Water Hook up |
Post Reply | Page <123> |
WakeSlayer
Edit: never mind what I had previously written, not paying attention... Ryan, you shoudl get a strainer cup on there for sure. |
Mike N
1968 Mustang |
CCrider89
Groupie Joined: February-10-2007 Location: Canada Status: Offline Points: 44 |
316-Ryan wrote
"I filled a cooler with water, put one end of the hose in the cooler, and connected the other end to the T." If you connected the T to a hose and the other end of the hose in a cooler full of water, don't forget that the other side of the "T" is going to the bottom of the boat. It will suck air before it will suck any water from your cooler unless you have blocked the pickup grate. |
CCrider89
Boating in the northern Adirondacks |
316-Ryan
Groupie Joined: March-31-2009 Location: United States Status: Offline Points: 45 |
Randy,
I didn't even read your post, but I'm pretty sure you're right. I just got finished sifting through an 83 PCM maintenance book I downloaded, and it doesn't have anything about a strainer. I'll definitely have to look into that. |
316-Ryan
I wonder what would happen if I put gravity to work, and set the cooler up on the gunnel... I'll go try that. Thanks for the pointer CC.
bkhallpass
Take a picture of what hose you haver running into the cooler.
Also, the line running into your white plastic T. It has a brass fitting running into the T. What does that line run to? BKH |
Livin' the Dream
WakeSlayer
I think that is the fitting for running on the hose?
Ran three on the hose yesterday, no issues. |
Mike N
1968 Mustang |
316-Ryan
Here's what I have running from the cooler of water. I used a plastic cup to prevent air from being sucked in through the grate... upon starting, no water was sucked in. I also connected a hose directly to a faucet that powers a row of five sprinklers (plenty of pressure), and started the motor. Water was streaming out of the grate on the hull. That's not supposed to happen, is it? |
WakeSlayer
Take the top of the T off and put your garden hose in the end of the uppermost hose, clamp it, and you will be fine. This is the same BS problem I have with the T in my Super Air, just bypass it and be done with it.
Mike N
1968 Mustang |
lewy2001
Ryan with your current system as soon as you turn on the hose water will exit from water intake grate. When the motor starts the RAW pump will suck the water from the garden hose supply and the volume of water exiting the grate will diminish. The harder you rev the engine the RAW pump will demand more water from the garden hose supply.
The Perko flush system earlier in the post has a non return valve inside it that prevents any water exiting via the intake grate. In this situation the garden hose pressurises the system and force feeds the RAW pump. I used to run a system like this with a non return valve between the water intake grate and the tee. But simple is often better and after a earlier thread where TRBenj described his system I removed the non return valve and the system works fine. Excess water will just exit via the intake grate. |
316-Ryan
Lewy - thanks for the explanation... that makes sense. Two questions: Where does the water that is suctioned in exit the system, the exhaust? And second, how do I determine if the pump is working? My temperature gauge is not working.
lewy2001
Correct the water that comes in through the RAW for engine cooling exits via the exhaust.
The procedure is turn on garden hose supply start engine let it run at idle making sure water is exiting via the exhaust before you start raising the revs. Do not wait to long before seeing water exiting from exhaust. A working temp gauge is a must in a boat. You will need to sort this issue out as it has the potential to cause major engine problems (expensive problems). This method proves the RAW pump is working to some extent. To properly test the efficiency of the RAW pump the "bucket test" is required. You would remove the hose from the top of your white tee place it in a bucket full of water. The garden hose is then turned on and put in the bucket also. With the engine running the RAW pump has to draw the water from the bucket just like it would do in the lake. The whole idea of having the tee setup and quick hose connection is convenience. Making it simple to run the boat on the trailer to check engine running and make adjustments. I have a quick hose connect on mine with a tap. Can have it setup in seconds ready to run engine. |
Randy_in_Ohio
I did this over the weekend. I haven't tried it out yet, still have antifreeze in the engine.. probably try it next weekend. I put the "T" before the strainer. Will I need to fill the strainer with water before I run it? I'm kind of afraid the water will fall down through the water intake hole and never make it to the strainer. I'm starting to think I should have put it after the strainer. I thought the strainer would be a nice visual indicator that the water was flowing. What do you guys think?
Anyway, was pretty easy to do, but I would recommend getting the hoses wet or spray with silicone fist so they go on easier. I had a heck of a time getting the last hose slipped on. |
316-Ryan
Mike- when I check the posts, it's usually in a hasty manner. I missed your post last night, but that's a great idea... I'm gonna use that as a quick fix so I can tune my carb.
Lewy- thanks again for the info and the pic. I'm definitely gonna have to fix my gauges (neither oil pressure or temp are working), that does seem kinda like playing with fire... I definitely don't want to ruin my motor! As far as the test goes, I did it, but without the running hose in the bucket. This was to see if any water was diplaced from the bucket... None was. |
C-Bass
Mike/Tim
As an update, I did the Tee setup this last weekend on the BBC. First time I turned on the water, started the engine, and it started sucking it thru perfectly. A few hours later after new points/condenser/cap/rotor, I go to start it, and it just kept blowing out the intake just as Mike described. I had to have someone cover the intake with their hand to provide enough backpressure to feed the water into the impeller, once it got to the impeller, no problem, it sucked it in fine from then on. Tim you said you had a 1" tee on yours. This may be the issue as the 454 (at least my old 85) has 1.25" hose. This may be a little too big to get good suction from the impeller. I'm going to install another shutoff valve on the strainer side and partially close it before I do this again, that way it will provide just enough resistance to keep water at the impeller, but not sealed off completely. Hope that all makes sense... |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21183 |
Craig, maybe your pump needs to be primed. Maybe the 1-1/4" hose is partially to blame, but my 302 Conquerers have the larger hose as well and dont have any problems drawing water.
CCrider89
I agree with TRBenj, a 1/2" garden hose pushing into a 1.25" suction hose would likely allow the raw water pump to suck air past the flow of water.
A small thread jack here, but can someone tell me what this hose is? and what it is for? TRBenj's engine picture has it too. Thanks Craig |
CCrider89
That is a quick fix that PCM suggested for early 1.23 trannys that had a hydraulic pump buzzing noise. It just serves as an accumulator. Right Eric?
Randy_in_Ohio
I installed this as well, but haven't started it up with the hose yet this year. I'm worried about this not working and running it dry. My system will be dry except for the antifreeze in the block. How would I go about priming the pump? I have the pump off the engine right now. Can I just put a toilet plunger or something over the intake hole and run the water?
Rglover
Senior Member Joined: October-21-2008 Location: Canton, GA Status: Offline Points: 111 |
[QUOTE=TRBenj] I guess the Flush-Pro is an OK device... but it seems overly expensive for what it is.
All I have to say is I have not had one issue with my Perko Flush Pro. I agree it is a little expensive for what it is, but I have the peace of mind of knowing it will work as intended every time. I also have the peace of mind knowing that if I forget to put the plug back on it and head to the lake I will still draw all of the water I need to cool my engine into my engine and none will be spilled into the bilge. Sometimes I don't mind paying for someone elses engineering when it offers me those benefits. |
C-Bass
Among many other ways, yes this would work Randy. That's actually a version of what I did. I just had someone put their hands over the intake to reduce the amount of water that could freely come out of it. Along with getting them soaked, it put enough back pressure to force some water right up to the impeller and it primed it and started pulling the water right away. If you wanted to make sure water was in the impeller to start off with, take off the hose running from the RWP up to the T-stat and fill that up so that the impeller won't be starting dry. Most likely you already have anti-freeze in that hose though so if it were me, I wouldn't worry about that. |
C-Bass
Another solution is to rev the engine up to 3-4k rpms until it starts to pull suction on the water.
Just FYI, Ive never had to prime my pumps- I install them dry and they always pull water.
Same with me. There's always enough A/F in there to lubricate/seal the rubber impeller to get the water sucked up. If you drain only without A/F or have installed a new impeller, then it may be a different story. I'd pressurize the inlet to the RWP with the garden hose first. It will have enough pressure to get some water into the RWP. Just don't over do it!! |
Swatkinz
Platinum Member Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
Tim, what does the "NPT" above reference? I've been to both Lowes and HD and couldn't find the 1x1x1/2 tee in brass plastic or otherwise. Surely I must be looking in the wrong place |
Steve
it stands for National Pipe Thread, the plumbing version standard thread callout for a taperd thread used in plumbing, They ahve them at lowes.
Steve,
When you go back to one of the home centers, just don't ask the "sales associate" for "NPT" fittings. It will just screw him up, he won't know, will never know and doesn't care!!! Hopefully he will know where the plumbing/pipe fittings are!! |
You are right on both accounts it is your transmission cooler and in this case it is your strainer as well since it is where you are going to collect anything sucked into your engine big enough to matter. It is preferred to have a strainer, and quite necessary in some areas... but there are a lot of boats out there without them.
Wow i guess i missed page 2 on that post...
Swatkinz
Made this modification to my boat this weekend. Worked like a champ and highly recommend |
Steve
Well if you just stick in the hose yes it will suck air, But you should be tightening the hose clamp around the metal end of the hose and it doesn't leak or suck air, so to me it's too easy to remove the hose from the pick-up insert the garden hose tighten the clamp and turn on the water and do what needs to be down to the engine. Then you don't have to worry if you flip this valve or that and smoke the impellar because you did. |
