  New Posts New Posts RSS Feed - Extent of rot?
Extent of rot?
merbesfield View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote merbesfield Quote  Post ReplyReply Direct Link To This Post Topic: Extent of rot?
    Posted: June-14-2010 at 12:48am
Need help from the experts. I looked a little closer at one of the rot spots on my boat. How hard will this piece be to repair and how long can I wait to repair it? I could stick my finger up into the cavity and with the hose was able to wash out all the rotten wood. How bad is this? The boat runs awesome other than a few mechanical issues and some water in the bilge after a run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 9:12am
What other checks have you done for stringer rot? Have you checked the engine to shaft alignment? The rot you found is in one of the crossmembers and isn't critical but it's also a indication there's rot elsewere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 12:01pm
Here's some pics of my '85 of the area your talking about with most of the foam removed.
The little block that is in question in your pic, is nothing more than a dam for the foam.
I wouldn't worry about that spot for now enjoy the summer than work on a fix.
As for the water in the bilge first check the easy things like the shaft log and rudder, then dig a little deeper.
My exhaust tubes were shot and riddled with pin holes but that caused it to take on water even when it sat.
Is the water hot? If so it could be an exhaust leak looking at the duct tape in your pic, that would be another place to start
malibud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2010 at 12:15pm
mine rotted out like that on my 85' and I ripped it out and replaced it w/ epoxy after it dried out over the winter. stringers are still good at least until my boy gets old enough to fix them
