Morse knob |
dans ![]() Senior Member ![]() Joined: March-23-2006 Location: United States Status: Offline Points: 187 |
![]() ![]() ![]() ![]() ![]() Posted: March-27-2006 at 8:47pm |
How do you get the shift knob off a morse shifter ? I tried to unscrew , but I don't want to break it off . I hope the previos owner didn't glue it on. I might have to saw off the top to break it easy. Any tips ? Thanks. Dan
AWhite70 ![]() Senior Member ![]() Joined: March-05-2004 Location: United States Status: Offline Points: 242 |
On my '79 it just screws off.
David F ![]() Platinum Member ![]() Joined: June-11-2004 Location: United States Status: Offline Points: 1770 |
They all screw off. Some may have a set screw.
Martinique87 ![]() Groupie ![]() Joined: November-29-2005 Location: United States Status: Offline Points: 75 |
I replaced mine not too long ago. It was really rusted in place, no set screw though. I used a pipe wrench on the old wood knob while bracing the metal shaft so as not to damage it.
As I applied force the wood knob from the threaded portion. once that was gone I removed the threaded portion with vice grips and put the new knob on. Not pretty but it worked. You might be able to do it with just the vice grips on the metal base of the knob. Maybe giving it a squirt of WD-40 a few hours before hand would'nt hurt? Tim |
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5777 |
Are you replacing the knob with a wood one? I have only been able to find a plastic replacement, anyone have a line on these? I am actually looking to replace the whole lever as the chrome is pitted but want a wood knob. Thanks
skidim.com
shawbound ![]() Newbie ![]() Joined: November-19-2007 Location: South Africa Status: Offline Points: 5 |
I spoke to skidim as mine is also corroded into place and we haven't managed to get it loose. They sugested that I cut it off with a drimel tool. I asked them about getting a whole new arm but they only sell the whole mechanism. they do sell a very nice mahogany knob tho.(got one just trying to get the old one off!:))
This is Randy in Ohios specialty, im suprised he missed it
Randy_in_Ohio ![]() Platinum Member ![]() ![]() Joined: September-13-2006 Location: N. Canton, OH. Status: Offline Points: 1891 |
Dan,
I had a hard time removing my knob too (I almost said "I had a hard time getting my knob off", but we all know where that will lead...) I was able to remove it using a small rubber strap wrench. Take a look at my thread from when I finished my knob: Randy's Knob |
I made these for my dad last Christmas; bocote on the left and cocobolo on the right. If I knew where to find the threaded inserts...
Greg, You do some very nice turnings. I do hope you used a dust make for the Cocobolo. It is a real bad irritant on the lungs.
Here's some inserts: wood workers supply-inserts-brass |
Thanks Pete, and that's a good link. The solid brass epoxied in would be a good deal. It was just an idea but now will have to be a material decision...I'll be thinking about that all winter?!!? LOL
Padauk to me is much worse to breathe! ...but looks great when aged. side note: no money involved, but I'm in your camp on the C K thing! ![]() |
Greg, It's been a few years since I was into the projects with the exotics. It's white Oak and Mahoganies now! If I remember, doesn't the Padauk turn a real deep purple color? I turned a couple of serving plates out of it and gave them as Christmas presents. Also a couple out of Brazilian Rosewood when you could still get it!
Those inserts don't require any adhesive but I'm with you, I'd probably put some epoxy in there too. The last time I used them was for the adjustment of a router fence in the table board of my unisaw extension. I did glue them in!! With the C-K thing, it must have been Eric's heritage that got the letters mixed up!! |
LOL!!! Padauk sure doesn't stay orange; I wish it would sometimes, though it turns to a great 'old rugged cross' look for that application. There are still several kinds of rosewood out there, but they are pricey. I wasn't kidding about me thinking all winter about my species choice for the shifter. I see tulipwood on a red and white classic(there's another nice 1 on craigs list in walpole?), and maybe wenge on the bfn...wenge has a cool grain pattern when turned round. We'll see. And that's a good idea for micro adjustments as well! |
The inserts are for the coarse adjustment. The Frued fence I picked was because it has the micrometer adjustment on both fences. Very HD cast aluminum. Forget the fence! It comes with some junk MDF. I replaced it with some nice T slotted aluminum. Great for finger boards. ![]() |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21143 |
Nice catch. Its only about 40 min away from me- let me know if you want me to check it out. |
Thanks TRB(Tim?), From what I can see in the pics it's a complete project and and in pretty good condition. I wouldn't be surprised if it was drivable now. Half of me is already on my way to get it, but I still don't have a good place for it... and I have a bfn all over as it is! ![]() It looks like it's been reduced by $300 too! ![]() |
Thats OK- dont let logic stop you from grabbing it (it hasnt stopped me yet)! It does look to be complete based on the pics and description- it may very well run. If you want some first hand input, shoot me an email: TRBenj@gmail.com |
Barracuda ![]() Moderator Group ![]() ![]() Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
Randy- Meant to say thanks. I followed your process and refinished the throttle knob for my 86. It looks great! I had some poly laying around, so I put a couple coats of that on instead of the spray laquer. |
The Dude ![]() Platinum Member ![]() ![]() Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
Randy's knob was one of my favorite posts of all time here. Just seeing this post made me start laughing and hoping Randy got on here with his most excellent advice.
Mullet Free since 93
95 Sport |
Brad
If I was to do it again I probably would have used a polyurethane. The lacquer I used was for indoor use I realized after reading the can after twelve coats. It seems to have held up good though and it looks like wood covered in glass! ![]() |
Dude,
Thanks for the compliment, but I am usually here looking for advice not giving it. I enjoy chiming in on something I have had experience with or sharing something I have found useful myself, but I take more knowledge than I give. |
The lacquer will probably hold up outside but it doesn't have any UV protection in it to keep the color of the wood from lightening up. There are polyurethanes for exterior. The only difference from the interior versions is the addition of the UV protection. When using a poly (or a spar varnish) with the UV, it will darken the wood slightly because the UV ingredient has a orange tint. If you have ever noticed what is reffered to as a "blond" section of a wood boat deck, it is really a orangish color. It is created by bleaching the mahogany to a "water white" and then varnishing. The orange in the varnish colors the wood - no stain is used. |
hopefully you guys dont say oh no not again, but i was on a 72ft Monterey built specially for an electrical contractor from NYC, he was loaded... the interior wood was all imported from Japan and was called Japanese ash and it had the wildest grain ive ever seen and i guess was very expensive, the carpet on the boat had actual Gold laced thru it and the capatain told me the carpet was right at 40k.
the owner was one of the nicest guys ive ever met, you could tell he earned every nickel he had and it wasnt old money, i went home with a 500.00 tip not that it matters, it is an example of a working man appreciating another working man the only difference is he had all the coin |
