Transmission leak? |
FrankT
Senior Member Joined: September-07-2006 Status: Offline Points: 245 |
Posted: July-05-2010 at 8:41pm |
It appears that I am leaking fluid on my 10-17 velvet drive from the detent ball. Is this possible? Can the O-ring be replaced on the control valve without removing the transmission?
FrankT |
Frank,
No need to pull the trans! There's a "O" ring on the shift control/spool directly behind the shift lever but, the spool come out from the other side. Be careful on the re install. there's some tabs that need to line up on the spool. |
FrankT
Thanks - I will give it a try. Any recommendation on who to source the o-ring from?
Frank |
I'd go over to my Ace hardware! |
