobby boat doesn't exactly have a "intelligent" or even "realistic" budget. It was 40 oz marine carpeting.. not something I would recommend...
Post Options Post Options   Thanks (0) Thanks(0)   Quote inglesideshawn Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2010 at 5:23pm
cements quicker and easier just fold and roll the glue out.. trowl down can be moved and adjusted but takes twice as long.. made patters out of paper then cut big to alow for triming
1989 nautique
horkn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2010 at 9:16pm
I used the 3M spray adhesive as it worked great on my martinique. It holds great even after several years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 1:20am
I bought some of the High Strength 3M spray adhesive at Auto Zone today($20/can X 3 or 4 cans ) but I found two places locally that sells the Henry's 223(?) Pete was talking about so I may check it out monday.
Question: How long should I allow to install carpet in my 16' CC Skiier?
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 2:18am
Take your time, measure twice, and cut once or it will take longer and cost more;)
It took me a few hours to get mine re carpeted after I replaced the flooring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 10:09am
Thanks,
This is how I was told to do it:
Cut the sides first. Come down the side and on to the floor 2" back to front. Then put the floor down and come up over the 2" from the side to flush with the gunwail. Seal the edge with liguid nails.
I asked my contact about the overlap down the side and would it be a hump or look bad and he said that's how they do it from the factory so unless I hear otherwise, that's what I'm going with.
scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 4:07pm
I didn't overlap that much. It would have been lumpy had I done it that way.
What carpeting are you using?
I used marine carpeting that have a tad more thickness than the stuff that nautiques have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 4:44pm
I just bought the best marine carpet they had from Lowe's. Woody at Mastercraft of orlando(formerly Southeast CC) told me that's where he would buy it if it were him. My contact told me about the 2" deal. He said that much would allow for it to even out instead of bucking up with a shorter amount.
I only use the boat 12-20 hours/summer so I just could not justify the Overton's or other expensive stuff.
LAKESIDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LAKESIDE Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2010 at 8:57am
Been doing upholstery for 23 years.The spray adhesive is crap. Even 3m. I would never recommend using that. Doesn't hold up after heat hits it. If you have access to a pray paint gun and a compressor, try to find some straight up contact cement. It sprays great out of a gun. Home depot sells it in gallon pails. Or maybe if you have a local upholstery shop you can buy some from them .We sell it all the time to customers. WE buy it by the 55 gallon drums. Also when applying it make sure you put glue on the carpet as well as what you are gluing it to. Let dry for a few minutes the stick it down. You wont have any problems. If you don't have a way to spray it you can always brush it on. Harbor Freight sell spray guns for around 15 to 20 dollars. Been using them for years.
93 Ski Nautique   SUCK MY WAKE
Post Options Post Options   Thanks (0) Thanks(0)   Quote LAKESIDE Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2010 at 9:13am
Home depot sells this. Much cheaper than the spray stuff. This will be more than you need.
DAP 128 Fl. Oz. (Gal.) Weldwood Original Contact Cement
Model # 00273
Store SKU # 465631
$29.98/EA-Each
Description
A multi-purpose neoprene rubber adhesive that forms an instant, high strength bond on a variety of surfaces. Offers hundreds of uses for the home, office and workshop. Forms strong bonds on contact to eliminate the need for clamps, temporary fasteners and long set times. Ideal for bonding: plastic laminate for counters and tabletops, wood and plastic veneers, metal, wood, leather, linoleum, tile, rubber, cork, polyurethane foam, paper and cardboard, many plastics and vinyls and other porous and non-porous materials. Resists the effects of heat, water, weather, grease, oil, and household chemicals. America's best selling contact adhesive. For interior and exterior uses.
    * Strong, Instant Bonds on Contact
    * Can be Used on a Variety of Surfaces
    * Excellent Water Resistance
    * Interior/Exterior
    * MFG Brand Name : DAP
    * MFG Model # : 00273
    * MFG Part # : 7079800273
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2010 at 11:29am
Henry's 263
Going to buy this tomorrow morning when I get off work. Come to find out it is only two miles from where I work.
Thanks
scott
