  New Posts New Posts RSS Feed - prop pullers
prop pullers
horkn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Topic: prop pullers
    Posted: July-06-2010 at 12:54am
So, do the harmonic prop pullers work well?
Otherwise, there is no real difference between the regular type OJ puller and the acme puller beside price, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 3:09pm
I'm sure someone has used the harmonic pullers.
I'm just wondering if the harmonic puller works every time. A harmonic puller that won't pull off stubborn props is not worth it to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 4:12pm
Tom,
I wouldn't waste my money on a harmonic! Or, you can go and buy a $2.00 3/4-10 coupling nut and pound on it!
You'll have a hard time using the harmonic on a prop that's properly installed by lapping it to the taper.
BTW, hammering on the end of the shaft does wonders for the trans bearings!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 4:23pm
yea and a harmonic puller doesn't even have arms, guess you use screws and a makeshift plate.
Pete he's about as acurate with tool names as he is with ford engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 4:41pm
Yeah Pete, I was not really sold on hitting the shaft with a hammer to pull the prop.
Chris, The makers of the harmonic pullers call them that. It's not me that named them incorrectly.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 5:28pm
So, Who has actually tried one?    (OJ Prop Knocker)
AT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2010 at 2:18am
That thing sure looks hard on your equiptment,how could you even hit it with the rudder in the way?
