  New Posts New Posts RSS Feed - Steering Cable Problem
srbranum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Topic: Steering Cable Problem
    Posted: June-26-2010 at 5:18pm
Hi everyone. It's me again needing some help from my buddies at CCF. My boat is the 1975 Skiier from the thread "1975 Skier Stringer Replacement".
No problems with the stringer issues. Had a wonderful vacation. Went skiing today for the first time since the 11th. Rode around for about 15 minutes, went swimming a bit and then decided to ski. Pulled my son up and the boat immediately went left and would only go left. To make a long story short, I have no steering. My first thought was "Omg, my rudder fell off". I jumped in the water and thankfully that was not the case. I took the back panel off in front of the fuel tank and looked at the rudder assembly area below the tank and it looks perfect. I opened the access plate on the rear floor and felt the bracket that holds the steering cable thinking it had become unattached from the primary stringer and it was fine as well.
Under the dash, the steering wheel will move the cable in and out of the helm but it seems very free turning unlike two weeks ago when there was resistance. You can turn the steering wheel as much as you want and the cable will feed out without stopping which does not sound good to me.
I can post a picture of the area under the dash around the steering helm if you need me to.
Can anybody give me some direction to try and fix my problem? Thanks.
Scott
I have to keep her running 'cause I can't afford a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 5:33pm
Scott,
When you turn the helm, does the rudder move? If not, one of two things. Ether the cable broke and then check that the tube at the stringer isn't slipping in the clamp.
Since there's no resistance, I'd say the cable broke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 5:57pm
Pete,
If you turn the steering wheel, the rudder does not turn.
I would have to open the access plate behind the engine cover and look at the bracket at the stringer you are talking about.
If the cable broke, I think I have a big problem due to the way I put the old cable back together. I dread the thought of running a new cable based on how I put things back together.
Too hot and frustrated today to look at it. Maybe tomorrow afternoon if I don't have a CC bonfire before then.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 6:38pm
Originally posted by srbranum srbranum wrote:
Pete,
What's different? I went back and looked at your stringer thread because I really couldn't remember anything real weird about your steering cable routing. What i did see is it's pretty normal. Up to the bulkhead between the main stringers and then through one of the pieces of flex tubing you put in running up to under the deck. Is this correct? If so, you shouldn't have a problem. Tie the old to the new and then pull the old out pulling in the new one.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 6:47pm
Scott,    marineengineparts.com
Teleflex SS C 61     117.85
Or if you do decide to go with the bonfire route, I'll take your Bimini.
AT
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 6:55pm
Scott, You can't pull a new cable in while pulling the old one out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 7:41pm
Pete,
Pete,
If I remember myself, the reason I think I will have a problem is that the cable is NOT inside the pvc tubing with the wiring and the throttle and transmission cable. It is running beside the tubing, through the small amount of foam I used and through the bulkhead and then back to the rudder. If I get a new cable, I guess I would just have to cut the other one off at a convenient spot and run the new one thru the tubing???
I will take some pictures and post for you to look at.
Again, everyone on this website should be proud to always give advise to others without any expectatations in return and it is always appreciated.
scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 7:44pm
I intentionally left two strong pieces of rope in coming out of each end of the tubing(under the dash and in the bilge) in case I run in to something like this so maybe it will come in handy.
See my quote to Pete as to why I can't use the old one for a new one.
Scott
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 7:45pm
so, I guess I'm not getting the bimini.
AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 7:45pm
AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 7:47pm
AT
Check with me about mid week..........
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2010 at 8:21pm
AT,
So, if I buy this cable tomorrow, how hard is it to put in? Are you sure it is compatible with what equipment I have and the year of my boat?
My old cable runs beside the tube and is encased in foam before it goes through its own opening in the bulkhead and back towards the rudder. I don't know my reasoning at the time but was probably under pressure to get it finished and it is what it is.
Also, the back floor is removable BUT the screws are under the carpet and not through it. I would have to scrape the new carpet off the wood if possible and then unscrew the screws. I probably made a mistake doing it this way but I guess my thinking was that I did not want large brass screws showing in the carpet.
Now, what do you think?
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2010 at 8:25pm
Scott,
Being a novice at this, how exactly does a steel cable break? And, is this pretty commom or did I do something to make it break? Could it be off it's track in the helm? I doubt this because the helm is apparently doing it's job by working the cable in and out when I turn the steering wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2010 at 9:01pm
Scott,
Cables failing is common. Anytime you flex steel enough it breaks.
It's not off the "track" at the helm because you say you saw it move!
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2010 at 11:36pm
Scott,   yes, breaking old cables is too common.   That cable (above)should fit your T-helm. Comes with the threaded style adapter.
Should be a simple install (back to front) meaning, pull it forward with one of your pull lines.
My only concern would be, if you changed the wiring/cable tube to a sharper angle.   That's the reason you can't pull a new cable in while pulling the old cable out. The transom end of the cable will not pass through the wiring/cable tube.   Could this be the reason you re-installed yours beside the tube?
AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 1:31am
AT,
I think you are correct. My mistake in this part of the rebuild was not making the angle of the tube correct. Unfortunately, mine is 90 degrees instead of 45. I thought 45 was the answer but could not think of how to do it at the time so I tried a certain 90 degree setup and it seemed to work. At one point,I had the transom end of the cable in my hand and told myself it would never make the turn and instead of pulling the cable out of the helm, running it through the tube and then re-inserting it back in to the helm, I just ran the cable outside the tube by itself, through the bulkhead and back to the transom.
If a new cable will not fit in the tubing as it is now and getting by the 90, the only thing I know to do is somehow use the old cable to pull the new cable from the point of entry under the dash, through the foam and out the bulkhead. I seriously don't think that will happen but I am at a loss right now. That poured in foam is some strong, sticky stuff and may not release it's grip from the cable sheath.
Do you think a new cable could be inserted into the tube and pulled through the 90 degree turn and up to the helm and not binding the steering excessively? If not, I don't know what to do and will have to come up with something.
scott
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 2:15am
Nope, you'll never get a steering cable thru your 90*
Just went back and saw your foam pics. Your right!!! Cable won't come out without a fight!
The only thing I would suggest at this point is some creative foam carving and digging.
AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 7:35pm
AT,
I went ahead and ordered the cable you mentioned above. The salesman thought it might be slightly smaller in diameter than my old one but not for sure which may help me some but I am not counting on it. I told him my contact(YOU) said this is what I need so I told him to ship it to me in a 17' length. Supposed to be here friday.
Still don't have a game plan for removing the old one and installing the new one so I will have to come up with something I guess.
On another note, what is the proper method for installing the back floor on my boat? I put the floor down, screwed it in and then laid the carpet on top of it. The only problem with this is if I need to take the floor out, I have to somehow remove the carpet from the floor in order to access the screws but this will ruin the carpet I'm sure. Now that I may have to replace my cable, the floor will most likely have to come out to access everything.
Your thoughts?
scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 8:08pm
I almost hate to say it, but these are exactly the sort of issues that could have been prevented by doing a little research and not rushing into a project with a major deadline approaching. Your determination and final project were very impressive, especially considering your restraints (namely time), but running the steering cable through the foam without conduit? Oh man. These might be good things to add to your original rebuild thread as sort of a "lessons learned" so people who use it as a future reference might not fall into the same trap. But I digress...
Ideally you would want a 16' steering cable for your 16' boat. The 17' will work, but will be a bit longer than you need. This is a generic rotary Teleflex cable- the last time I bought one from Go2Marine, it was ~$95. It looks like youre replacing the original cable, so you may also need a clevis kit to attach it to your tiller arm. I have posted the part number here before, though I dont know it off the top of my head. I cant tell if you can reuse the clamp tube off your old cable- but you may need one of those as well. Try the search function, that info is on here somewhere.
I looked back at your old thread and cant see what the conduit tube that you used for the wiring, etc looks like. Was it the same as the ones you used for the vents? If so, thats not *too* sharp of a radius, and I would try to get the new cable through it. I sure wouldnt run it through the foam again- thats just a disaster waiting to happen. I would make every effort to reseal the holes at both ends once the old cable is removed to prevent water getting under your fresh floor.
As far as the rear panel goes, you probably mimicked the original install pretty closely. That being said, the original setup isnt very good. All modern (1980+) panels simply "float", meaning they dont screw down. Theyre also carpeted separately from the rest of the floor, so they truly are removable- which is necessary to do any maintainance in the bilge (replace packing, exhaust hose, etc). I would recommend you cut the carpet, remove the screws, seal up the holes and reinstall the panel without them. Add some T carpet trim to hide the seams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 8:29pm
TRBenj.
I have no idea about what length is correct. DRCC suggested what I purchased so that is what I went with because the cable is still in the boat and there are no markings on the cable for reference. The cable comes out of the floor under the dash and has a big sweeping curve to it before it enters the helm so maybe that's the reason for the 17' length. As far as a clevis kit to attach it to the tiller arm, I also do not have a clue. If I figure out the cable installation, I will worry about the rudder area later and any hardware I need.
I have heard your comments on your rear floor before but maybe I did just put it back the way it was, who knows. I purchased the pieces to cover the seams but just did not put them in.   I can get the floor out, I will just screw up the carpet. I hope Lowes still has the same roll so the color will be the same and not another lot number with a slightly different shade of the same color.
I hate that I don't know what to do when it comes to fixing this boat but it is what it is. If I had the money, I would just sell it and buy a new one an not worry about anything breaking and for piece of mind. If it was not for my son who loves to ski, I would put it in the garage and fix it if I got a notion and only then........
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 8:52pm
Wow I feel or you. I attached my steering cable a few hours ago and am getting ready to hook up the steering column. It was all fun and games till you have to make it work. I am stressed but have pushed back my launch date a dozen times now as I run into difficulties. Good luck!
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 9:08pm
Scott,
When I went back, I really must have missed the picture that shows the cable in foam. I too believe you will have a tough time getting the new in the same spot. Tim's idea of getting the new one through one of your vent hoses is best. I wouldn't even try getting the old out. Just cut off the ends with a cable/bolt cutter.
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 9:43pm
Scott, I also would try to fish new cable in the conduit.I could only remove mine pulling from the back so I would try to push new one up to the helm. It might help to remove throttle and shift cables and wiring. Also if you had to maybe cut down into the conduit where the steering cable binds with a sawzall to make the bend and possibly patch it back up with a smaller piece of 1" cut in half lengthwise. Then cut and abandon old cable. Just some thoughts Good luck and keep us posted. Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2010 at 11:50pm
Scott,
Excuse me for being a little slow but I just realized what you guys may be implying......are you saying run the new cable up the vent lines coming down from the scoop on the bow? That would be great but the lines are primarily on the passenger side of the boat and everything now is set up for the drivers side. Also, what if the clamp attached to the primary stringer underneath the rear floor on the drivers side is a larger diameter than the new one? If I could run it through the air vents, I could just drill an exit hole for the cable to come out underneath the dash and just loop it around to the helm possibly.
Leaving for Memphis now, will get back with ya'll in the morning.
Again, thanks for putting up with my ignorance.
scott
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2010 at 2:26pm
Scott,   Yes, the 16' (192") would be the proper cable, However, in your situation you might be glad you have the 17' (204")    Any identifying markings on the cable will be in inches.
I suppose I should have gave you both prices and let you decide which one you preferred.
Question: How many big brass screws did you put in the rear floor section?
From your pic, it shows you carpeted it separately. Slowly and carefully, with a putty knife, peel back the carpet.   The glue is still fairly fresh, so this should not be too much of a problem.
If you feel you need or want to screw the floor back down, all you would need is 4.   Oval head stainless with finish washers, on top of the carpet. Front two- hidden under the motor box. Back two- hidden behind the rear panel. Or if your motor box hinges line-up directly above the stringers, only one longer screw in each hinge.
Ok, Up front.   I'm assuming I see 3" white PVC schedule 40?
This is why I say a steering cable will not pass through a 3" PVC 90*.
I personally would dig out the old cable and install a flex tube just for the steering cable.
AT
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2010 at 2:32pm
Red arrow points to steering cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2010 at 2:36pm
Wouldnt this be dependant on the size of the radius on the 90* fitting? I agree that a short 90 wont work well, but he has some pretty big bends in his vent hoses. I cant see what his conduit looks like from the pictures he posted previously.
For anyone else reading this, I used a 4" PVC conduit on my Tique with a 45* fitting and feeding cables through it was a breeze. We're using 2 large radius 45* fittings (again, 4") on the BFN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2010 at 2:48pm
I would just use the plastic electrical conduit....its made so cables can go through it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2010 at 2:55pm
for you to be able to pass the cable through that 90 you will have to feed the helm end of the cable from the bilge side of the tube to even have a chance, I think it'll be fine little tight but should work ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote srbranum Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2010 at 8:42pm
AT,
First, thanks to all who have responded. I have read everyones comments and here is my best response to them all.
I have already ordered a 17' replacement cable. Should be here thursday. I don't think there is any way in the world to get the new cable in the same tube with the electrical, throttle and transmission cables. I am going to try and cut the old cable off underneath the dash and try and pull it out from the back with the strongest device I can get my hands on(vehicle, winch, come-a-long, ect..) and pulling the new cable attached with it.
If this does not work or I change my mind, the last choice will be to drill an access hole in the clear trash hose(The Front air hoses from the bow scoop) and run the new cable down the tube, in to the bilge area from the bulkhead, past the battery box, hang a left at the engine and work my way down to the rudder hoping I have enough cable to do this. I don't know how the new cable will attach to the rudder arm and I may have to buy the clevis kit(part num. telsa27314, $29.39 from marineengineparts.com) mentioned by someone earlier in this post. I will probably have to use the tube closest to the passenger seat because otherwise, the cable will run in to the back of the battery and/or the battery box.
Out the door to the ball park and then to work tonight. Will check back in three hours and then tomorrow. Thanks again everyone.
scott
