  New Posts New Posts RSS Feed - exhaust hoses
exhaust hoses
dans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dans Quote  Post ReplyReply Direct Link To This Post Topic: exhaust hoses
    Posted: March-29-2006 at 7:36am
I recently replaced my exhaust hoses. I had to throw away the carpet wrapped around the old hoses. Why is this carpet even there ? Is it ok to leave it off ? Thanks Dan
Bremsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2006 at 7:44am
I think you want it there. I'm pretty sure its there mostly to avoid rattling and probably some heat protection. The exhaust would rattle against the hull and stringers pretty bad without the cushioning of the carpet.
Bob's2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob's2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2006 at 10:24am
Roger that. Mine has sponges between mufflers & hull.
Bob Ed
83 2001
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2006 at 11:01am
That's not carpeting it's a vibration and noise abatement and reduction system.
dans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dans Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2006 at 12:38pm
This was carpet on the hoses. I left the carpet on the glass packs so they wont rattle. The hoses dont rattle when I drive. Think it's ok to leave off ?
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2006 at 8:03pm
     They used the scrap carpet from the floor to wrap not only the exhaust, but also used it on the gas tank wood rails. You will find several different colors on different boats which I think was pretty neat.
                                  Jeff...
