  New Posts New Posts RSS Feed - draining trans fluid
martin 74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote martin 74 Quote  Post ReplyReply Direct Link To This Post Topic: draining trans fluid
    Posted: July-14-2010 at 3:30pm
Is there any shallow pan that is especially good for draining the 1.8 quarts of trans fluid into for my '74 trans change? I'm trying to do a neater job this time and keep the bulge clean. Any way to use my oil sucker?
Thanks
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2010 at 3:37pm
It's sucked out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote martin 74 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2010 at 3:50pm
So I remove the top hose and suck out of top instead of removing the lower hose and draining out of the bottom. Great!
Thanks
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2010 at 3:58pm
Rich,
Suck it out of the dipstick hole. Then no hoses need to come off. You won't get all of it this way but it's enough to get the job done. You can even use a cosmetic pump say off the top of a hand cream bottle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote martin 74 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2010 at 4:27pm
Got it.
Thank You
Rich
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2010 at 6:29pm
This is what I use.
Tim D
FrankT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankT Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2010 at 6:46pm
I made a changer out of an old drywall bucket and a geared fuel pump. Use it for both engine oil and transmission fluid.
FrankT
thatdude596 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thatdude596 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2010 at 8:08pm
ski dim sells the pela extractor for 50.00 its a really nice pump, works well.
